Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Mitsubishi WS-55513 won't turn on
The mitsubishi WS-55513 won't turn on. Just a flashing green light .
Took it to a tech who wanted $650 for a new DM (?) board install.
Any Ideas.
Thanks,
Roy
  • 6 more comments
  • freelanc Nov 07, 2007
    WS 55511 Mitsubishi 2002
    turn unit on .. shuts off in 5 seconds ......
    have seen green light next to ON button over TIMER label blink continuously for a while then ....... shut off too.
    Any advice please freelance@digitaleventphotos.com
    am in maryland .. repair person would be .... ?? called local tv repair .. don't work on mitsubishi ........
  • luqman Nov 23, 2007
  • jrabp Dec 13, 2007
    One day the Mitsubishi WS55513 worked fine; the next day, the television won't turn on. The flashing green light continues to flash even after pushing the reset button and unplugging the set.
    Suggestions?
  • Anonymous Dec 17, 2007
    I have the same problem that green light won't stop flashing not even to press the reset key to see if this works. Thanks
  • Orvy Dec 19, 2007
    I have the same exact problem, the green light is flashing and will not reset. I saw the one dude who responded saying that you should try to reset the thing. That's all fine and dandy, but the thing WILL NOT RESET!! Read my shit before you post a suggestion on how to fix it Phawwt you suck.
  • dobber1 Dec 23, 2007
    I have a Mitsubishi ws-55513 and I also have the same problem with the green light.If the fix costs $650 then at what point should I just sell this TV since it is not worth $650 and just buy a new one.The sad part about this is that I thought Mitsubishi made a great TV and since this seems to be a problem that alot of owners have then I say instead of loosing me as a customer for life then maybe mitsubishi should help us with the cost or otherwise for $650,Im going to buy a new TV.BTW the warranty is for 3yrs and I have had it for 4.Sorry about my luck,Reset button doesnt work either btw. Thanks
  • kayleigh22 Dec 24, 2007
    TV was working fine no problems at all, turned it off came back 1-2 later and it won't stay on clicks on then clicks off. reset didn't help either. does this module burn out from so many hours usage or how many times TV is turned on and off?
  • adamstriz Feb 02, 2009
    how do you get the dm board out? It is the biggest shield in this thing right? ws-55513
From what i know thru extensive research.....and i mean alot the dm board (as in the whole thing) is not all bad its thecapacitors on the dm board that are supposably cheap O'z if you know what i mean. there should be 4 of them. you can buy the replacemnets from radio shack for about 8.50. if you know someone who is handy with a soildering iron, or a freelace electically type then ask them if they can put the new ones on for you. the correct one you need are -40 degrees to +85 degrees Celceus...tolerance +20%, now this is important 1000microfarad.... now these capacitors cant be less than 16V they can be over but not under.... typical brand to get is xicon....you have to remove the dm board which is in a metal shield once the back part of the television is removed you will see it cause it looks like it should be in a computer. but apparently this is typical and its a very simple fix but everyone that is capable to fix it want to bend you over and do you dry....mitsubishi should be ashamed of themselves for not correcting this themselve and offering help with cost.. hope this helps guys!
natalie
Posted on Jan 20, 2009
    Genius:
  • 1,694 Answers
Two choices =
1) Replace DM MODULE. 650.00 is right.
2) Rebuild DM MODULE. Done right = a little less than Mits.
Caution: High degree of skill needed and ask about warranty
in either choice.Rebuilds usually cover only parts installed,
not complete module.If you do the research on repair,you
will find pin push reset does not work,in most cases....T.
Posted on Nov 05, 2007
Wait for the flashing green light to stop the use a pin to push the reset button next to the power and it should turn on fine. I've had this issue a couple of times when I get a power spike.
Posted on Nov 02, 2007
Hey anyone there? I have a WS-55513 with a
There are 4 capacitors on the dm board that cause this problem if they are not puffed up, however the dm board will need to be replaced.
Dec 06, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Green light flashes under timer when tv is turned on. no picture
Sounds to me that the DM is the cause. If this model is 7-8 years old, it uses a DM that is no longer available or supported by Mitsubishi. You could confirm this by calling Mitsubishi at 1800-332-2119. This is there Customer Service Line.
Hope this helps,
Skyassoc
Jul 18, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi-ws55859 power failure flashing timer green light
the capacitors on the DM need to be replaced. Very easy repair you can get the repair kit at this link which is for your model it contains the replacement capacitors and step by step insturctions.
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
Apr 03, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi hdtv1080 won't turn on. green timer light flashing
could be a lot of things really. when you replace the bulb, there is a switch that will prevent the tv from turning on if the cover isn't sitting correctly, by moving it that might have shifted so it would blink, but not turn on. if not, well get it serviced, sorry
Mar 04, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Wont power up , green indactor light wont stop flashing
You have four capacitors bad on the "DM" module in the unit. I recommend you get a tech to do this repair. This is due to the complexity of accessing the DM module. A qualified tech can do this repair in under an hour. You can find a tech in your area by inputting your zip code on the home page of this website. Let me know if I can be of further assistance
Jan 11, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi ws-55513 blinking power light
The infamous flashing green LED problem is usually due to a failing or faulty DM board. I purchased the PDF manual online and was able to locate and remove the components as necessary.
If you can solder, and are semi-proficient with electronics it is 4 bad capacitors on the DM board...
Otherwise there are facilities that can repair your failed board for about 275.00 or replacement of the board is between 350.00 and 500.00 buck USD.
Good Luck with your repairs....
-Richard (MetalDad)
email: PentiumDreams@aol.com
May 10, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS 55513...
www.chrisandnat.com/projects/blinkingtv/blink.htm
Also,check three 4 amp surface mount fuses on trace side
of board.............T.
Mar 10, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi ws-55513 green flashing light issue
I would asssume that the four cap replacement you're referring too is in the power supply of the DM module. (The large silver looking box on the left looking at the back of the TV)..
You can unplug that module from the signal board and remove it. Open the cover and you should find 4 16v caps in the power supply. If they look buldged chances are they are the failure. If not you might want to take an ESR meter to them to confirm they're okay and move on... In the back of that module is a small vertical board called the E2P module. Unplug it from the DM and plug the DM back into the signal board. If it powers up your picture might not be in the best alignment but you've identified the problem - just replace the E2P module.
If none of this works you're going to start getting into some greater technical requirements - but let's cover that when you get that far...
Bill
Dec 28, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi flashing light replaced capasitors that were blown tv still has flashing light
The four cap replacement in DM module repair is simplistic
and incomplete, as you found out. ALL defective DM modules
have bad SMC's ( small "top hat" caps) AKA surface-mount
capacitors that can be changed only by the most highly skilled
bench techs. We used to change out hundreds years ago in
camcorder circuit board repair.DM board repair is a much more
accessible,thus more "do-able". For more info.............T.
Sep 26, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
412 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
