Question about Acer Aspire 5315 Notebook
Acer 5315 will not boot up past f2 start up screen
It has crash dumped and switched off then when restarting it does not go past the acer start up screen, it just goes to a black screen and does nothing. It has done it in the past but always started up eventually, not today however!
any help please!!
  • catherine_r May 28, 2009
    So what now?! :)
    Problem Solver:
  • 14 Answers
It is probley over-heated.
Posted on May 27, 2009
Unable to enter setup in acer aspire 5315
You do not say what OS you are running. You could try F12 at bootup to see if you can get to the boot manager that way.
Jan 15, 2012 | Acer Aspire 5315 Notebook
On startup of my acer aspire 5315 laptop i get the message " no bootable device insert boot disk and press any key"and nothing i have tried can get me past this screen.I can't even get get into...
Hi Charles, I apologize for the inconvenience. In this case what you could try is to get into the BIOS screen for the laptop by pressing the F2 key as soon as you turn on the laptop.Once you are in the BIOS screen please use the right arrow key to select the tab "Boot" below boot make sure that the hard drive is the 1st boot device(you can change the order by using the F5 and F6 keys) and then load the default settings in BIOS using the F10 key and select "YES" and the computer would restart once.In case after performing the above steps the issue still persists then the issue is with the hard drive on the laptop not being detected and if the computer is still covered by warranty please contact Acer and do get the laptop repaired or else you could have a local technician replace the hard drive for you.
Best wishes for your effort.Thank you for your time and patience.
Nov 12, 2010 | Acer Aspire 5315 Notebook
I have an Acer Aspire 5315-2290, I recently installed norton 360, made the notebook worse, so I uninstalled norton 360, and system crashed. I turned it on, and tried "start windows normally" and...
You may be able to purchase a recovery disk from Acer.
Failing that if you have the Windows installation CD you can boot up with the Windows CD and run Repair.
If you do not have a Windows installation CD, you might be able to borrow one BUT check the Windows label on the bottom of the notebook for the Windows version and the Product installation code.
Make sure the Windows CD matches the version that is printed on the label.
You may need to install the Acer device drivers again then -
Download the drivers from the Acer WEB site. Make sure youselect the model of your laptop and the XP or Vista version of the drivers youthat require and it matches the Windows version that is installed on yourlaptop. Use this link to get to the Acer support: -
http://www.acersupport.com/drivers_download.aspx
Oct 27, 2010 | Acer Aspire 5315 Notebook
Acer 5315-02153 Recovery disk instructions
When you start your computer press f1 or f12, it will let you know on the screen, you want to press the one with set-up on it. Now find boot sequence and put cd rom as first boot sequence, that way it will boot off the disc and not the HDD (harddrive)
Feb 21, 2010 | Acer Aspire 5315-2153 Notebook
How to setup windows xp on acer aspire 5315
put cd in machine and restart Keep hold of F2 to enter setup (BIOS) find the 'Boot' tab and ensure that your cd/dvd drive is the 1st boot device. now exit saving changes. on startup now it should ask 'press any key to boot from disc' do so and blue RAID screen will appear. wait until instructions appear and follow, making sure you format the partition.
hope this helps, if theres any problems just ask.
Jan 28, 2010 | Acer Aspire 5315 Notebook
The AC cord accidentally got pulled out of my Acer Aspire 5315 and now when I turn on the machine it won't load past the Acer screen. F2 bios won't load neither. The Hdd indicator is flashing too. I have...
sounds like you need to reload operating system. do this, on boot up strike F12 until it goes to another screen. choose boot in safe mode or last known good config.
Aug 19, 2009 | Dell Latitude D600 Notebook
My son's 5315 will boot up, then hang, do a memory dump, then restart at the screen that asks how you want to start Windows, i.e., safe mode, normally, etc.
hello
If it is showing the memory dumping message then you RAM is dying.
you soon have to replace it with a new one.
If it shows some other error message then please mention.
Thank you
Aug 16, 2009 | Acer Aspire 5315 Notebook
Acer 5315 will not start up windows
check the BIOS setup screen, when you get the ACER screen press F2 or F10 or the DEL or END or ESC key one of those will get you into the bIOS SETUP. Once there revise the boot order, make sure the CD is first to boot then HDD. Also review to see if the BIOS recosgnized the HDD. the symptom you are describing may be a bad HDD.
Jun 02, 2009 | Acer Aspire 5315 Notebook
Black screen with blinking curser in left top corner
Hold the power button down and let it fully power off then boot it back up. If you get a prompt saying Windows did not shut down normally, select Last Known Good Configuration.
May 19, 2009 | Acer Aspire 5315 Notebook
Black screen with cursor acer aspire 5315
start your laptop in a safe mode by pressing f8 during booting, the restore your system to a back date where its working fine
Sep 30, 2008 | Acer Aspire 5315 Notebook
Acer Aspire 5315 Notebook Logo
333 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
