Question about Yamaha RX-V3000 Receiver
Yamaha Receiver (rxv3000) has intermitent power problem
I have a Yamaha RXV3000 receiver that will work for a few months with no issues and then when powered on it shuts off like it is in protection mode or something similar. I have unhooked all connections and have reconnected. I thought it might be a short in my main speakers but I have since replaced and it worked for about 3 months and started clipping off. I have taken the unit to the repair center twice and they can not replicate the issue which tells me it is probably not the unit but somewhere in my connections. If I disconnect everything, the unit will not operate for a number of days but then it will start working with no issues. I have switched speaker wires. Currently, I only have mains and center connected to the unit. Can connections such as video be causing a short of some type? I have another Yamaha receiver that is older and connected it to the sames speaker set and it worked without failure for a couple of months. This very frustrating and any help would be very much appreciated. Turn on then It turns back off right away, but this is an intermittant problem
Most, but not all of the voltage regulators are cooled by the same heat sink
that the output transistors are attached to and get overheated when you crank up the volume. Although this unit has a cooling fan, after some time the heat sink gets HOT and will age these parts. There are also a group of three current limit/ voltage drop resistors supplying one regulator that will give up too. This is not for most DIY folks. Repairs are available in certain parts of the country. I know of one you can ship the unit to and get it fixed like I did.
Posted on Sep 17, 2009
I also had the very same problem.....I followed the instructed already posted indicating that it was a speaker problem....Instead of disconnecting all speakers at once, I went pair by pair.....and tried to turn it on and see if unit then would stayed on...not really...I continued with the same process....until I got to the last set of speakers....to no avail...
Eureka!.....a few minutes, say 5 or 10.....I turned on the unit and stayed ON!! ! ! ! ! !
Than I re-connected all speakers......and the unit is working fine.
I was at the point of purchasing a new one........to this day I do not have a clue of what caused the unit to go into "protective mode".....
Folks, try this route......and it worked for me....It was a matter of luck...perhaps...I do not know.
Posted on May 31, 2009
  • icebreaker20 Nov 01, 2010
    It'll occurred again ... just don't know when with yours. It occurred again and permanent with mine.
Hello: I would like to know if you could tell me if there is a way to get this receiver to work again. As it does not turn on when powering it up.
It sounds like the power supply has gone out on it, I am having no luck in finding a replacement part for you though, sorry.
May 12, 2016 | Yamaha RX-SL100 Receiver
The rxv3000 will not power up instead it would produce a clipping sound.
I have the same issue with mine, did you ever find a solution?
Nov 26, 2012 | Yamaha RX-V3000 Receiver
Hi receiver is having intermittent problems with power up & off. at the moment it would only turn on once in 5 times i try to turn on. At one stage it would turn off but then back on again within five...
I got Yamaha RX-V3800 with intermittent power.
Cause by capacitor C4 22nF 630V on the control power board.
After replacing the capacitor, receiver again working OK!
Feb 13, 2011 | Yamaha RX-V3800 Receiver
I have a DVD and a HD cable box going through my Yamaha RX-2400. Things worked great for past 6 months but recently started getting flickering picture and eventually picture was gone. TV says it is...
I'd investigate the intervening video-carrying cables.
Consider whether you actually NEED to route video through the receiver in the first place. Is all that extra cable and 2 extra interconnections actually doing any good? Apparently not.
In my rig, I run high-end video only to my TV and high-end audio only to my receiver. No problemos.
Feb 12, 2011 | Yamaha RX-V2400 Receiver
Yamaha rx-v456 av receiver, shut down with optica cable
Does it work without PS3 attached?
When receiver turns off, it is usually due to badly connected/configured speakers. Try powering on the receiver without speakers.
Jan 06, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
The unit turns on then shuts off after a few seconds.
This could be a bad speaker or speaker wire. I had this same problem recently. In my case it was the powered sub-woofer. I disconnected the speaker wire from the back of the receiver(with the power off, of course). When I powered up the receiver, problem solved, it worked fine. I then made sure the wire was not shorting out, carefully reconnected everything and the sub works too. I never found the cause, but it has worked fine for several months now.
You can start by disconnecting all the speakers. If the receiver powers-up reconnect them one at a time to find the bad wire/speaker. If it is not the speakers, disconnect all attached devices. If the receiver still won't power-up go shopping for a new one. It is not worth repairing. It is less expensive to replace it.
Remember, always turn the power off and set volume to zero before disconnecting or connecting anything! You don't want to cause any damage.
Nov 06, 2009 | Yamaha HTR-5790 Receiver
Yamaha RX-V2400
Get another receiver! I had the same problem and had the power supply replaced $250 and after 3 months it started doing the same thing.  I just purchased a Pinoeer Elite VSX 90TXV.
Jun 04, 2007 | Yamaha RX-V2600 Receiver
UNIT TURNING ON BY ITSELF
check and see if the power button is not binding tightly on the body of the set.if everything is okay call a tech you are having a short in the power supply good luck.
Apr 11, 2007 | Onkyo TX-SV535 Receiver
Yamaha RX-V3000 Receiver Logo
773 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
