Home | Keyboards and Mice | Broken Prong inside con...
Keyboards and Mice
Problem for Keyboards and Mice
Generic problem for all Keyboards and Mice
Broken Prong inside connector for mouse
By nicole08 on Oct 21, 2007
Hello how do I fix a mouse that has a lost prong on the inside?
Comments:
Oct 22, 2007
- Ok maybe I wasn't clear enough I tried to plug the mouse into my computer and I accidently bent one of the prongs on the connector/ male part of the PS2 connector that fits into the computer. I tried to bend it back but broke it off and now the mouse does not work. Is there anything I can do to fix it?
Thanks
Nicole
Same Problem
Apr 12, 2009
-   i have the orbit elite mouse
when i move the mouse upwards it works great!
but when i move it sidewards it stops working
i have cleaned the ball and cleaned the inside but it still doesn't work!
please tell me what to do
i think it might be the pin thing in side
HELP!!!
-   jls4eva
Nov 15, 2008
-   I used a fingernail file to open the hole that was blocked because it was still bent on my mouse since I didn't have tweezers. It worked!!! Thanks for the tip.
nikoftimetravel.com-   nikoftime
Nov 15, 2008
-   I used a fingernail file to open up one of the 4 holes that was blocked because it the prong was still a little bent. It worked!!! Thanks for the tip about tweezers even though i had to use a file.
nikoftimetravel.com-   Guest
Solution #1
posted on Oct 21, 2007
Somewhat Helpful)
BigLou1958
Rank: Wiz
Rating: 81%, 171 votes
If the ps2 port on the main board is broken you will need to replace the board. If this is the case and your computer has usb ports on it just go out and buy a usb mouse.
If the part that is broken is from the mouse by using tweezers try to gently remove the broken part from the board. if unsuccessful use the usb port with a usb mouse.
Was this helpful?
Yes
No
Popular Solutions for Keyboards and Mice
Questions and Unsolved Problems for Keyboards and Mice
Answer
Microsoft's Elite Wireless keyboard and mouse is an excellent combination for use, according to your... (More)
Answer
I installed my logitech software for the mouse, has new batts., but will not work. What am I doing... (More)
Answer
When I push the space bar instead of taking me along one space it takes me to next line
Answer
I had to change the batteries of the Logica MX 3200 Mouse. When I did, the Mouse failed to light-up... (More)
Answer
my spacebar and backspace although clicking does not work and any typing i do just jams together... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Keyboards and Mice:
Top Keyboard and Mice Experts
Rank: Guru Guru
Solutions: 14051
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Keyboard and Mice Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
