Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
I need to clean freezer drain plug that's under condenser coil in freezer. How to remove?
I have a regular refrigerator with top freezer.My problem is the little drain under the condensor coils is plugged.My question is there a simple way to remove it and clear it?Thankyou.
    President:
  • 1,136 Answers
HI, Could you get em a model # so I can assist you further?
Thanks
Vic
Posted on May 27, 2009
Defrost drain is freezing
it is a normal problem with all refr. there is a drain tube at the rear of the unit the has a "drain loop" it gets plugged after a few years. try and remove the tube from the clamp, and run water thru it to clear the blockage. you will also need to remove the ice from under the freezer coil after you clear the tube. after that the regular defrost cycle will take over and work properly.
Dec 31, 2013 | GE GDS18LBR Bottom Freezer Refrigerator
My LG Model LRTN18320WW is leaking water inside frig. on bottom below produce drawer. has occurred since summer. what is solution?
Drain in freezer compartment is plugged.
Mold (fungus) buildup sometimes restricts water flowing into condensate tube in the defrost cycle, and water somehow can enter in the refrigerator compartment and out the bottom of the refrigerator door.
You must clean the condensate tube!
You must remove back cover in freezer. One screw in left upper corner behind plastic screw plug will allow you to remove the cover exposing evapourator coil and condensate drain tube hole below it. Must also remove back cover at rear of refrigerator exposing the condensate drain tube END which may be restricted also.Tube must be totally cleared to allow the water created from defrost cycle to exit to the drain pan in the bottom of the refrigerator.
Oct 05, 2010 | LG LRTP1231W Top Freezer Refrigerator
My refrigator is leaking water
Most times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section ( not on all models, but this is the most common way ), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On a S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system. For some reason Whirlpool has found a need to "hide" the drain hose inside the walls now ( Whirlpool makes many of the Kenmore branded refrigerators ) on there top freezer refrigerators. This makes accessing the drain hose to flush it out more difficult, no cup inside the fresh food section, no hose down the outside back wall and the only access is inside the freezer section behind the back false wall and under the evaporator coils.
hope this helpout ......
Aug 12, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The freezer leaks water and the fridge is 43 degrees and full of condensation on the inside
Most times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section ( not on all models, but this is the most common way ), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On a S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system. For some reason Whirlpool has found a need to "hide" the drain hose inside the walls now. This makes accessing the drain hose to flush it out more difficult, no cup inside the fresh food section, no hose down the outside back wall and the only access is inside the freezer section behind the back false wall and under the evaporator coils.
Hope this works...............
Jul 28, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The inside of the refrigerator get full of water condensation(lots)
It is not condensation
The drain at the bottom of the freezer under the coils is clogged. Remove Icemaker if you have one, remove bottom floor of freezer, remove back panel of freezer. Use hairdryer to melt ice. ALL ICE MUST BE REMOVED. Use hot water and a turkey baster to get ice out of drain hole located about middle under coils. Be patient, do not chip ice with sharp tool. After ice is removed pour hot water down drain hole. Water must come out in drain pan under refrigerator(you may have to take front grille off to get to pan)
If Ice returns after a few weeks, you need to look at defrost thermostat which is usually clipped on cold coil at back of freezer. This part or the defrost timer could be defective.
Sep 14, 2009 | Amana Refrigerators
I keep getting water in the refigerator. Everything works fine, but the water just drips and drips
Hi
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 03, 2009 | Haier RRTG21PAA Refrigerator
Water leaking inside refrig below ice maker
Hi
Thanks
Rylee
Jun 22, 2009 | Kenmore Refrigerators
All items in freezer were defrosted when I opened the door this morning. Fridge is semi cold.
Hi
Some leaking water refrigerator helps....
  1. My older style Amana freezer on top refrigerator is leaking inside
  2. My refrigerator is leaking water inside
  3. My refrigerator is leaking water onto the floor
My refrigerator is leaking water inside the fridge:
Thanks
Rylee
May 30, 2009 | Kenmore Refrigerators
Water leaking inside the refrigerator
Hi
Please do rate the solution as FixYa if found useful and revert for further assistance.
Thanks
Rylee
Apr 17, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Ice build up under rolling tray in freezer
Yes you are right there is a drain tube in the middle of the coils. You need to remove the back panel and you will see the coils of the evaporator (freezer) and right underneath you will see drain tube. Now more then likely it is plugged with ice so take some regular table salt and two or three teaspoons on the top of the tube opening will break it loose and start draining. Take some regular tap water and pour down just to flush the tube and inspect the bottom collection pan under the fridge and see how much water is coming out. Be sure to have unit turned off when you do this cause the fan will run inside the freezer compartment other wise. Hope this helps you. ken
Jan 11, 2009 | KitchenAid KTRS22EM Top Freezer...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
114 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
