Question about JVC Televison & Video
80% of the picture is black
My JVC Model AV-27260 Serial No.08622084 when turned on 80% of the picture is black. Sometimes the whole picture will come back on for a few minutes and then go black 80% again. I did turn the closed caption off but that did not help Would appreciate any suggestions...Thank You
  • lwlareocoupe May 27, 2009
    The 80% I'm talking about,is the screen itself turns black.The 20% is a regular picture or program that is running. Thanks for answering so quickly
  • hatman1 May 11, 2010
    I need clarification about the 80% thing. Is this a black box perfectly centered on the screen or the top or bottom or one of the sides too small? If it is perfectly centered then you do have a problem with the close captioning. That is the symptom of being in one of the text mode functions of close captioning.
  • 126 Answers
Ok, if the video is present around the outside of the black box you have a problem with close captioning. It is stuck in either Text 3 or Text 4 mode. The options for close captioning are CC1, CC2, Text 1, Text 2, Text 3 and Text 4 and of course OFF. Apparently the close captioning is stuck on or is not being properly shut off. Better read the owners manual to see if you are missing a step when turning off close caption.
Posted on May 27, 2009
I have a jvc tv , old, model no av-48wp34....turned it on hsd sound pic everything normal , changed channel, picture went 80% black , stil have sound
HI Bonnie,
If you have a good picture when it's on then it points to a dry joint on the circuit board, It is probably round the switching transformer section or the eht section but please be aware of the very high voltages stored in the capacitors and tube.
If you need any more help don't hesitate to contact me.
Regards
Barry
May 06, 2016 | JVC Televison & Video
Tv went Black and wont come on now?
Sounds like you were having a power failure in the community,, we call it a brown out. just turn it off and unplug it,, I'm not sure if this is what the problem is.. I had this to happen years ago on a magnvox console.. I will check and see what I can find out for your model tv..
Aug 22, 2009 | JVC AV-27260 27" TV
A black rectangle is displayed on the screen
the black rectangle appears as soon as the channel indicator goes off. someone has turned on the closed captioning in the menu of the set. it is in the "text" mode. go into the menu and turn off the closed caption feature.
Mar 20, 2009 | JVC AV-32320 32" TV
Audio ok, but Video goes from color to black.
the tv turns on fine, but after 5 - 30 min or so, "sometimes MORE " the picture all of a sudden go's black. Sound is ok it is 100% loose contact problem. 1 please check for any connector or print for loose. 2 in signal processor ic there might be loose. remember there is no component failure.
Sep 24, 2007 | JVC AV-32D305 32" TV
JVC AV-32730 36" picture problem..
From what you describe, a solder joint has probably cracked loose in a power supply or deflection circuit, which is quite common. Since you do sometimes see a good picture, all of your major components are fine. Repairing cracked solder joints is a very easy procedure and definately worth fixing on a 32 inch TV. The first 2 digits of the model number indicate the size of the TV.
Aug 04, 2007 | JVC AV-32D305 32" TV
Jvc Av-48wp30
try unplugging for a few seconds the plug it back in
Jul 11, 2007 | JVC AV-48WP30 48" Rear Projection...
Color comes in and out
could be loose connection bad solder or crack,on the main board ,is hard to tell with out open it, you need to have a little experience to do that, 60 to 80 dls depends on the tech who works on it , in shop 125
Jun 10, 2007 | JVC AV-32F475 32" TV
Tv on with sound but no picture
my jvc tv has sound but no picture. Sometimes when I turn it off for a few minutes it has picture then it goes black
Aug 07, 2006 | JVC AV-27230 27" TV
Av20cm5
Common problem with alot of tvs NOT just JVC but its in the power supply feeder coils or plugs. Cold solder connections all the time seen it a few dozen times. NOW to fix it . I advise anyone who dosent have any electronic experience to seek a pro to assit in the repair cause man this thing if you slip up just a bit will bite ya HARD in the butt!! NO insult intended but without the know how on the solid state repairs you can not onlt cause great harm to the TV but to your self.. Oh yes and we cant give a miricle cure as I wish we could so please understand Im lookinjg out for your best intrest. Good luck
May 27, 2006 | JVC AV-27260 27" TV
Televison & Video Logo
133 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
