Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Ice maker not dumping as frequently and cubes freezing one large chunk
I have a Whirlpool refrigerator model ET20NK with automatic ice maker. Lately the ice maker isn't dumping as frequently as is it used to. Like only once a day now, even with an empty holding tray. When it does dump, the cubes are usually clumped at least 4 together. Plus any ice in the holding tray seems to thaw somewhat and then refreeze into one large chunk. It is an auto defrost. This is the first time we have had a problem with this fridge. What do you advise? Thank you for your helpd.
    Problem Solver:
  • 18 Answers
The first thing I would check is the cleanliness of the condenser coil under the fridge. Make sure the fan under there is running, and that the coil is clear of dust. The ice maker requires 15 degrees for a period of time before it will make ice and dump. If the temp in the freezer is colder than this, then it is likely the ice maker needs replaced. They can be replaced fairly easily with just a couple tools. (1/4" nut driver and a flat screw driver). There is a plug where it plugs into the freezer side wall, and a bent tube that supplies water to the tray. If not sure what to do, have a service tech look at it.
Posted on May 29, 2009
ED25RFXFW01 icemaker
Sounds like the=> W10408179 Dual Water Inlet Valve
has began to seep water at the valve and out through the ice maker fill tube and down into the ice bucket. About all you can do when this happens is replace the above W10408179 Dual Water Inlet Valve. I will be here should you have questions, Thanks Sea Breeze
How to test the valve can also be found HERE
Nov 08, 2012 | Whirlpool Refrigerators
I have a Whirlpool French Door Refrigerator Model #G17FVCXWY and the ice maker jams up about once a month (ice doesn't completely dump into the door bin, water refills into the ice maker, then refreezes to...
HI, we have the same problem with ours from time to time. It is a engineering flaw, bad design, the ice cubes are kept in the refrigerator section, which is about 38-40 degrees. So the ice cubes melt, the only way to keep it clear is to use ice cubes every day and not let then thaw and freeze.
Mar 11, 2011 | Whirlpool Refrigerators
My icemaker is making huge chunks of ice in bin
You will need to replace the termination thermostat. What sounds like is happening is. Every 8 to 10 hr. your freezer goes into defrost for a set period of time. There is a termination thermostat that senses the temp at you evaporator coil in you freezer. When you heaters come on they defrost the ice from your coil. once the termination thermostat senses the temp has gotten to a preset degree, it cuts the power to the heaters. This keeps the heaters from staying on the whole period and making your freezer warm. After the pre set time period the timer turns the compressor back on. What it sounds like is happening is the termination thermostat is not opening, cutting the heaters off. By not doing so, it's letting your freezer get above freezing, melting your ice some. When the timer advances into cooling again it freezes your ice together. I would say it's your water valve leaking but that would make large pieces of ice that the ice maker has trouble dumping and also sometimes a large chunk that does not look like cubs. That would also eventually freeze the inlet tube closed..
Please rate solution
Aug 28, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice cube maker not working whirlpool refrigerator freezer side-by-side model ED5FHEXTBOO
Most like ly the water control valve on the back of refrigerator. Pour water into ice maker. Let freeze and if it dumps the ice change the dual water control valve. Sea Breeze
Aug 26, 2009 | Whirlpool Refrigerators
Ice Maker stopped making Water Whirlpool model (ed5phexnq00)
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 15, 2009 | Refrigerators
In side by side whirlpool refrigerator freezer ice cubes stick
if they are hollow and stuck together then u are not getting enough water..check the supply.
Jun 09, 2009 | Refrigerators
Ice cubes made by ice maker become large fused chunks over time.
Ice cubes will deteriorate over time if not used. They shrink due to defrosting of the freezer and will become stale.
Once the ice bin is full, turn the ice maker off until you use the cubes and or dump the cubes every 3 or 4 days and start over.
Mar 03, 2009 | GE Refrigerators
My icemaker makes large hunk of ice
IF YOU REMOVE THE FRONT COVER OF THE ICE MAKER THERE ID A SCREW TO ADJUST THE SIZE OF THE ICE CUBES TURN IT DOWN AND YOU WILL GET SMALLER ICE CUBES ALSO SOME MODELS HAVE A OUTSIDE KNOB TO ADJUST SIZE,LET ME KNOW-MIKE
Jun 17, 2008 | Whirlpool Gold Series GI15NDXT 15"...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
381 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
