Blue lazer like lines going thru top of screen Any writing on screen is doubled in blue
  • silvio_c May 28, 2009
    yes thanks
    Brigadier General:
  • 3,917 Answers
There are three projection units in the back. Each projects to its own color, Red, Green and Blue.
One of the follow may have happened:
1. The adjustments for one of the colors is slightly off, thus more blue is coming through.
2. The blue projector is off, or it has sustained some sort of damage.
3. A bit of debris has collected in such a manner as to refract a line from the blue or cuts off the projection from Red and Green.
4. The mirror in the rear has a crack.
Most late model project models project from the front to the read of the cabinet where the light is reflected onto the screen via a mirror. That mirror is very fragile and somewhat large. It can (and does) collect a lot of dust and debris.
First try to auto focus the TV:
Most later model project-type TV's have an auto focus feature via the menu, what it will do is align the projectors, going through a few test patterns. The alignment is internal, not actually moving the projector - this is usually all that is needed.
Your Owners manual may have helpful information on how to physically align the projectors. Or it may specifically state you need to have it serviced.
Before you call for service you can do some cleaning inside the box.
Unplug the TV, unhook cables and stuff that will interfere with your opening up the back
On ours we have bolts/screws around the top and sides at the rear, we also have to take off the speaker covers and remove a few very long screws.
Once all of the screws are off, there are tabs at the bottom, front which have to be depressed to allow the back bottom to be pulled out (toward the rear) from there one needs to be behind the TV and lift the bottom up slightly to take it off of a couple of holders.
Once the back is off it becomes clear of just how much debris can affect the picture.
Cleanse the lenses gently with a soft cotton cloth - old torn up t-shirt material is wonder for this. You should be able to get most of the debris/dust off being dry.
On the back cover (that you took off) there will be mirror - that should be cleansed with a non-streak Solution. You will be amazed at the clarity of the image after a cleaning. These cabinets are not air tight and a lot of dust gets on everything, doing odd things to the image, beyond making everything dimmer and fussy, things like making streaks, or lines across the image (in the case of cat hair), causing the color to be off true.
If cleaning the lenses and the mirror does not work and you can not see an easy way to realign the projectors, then call a service person who will have the tools and the experience to align them quickly.
6 Pts Rate Answer
Thank You
Posted on May 27, 2009
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
I do see that the lazer does light momentarily but does not apear to be deep blue. there is initially a red lazer that lights and goes out after which the blue lazer lights and goes out. Is this the sign...
Yes you need a new laser. The red beam should come on and go off only if its a blu ray disc or ps3 game then the laser will go to a blue beam and from there it should read the ps3 game or blu ray. If a dvd movie is in it the laser should light up red beam and read the dvd.
Nov 20, 2010 | Sony Playstation 3 (PS3) Console
Right half of screen black with thin blue line top to bottom about another line inch over another thin line starting blue then red getting thiner to bottom
This is a very common problem with this Panasonic set where half the right side is bad and the other half is good. This has been traced to a general plasma panel defect in the manufacturing precess. The panel lasts only about 1.5 years and they go bad. The only solution is to replace the plasma panel. The charges for the cost and labor will double the original prize of the TV set.Good luck.
Oct 27, 2009 | Panasonic TH-42PX60U Television
Blue outline on the top half of the picture on my Hitachi 51F500
your convergence ic is going bad. usually worth the repairl.
Jun 04, 2009 | Hitachi 51F500 51" Rear Projection...
Blue and yellow curb on top of my 43" hitachi
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 14, 2007 | Hitachi 43FWX20B 43" Rear Projection...
Sounds like there is a problem in the convergence circuit. There should be an on board cross hatch and controls to adjust the lines to a white line. If these control wont adjust then the power ICs in the convergence circuit are most likly bad. if you know how to solder and know how to replace electronic parts then get a service manual find the part #s and order the parts . If you dont know how I can teach you here sorry. But I will tell you that a repair like this will run about 300 to 400 bucks to repair. Good Luck
Jun 04, 2006 | JVC AV-56WP30 56" Rear Projection...
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
