Home | Canon | imageRUNNER 2200 Black and White Copier | Canon IR scan problem
Canon imageRUNNER 2200 Black and White Copier
Problem for Canon imageRUNNER 2200 Black and White Copier
By jschrock on May 27, 2009
We moved from one office to another. We changed the ip address too onboth copier and computer. The printer is networked/working fine withthe computer but when we do scanning it says ''error while interactingwith scanner, the selected scanner was not found.
Network processing is timed out. Check the scanner and network status. The scanner driver will be quitted.
I ran the network scangear utility from the start menu. Clicked ''discover scanner'', and selected my copier and applied it.
I have 3 and all are doing the exact samething.
Solution #1
posted on Jul 24, 2009
Somewhat Helpful)
mdgm
Rank: Guru  Canon Expert
Rating: 89%, 22 votes
Read the Manual (comes with Tool). If you don't have the Tool download it from the Canon site. Go to the copier and press the System/Options button next to Copy/Mailbox/Fax. Press Online. Then try scanning. Go back to copier and press Offline so can photocopy again.
Was this helpful?
Yes
No
Popular Solutions for Canon imageRUNNER 2200 Black
Questions and Unsolved Problems for Canon imageRUNNER 2200 Black
Do you recommend Canon imageRUNNER 2200 Black and White Copier?
Answer
Answer
how to remove the MITAC kyocera km 1500 repair and remove or reset the error code c-6 20
Answer
I have a toshiba e-studio 160 photocopier and i need to know the password. The admin in charge of... (More)
Answer
I have a Canon 210s / F139800 that is connected to the local network but I cannot access the printer... (More)
Answer
My Canon imageRUNNER 2200 won't print envelopes. How can I get this function to work?
Answer
It displays screen to turn off and back on. Error code E00012-002 is there anything i can do to fix... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon imageRUNNER 2200 Black...:
Top Copier Experts
Rank: Guru Guru
Solutions: 1490
Experience: The Truth is a set of corrected errors. Erwin Schroedinger
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
