Question about Apple iPod classic MP3 Player
Battery icon won't show when charging...
I am trying to charge my IPOD classic battery, I have the thunderlight symbol on the top right hand corner but can't see the battery icon charing and showing progress...can you please help??
  • 502 Answers
I think on the iPod classic it doesn't change the battery logo other than showing the little lightning bolt when you plug it into the charger. However if it doesn't hold a charge after leaving it connected for a while, If hard resetting and restoring fails and If you're out of warranty there are third party ipod repair services that will replace the logic board or battery depending on what's wrong. There are also ipod repair tutorials that show you how to replace the logic board yourself, if you're comfortable with taking things apart, parts are usually on auction websites.
Posted on Jun 24, 2009
  • 342 Answers
Have you already reset the iPod? If not I would try that first. It may be that your battery is shot though. It's not a relatively expensive repair though.
To reset the iPod Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If that does not start the iPod to charging you can go to (www.rapidrepair.com) and view free repair guides that show you how to replace the battery as well as how much it will cost to replace. Good luck. Hopefully the reset resolves your issue and you will not need a new battery. Let me know how it turns out
Posted on May 27, 2009
Tip
How do I find if my iPod touch battery is dead?
<p>When the iPod touch battery dies, you cannot do anything with the device. You will receive a warning on the screen of the iPod touch, when 5 percent of the battery turns on the device. Connect the device to a power source as soon as possible to load and prevent the battery goes dead. When the battery dies, the unit will shut down and will be connected to a power and charged before you can use <br /> <p><br /> <p>1. Press the iPod touch "Sleep / Wake" button, located along the upper side of the machine. If your iPod does not care, this is an indicator that the battery is dead. <br /> <p><br /> <p>2. Connect a charging cable to charge your iPod and connect the USB cable to a power of high power. High-power USB ports directly on your computer tower or, if the hardware usually found in the tower on the monitor, the monitor itself. The iPod touch screen shows a big red battery icon on the far left of the icon, indicating that the battery was empty. <br /> <p><br /> <p>3. Press the "Sleep / Wake" to see if the iPod is connected. If so, check the battery life, looking at the battery icon in the upper right corner of the screen. When the icon appears white, the battery is full when the icon is half black, the battery is almost dead, and if the battery is almost dead, you will receive a warning. If the iPod does not start, the battery is completely dead. In this case, your iPod into electronics store and have the battery replaced. <br />
on Aug 05, 2011 | Computers & Internet
160gb classic
iPod Symbol Meanings
The Apple iPod personal media player uses a set of symbols to communicate what's happening to the device: when it needs to be recharged or when it's experiencing problems.
Sometimes it's not obvious what these symbols mean; problems with your iPod may cause conflicting or confusing icons to be displayed.
Folder with an Exclamation Point
This suggests that your iPod can't read data stored on it.
Your iPod may simply not have enough charge in its battery to read its hard drive.
If recharging it doesn't help, you can try connecting it to your computer, then updating it with the latest version of the iPod's software.
If none of this works, you may have a dead hard drive; your iPod will need to be repaired.
Battery with an Exclamation Point
A battery with an exclamation point usually just means that your iPod needs to recharge.
Once the battery has charged up again, everything should be fine.
You can charge an iPod through a FireWire connection to a computer, but not if the computer is in sleep mode or switched off.
Third-generation iPods cannot be charged via USB 2; later iPod models can, however.
If you are having problems charging your iPod, try switching cables.
You can also try resetting the iPod by pressing Play and Select together (Menu and Play on earlier models).
If none of these methods help, your battery may need to be replaced.
Empty Battery
If the battery icon shows an empty battery, this means that your iPod is almost out of charge and needs to power up.
If you know that the iPod has been charging for a while, and the battery icon is still empty, you may need to update its software.
Older software can lead to a confused battery readout.
Wall Plug with Power Adapter
This means that your iPod needs to be plugged into an electricity supply while it updates its firmware.
You won't be able to do anything else with it until you do this.
Frowning IPod Icon with an Exclamation Point
A picture of an iPod with a sad face and x-ed out eyes plus an exclamation point indicates a very serious problem with the device.
In some cases, draining the battery completely then recharging and resetting the iPod can offer a short term solution, buying you enough time to back up your iPod's data.
The underlying problem will remain and is likely to get worse until your iPod is repaired.
Apple Logo
A brief appearance by the Apple logo when the iPod is reset or switched on is normal and nothing to worry about.
If the logo does not go away and the iPod doesn't boot up, there is a problem.
You can often resolve this by putting the ipod in Disk Mode and then restoring or updating its software; note that you will lose all data stored on the iPod if you do this.
If this doesn't work, your iPod needs specialist attention.
Do Not Disconnect
It is not safe to unplug your iPod when you see this icon. Wait till it goes away, then you can safely disconnect your iPod.
Spinning Disk Icons
The spinning disk and magnifying glass icon means that the iPod is performing a disk scan.
If you don't want to perform a scan right now you can re-set the iPod; you'll see a disk with a cross when you stop the scan.
If you would rather let the scan complete, you should connect the iPod to a power source as scanning drains the battery.
If the scan finds issues but can fix them, you'll see a disk plus an arrow.
If everything is alright, you'll see a disk plus a checkmark.
If there is a problem that the scan disk function could not fix, you'll see a disk plus an exclamation point.
Ipod shows RED X
http://support.apple.com/kb/ts1463
Resolution
Restore iPod from Disk Mode
Jul 26, 2013 | Apple iPod MA446LL/A MP3 Player
Show charging symbols
Your question was posted under the Nuvi 680 GPS, so I am assuming this is the model that you have.
On the main screen, you will see a green battery status indicator in the upper right-hand corner of the screen. The battery is divided into 4 parts. Each part represents 1/4 power. So if you have one green bar, that indicates that the battery has 1/4 of power left. If there are 3 bars, that indicates that there is 3/4 power left.
When the unit is charging, you will see a yellow lightning bolt appear over the green battery status icon.
When the lightning bolt is not there, this means the unit is running off of the battery.
When leaving the unit to charge, press and hold the power button until you see that the screen says Charging Battery. A few seconds later, the screen will go blank to save energy.
Pressing the screen again later will either say Charging Battery or Battery Charge Complete.
Mar 26, 2013 | Garmin Nuvi 680 GPS Receiver
Shuffle not working
If an iPod appears not to turn on, check the hold switch on the device.
If this switch is activated while the device is off, it will not power on again until the hold switch is turned off.
If that is determined not to be the problem, the battery's charge should be checked.
When the battery is no longer holding a charge, the device will not power on, but will show a battery icon on the screen for a few seconds.
If you see this icon while trying to boot up the iPod, just connect it to the USB cable and allow the battery to charge, which can sometimes take up to 30 minutes before the iPod becomes operable again.
If no battery icon appears when trying to turn on the device, try resetting the iPod.
Once reset, the device should turn on, but if it does not, the battery may need to be drained first (by leaving the iPod disconnected from power for up to 24 hours), and the reset procedure tried again.
hope this helps
Oct 15, 2012 | Apple iPod classic 6th Generation Digital...
Hello, this is roger, my toshiba laptop showing battery filling sign for 5 second ,however , after 8 hours of charging battery capacity still showing 0% available . i have done solution with device...
Hi Roger,
There are a couple of problems that may be causing your laptop not to charge, the most likely are listed below.
1) Ensure that the battery icon in the bottom right hand corner has a picture of a plug next to it.
If this is not showing there is a problem with the connection between the charger and the laptop. This can be checked by "wiggling" the connector between the laptop and the charger to see if it shows the plug symbol in any position.
The charger can be ruled out as a problem by borrowing a friends charger if they have one to see if that works and to try your charger on their laptop.
2) Ensure that the battery icon in the bottom right hand corner does not have a picture of a red cross.
If this is showing it indicates a problem with the laptops battery and will need to be replaced in the near future. Unplugging and plugging the charger back in can sometimes remedy this but it is only a temporary solution.
3) If none of the above work it is also worth powering off the laptop completely and removing the battery overnight. Then trying to charge the battery the following morning. This can give the laptop time to "reset" itself and cool down.
It is most likely a problem with the battery as they tend to have a shorter lifespan than the chargers (unless the charger is physically damaged by cutting the cable)
Regards,
sjstore2
Dec 18, 2010 | Toshiba Satellite A205-S5823 Notebook
Wondering how to get brand new iMT620 inmotion classic to charge the battery for the first time?
You just plug it into the wall and wait four hours. The battery icon will show full when the battery is completed charged.
Jan 29, 2010 | Altec Lansing inMotion Classic Portable...
My 160 gig ipod doesnt charge anymore.
Does the battery icon show to be taking a charge? If so, you most likely need a new battery.
Jan 05, 2010 | Apple iPod classic MP3 Player
Battery Symbol and "charged" stay on iPod screen
You could try restoring the software back to factory defaults and see if something is missing. Make sure it is fully charged before doing it.
Aug 08, 2008 | Apple iPod nano
No response
That icon means your hold switch is on, follow this link and refrence page 5. http://manuals.info.apple.com/en/iPod_Features_Guide.pdf The hold switch is located on the top of your ipod and it slides left & right, this feature allows you put it in your pocket while playing music and you don't have to worry about accidently hitting buttons, it locks all buttons out hence the pad lock icon. Good Luck L8R
Sep 18, 2007 | Apple iPod MA446LL/A MP3 Player
Apple iPod classic MP3 Player Logo
517 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
