Washing machine won't drain
I have the front panel opened and the water is bailed and clothes are removed. Where is the drain pump to check for the clog? Thanks
    President:
  • 1,136 Answers
Hi, get me a model # and I can assist you.
Thanks
Vic
Posted on May 27, 2009
Won't drain the water anymore
Drain motor is usually located on the bottom of the machine. Hopefully you have an access panel separate from the main door panel. Should be a hose coming in and a hose going out. Put the machine in spin cycle and see if you can feel the pump spinning. If the pump is very hot, chances are something is blocking it. They will usually have an access port that can be opened up just for this reason, be ready to catch the water when you open it up, and please turn the machine off first. If you get no sign of life from your pump it may have died. Also check for any blockages in the drain lines. All of this should be easily accomplished with a couple screwdrivers and towels
Apr 10, 2013 | Baumatic BTWM4 Front Load Washer
Tip
Washing machine won't drain, pump stuck
If your washing machine won't drain and, the pump appears to be stuck:
Go to an autoparts store and, buy a radiator locking hose pinch off plier. Then: unplug the washer (remove all power) bail out all the water with a cup or, bowl; remove the washer cabinet or, tilt back the washer against a wall so that you can access the pump from underneath the front; pinch off the tub to pump hose; lock the plier, place a towel under the pump; remove all screws on the pump cover; remove the blockage from the pump and, reattach the pump cover. remove the pliers and, test the washer. (if you can acces the pump from the front (like a front load washer) you do not need to bail out the water as, the pliers will hold the water in the tub, so that only a small amount of water will come out when you open the pump.)
on Apr 07, 2010 | Washing Machines
MY WASHER WON`T DRAIN
  • Wait to see if the water will drain on its own since there may be delays of up to three minutes between cycles.
  • Unplug the washing machine to avoid risk of electric shock.
  • Confirm that the drain hose is not "kinked," or trying to drain from a height of more than 8 feet from the floor.
  • Remove the front service panel at the bottom of the washing machine by unscrewing the three small screws using a screwdriver.
  • Drain the tub by opening the drain plug, which is located under the washer door adjacent to the pump. Use a bucket or large plastic bag to contain the water.
  • Clean any lint, coins, pens, screws, clothing or other items out of the drain.
  • Blow into the drain hose to determine if there is anything clogging it.
  • Feel the pump. If it is hot, it may also be clogged. Remove the pump, open the tension clips and remove any debris from inside the pump.
  • Reassemble the pump. You may need to replace the factory-supplied tension clips with metal screw clamps.
  • Jan 29, 2011 | Zanussi IZ161S Front Load Washer
    I have a fisher and Paykle GW612 washing machine, it won;t drain the water and won;t do the spin cycle. It now is making a huming noise. I think it is the motor that has an issue?
    There should be a tech sheet located underneath the control panel that has the procedure for putting the machine in "diagnostic mode" and you can easily run the water pump by itself. Listen for a "hum" sound- If you hear a hum instead of a running water pump, then something is keeping that pump from turning for sure.
    If this is the case, then you would need to check your water pump. It is located underneath the machine in the right front corner (as viewed from the front of the machine)
    There is a black plastic external cooling fan impeller that you can spin with your finger (of course unplug the machine first) and see if the pump spins freely. You should also examine the pump for signs of leakage or corrosion. You may simply have an object that was left in someone's pocket that has become lodged in the pump. Pump removal requires no tools, however you need to first bail out as much of the remaining water in the wash tub as possible.
    Jan 15, 2011 | Washing Machines
    Kenmore washer
    most likely you have a sock or, some cloth obstructing the pump.
    you will have to bail out the water then: remove the Sears 700 series 4screws holding the washer's control panel and, remove the washer side clips under the panel to remove the washer's sides then remove the 8 pump screws to remove the pump face and, remove the obstruction. the
    exploded drawings can be found at: http://beta.searspartsdirect.com/partsdirect/index.action
    Jul 14, 2010 | Kenmore Washing Machines
    Washing machine will not drain
    Hi
    The drain line is probably clogged. Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. In this case it may then get into the drain hose that's attached to the pump.Remove the hoses from the pump and pull the item out. In case it clean there, check the outer tub port- open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then,try to remove the clothing through the port.
    Thanks for contacting Fixya.com
    Oct 11, 2009 | GE Spacemaker Washer and Dryer Electric...
    Maytag Neptune front loader won't rinse/spin
    you have something clogging your pump
    remove the back panel
    clamp the tub to pump hose or deal with all the water when you remove the pump - three bolts
    open the pump - three screws
    remove the object blocking the impeller
    check tub to pump hose and pump to drain hose thoroughly
    reassemble
    be careful of the machine opening once you remove the rear panel it is razor sharp !
    Oct 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Due likely to overloading last load, washer now does not drain
    Check the belt. If it is good,
    Bail out the water.Open the front panel. Remove the hoses to the drain pump. Clean the debris from the pump. No debris, replace the pump.
    Apr 01, 2009 | Maytag Washing Machines
    Water runs during final spin cycle
    You have a blockage in the drain pump. Remove the front panel to access the drain pump.
    Bail the water from the tub.
    Remove the hoses on the pump and clean out the lint or garment from the pump.
    Mar 26, 2009 | Frigidaire Washing Machines
    Wahing machine kitchenaid won't completely drain water
    Check drain pump for any blockage.Pump accessible by removing lower panel,on bottom front of machine.Also try liquid instead of wash powder,and make sure that you are using automatic powder as other will foam in machine.
    Apr 01, 2008 | Indesit W 123 Front Load Washer
    Washing Machines Logo
    15 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
