Gateway ml3108b laptop wont start up
The laptop would nt turn off so i unplugged it and let the battery run down until it turned off then when i plugged it back in and turned it on nothing appears on the screen i have a blue light indicating i have power and the battery is fully charged ,no recent hardware or software has been added ..any suggestions ??? My Laptop will just not start up , power light come's on CD trys to start but thats it
  • Anonymous Mar 29, 2014
    wont powero. jut a pnk sometimes blue light
    Problem Solver:
  • 5 Answers
Shine a flashlight on the screen. if you see a faint image, its the backlight thats the problem and you will need to get a new one to fix that. But if you dont see a faint image you will need to hook it up to an external monitor( an monitor that is not made into the laptop) , and if you see an image on the monitor you will have to clear the CMOS.
and to do that you will need to take out the battery, the plug, and hold down the ON button for about 30-60 seconds. Well thats how you clear it on most laptops. But if it does'nt work on the external monitor you probally have a bad video chip and need to replace your old one.
Posted on May 27, 2009
Gateway M275 doesnt turn on
unplug it from the wall, remove the battery, hold the power button down for 30 seconds, then plug the power cord back up and into the laptop and press the power button, if that makes a difference, replace battery and see if it continues to run
Oct 11, 2012 | Gateway M Computers & Internet
MD781 battery wont charge...will run with the power cord plugged in, I replace the battery first thinking that may be the trouble. Still wont charge...it would run for a short while on the battery when...
Hi
Can you please try to leave laptop switched off
plug in laptop and leave until the light on front goes green or at least 2/3 hrs
then unplug power cord
switch on laptop and use it or leave it until it looses all power and switches off
then recharge until green
when battery is fully charged always un plug and use on battery power
until it reaches about 10% before recharging
some people even remove their battery to preserve it if they always use power cord
if this does not sort the problem please come back to us
many thanks
Feb 23, 2011 | Gateway MD7818u Notebook
Gateway M-6862 laptop will not turn on; battery light flashing re
Seems to be a problem of not enough power.
First check the voltage output of the charger(adapter) and match it with its specs.
Also try to reset the hardware using the following steps:
1 Disconnect battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Reconnect battery and charger and try to start by pressing the power button.
Mar 07, 2010 | Gateway Computers & Internet
I need a bios update for a Gateway ML3108b.
So you are a tech so so Hello
I am also a tech here arre the things you should allways do before you attempt to slay the dragon man (IM THE DRAGON) lets get you fitted for the job
Ok Bio's man I hate firmware Let me snoop
brb
Here are some I think snoop around
http://bios-download.net/
You might surf a little more i have a system cd refernce on my machine you might try
it is: http://www.user-guides.co.uk/asp/search.asp?keywords=ML3108B&recor=1
Oct 19, 2009 | Computers & Internet
How do i restore my gateway laptop ML3108B to factory settings
Put your original restoration disc in the computer and boot it, it will probably ask if you wish to completely restore your computer back to the original configuration, click yes and follow the prompts as given to you by the program. There may be several discs and they are probably nukbered. As the program goes through the process it will ask you to remove one disc and insert another until it tells you to remove all media and reboot. When that happens, it will be just like the day it came to you. Beware though that windows at that time will want to update. My advice is to turn the automatic updates off until the computer stabilizes, then run windows update,but choose custom install and look at the updates and run maybe 10 at a time. That way there won't be any hangups or file corruptions. Reboot after each update untill you are done. As far as your drivers for the components installed in the pc, when you are on windows update, choose custom install instead of express, click on optional updates and you will see under hardware all the updates for your systems components. Get everything there and you will be all set. Good luck, ParrotHead PC Repair
Sep 11, 2009 | Gateway MT3705 Notebook
Gateway laptop ml3108b no screen coming on
this is a common fault with this laptop, the only way to repair this is to strip the laptop, remove the mother board, heatsink and fan under the heatsink you will see the nvidia chip this needs to be heated to 480C for about 5 mins only heat the nvidea chip nothing else! paste chips and replace heatsink fan etc laptop should now be fixed, remember to clean fan whilst it is out as a clogged fan probably caused the fault in the first place
Jun 11, 2009 | Gateway M305CRV Notebook
Laptop shuts down in 6 seconds.
Most proably it is a main board problem. Contact authorized service center.
Jan 27, 2009 | Gateway MX6448 Notebook
This is a problem with that particular model of laptop.
It seems that the GPU chip (Graphics) overheats resulting in the solder points not making a good connection to the motherboard.
If your quite hardware savvy, you could strip her right down, take of the cooling unit and clean off all the old thermal compound and dust from the Heatsink, CPU and GPU. Then replace the thermal compound with better stuff (Arctic silver 5). This may solve the problem.
I had to do a bit more than this to get mine up and running though. If you need details just let me know.
Better still is if you know someone who's real good with a heatgun (aka Someone who's done this sorta thing on an XBox360) that can reflow the BGA joints on the chip for you. Sounds dangerous i know but if your lappy aint working theres not much else to lose.
Good luck, maddoc666.
Dec 02, 2008 | Computers & Internet
Computers & Internet Logo
508 people viewed this question
David Payne
David Payne
