Pool heater pilot lights, goes out when heat called for
Ray Pak, 2100, good pilot, tried new pilot generator and gass valve. Jumped terminals around safety switches, cleaned pilot and burner. Seems like the gass pressure may be too high, would this tell the valve to shut down the pilot when heat is called for?
    President:
  • 1,902 Answers
No, that would just cause you to have huge flame. There is another high pressure switch located next to the flame sensor/ pilot genator that can cause this problem it is the size of a quarter and is screwed down with 2 phillip head screws
Posted on May 27, 2009
How do you change the flame sensor
It is not a flame sensor. It is a pilot generator or sometimes it is called a thermal pile or thermocouple.
easy to replace...
loosen brass nut, with aluminum tube at gas valve, and take good notice here... Two wires follow along the tubing and are connected to two of three screws on top of gas valve - loosen and remove. then unsecure pilot assembly from under the burner tray. Pull out the pilot assembly as one unit along with the tubing.
Then either unscrew small retaining nut or just pull straight down and generator will slide out.
i would replace the whole pilot assembly. If not at least clean the pilot orifice!
look at the picture at the following site. Click on 'enlarge picture'
good luck.
Parts4heating com Teledyne Laars R0027600 Pool Heater Universal Pilot...
Jun 15, 2014 | Hayward H-series Electronic Gas Pool...
Heater fires 3 times then quits, light on control board quits blinking then minutes later it tries again.
It sounds like a weak pilot generator. They wear out after a number of years. It is trying to fire which means the safety loop is all good. Sometimes the pilot generator is strong enough to keep the pilot valve open, but upon call for heat the main gas valve isn't getting enough voltage to open (and a good voltage output from the generator drops to nothing). It's not too hard of a diy
Sep 12, 2013 | Jandy Lite 2 Natural Gas Pilot Light...
Heater is corroding pilots at an alarming rate..........1 per week....is there a potential fix or is it time to replace
check for leak in heat exchange if ok then if water is under 70 degrees it will condense and rain down on the pilot generator
Jan 21, 2013 | Raypak 2100 Pool Heater Gas 266000 BTU'...
H200 heater wont Light
I have the same heater and have been struggling with it since we purchased our house 6 years ago. I am very familiar with the "tapping" method and just this year learned that I could jump the TH connections to consistently get it to light. Finally that too became unreliable as the heater would shut off shortly after I jumped it. I used a voltmeter to test the millivoltage coming from the pilot generator (assembly) and found that it was only around 300mv, whereas supposedly 500mv is required to open the gas valve. Before investing $70-$100 on a replacement pilot assembly I decided to take it apart and see if it needed cleaning. There was a bit of buildup on the thermocouple that I removed with 150 grit sandpaper. I re-installed the pilot assembly, lit it, and retested the mv. I was disappointed to see that the millivoltage was still only around 300, but as I watched it began to rise until it eventually reached 500. I then turned the thermostat on and adjusted it until it was higher than the temp of water and the heater instantly turned on. So far so good....
Jun 07, 2010 | Hayward 250kbtu Ng Pool Heater - Inground
Pilot wont stay lit when i release push down button on gas valve
Are you certain you are connecting the generator to the correct terminals? Is the pilot head partially blocked not allowing the flame to reach the generator even though the pilot is lit? Can you read the millivolts on the generator leads? Is the reading 400mV or higher? I assume it will be with a new generator but if it is not then the flame is not across the generator as it should be. If it is, be certain you are connecting the two leads properly and in the correct order. The generator has polarity so it needs to be connected to the valve properly. The tag up inside the heater should give you the correct locations for the white and red wires on the valve.
May 29, 2010 | Hayward 150000 BTU Millivolt Natural Gas...
The heater does absolutely nothing when you turn it on. Hit the switch and nothing happens. No noise from the pilot light, no flame, nothing. Its a Raypak Versa that's approximately 23 years old. Is it...
Unless there is water running out of the inside it is always repairable. You can start by pulling the burner tray and cleaning the unit and the burners. Also pull the wires and clean the leads and contacts. At 23 the heater is probally a milivolt run heater so a small drop in power can stop the heater from working. Often the problem will be the pilot generator or the gas valve. The generator should delevop 1/2 a volt to run the heater. This can be measured with a milivolt meter. You should get 500-700mv from the generator. If you get that and have no pilot you may need a gas valve and if not you probally need a new pilot generator and it would be best to replace the whole pilot assembly. If you live in Calif. or someplace that makes standing pilot obsolet you can probally find these parts on line through Ray-Pak.
But before starting check the filter to be sure it's clean. If you have had the pool for 23 years that goes without saying but I have to say it anyway.
After that you can use a jump wire and isolate each itim in the saftey circut (thermostat, high limits, presure switch...) just follow the wire when it leaves the gas valve and follow it to each item and jump across. If you find one of these itims to be the culpret it is just a simptom and their is probally another problem and the part just keeps the heater from working so as to keep it safe from that problem. Good luck and let me know what you find and we can go further if need be.
Mar 12, 2010 | Raypak Versa 130,000 Btu Above Ground...
Pilot will light but main burner will not light
if burner lights after jumping valve you have something wrong in thermostat loop. disconnect the 2 thermostat wires on gas valve and use multimeter on continuity setting. if all wires ,connectors and components are good,you will get a tone.since you have jumped out each component in thermostat loop with no success ,i would suspect a bad wire or oxidation on a terminal .
Sep 24, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot did not stay lit,replace gas valve , pilot stays lit,but now it won't fire up. Jumped the TH terminals and it shut off the pilot light.thermostat is set highier than the water temp.Jump all ths...
Your problem is the pilot generator where the flame is by the burners. This needs to be repalced. That is what is causing the pilot to go out and not start. It is a flame sensor and also tells the gas valve when to release more or less gas.
May 28, 2009 | Hayward H Series Pool & Spa Heater 400k...
Heating & Cooling Logo
105 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
