Question about Garden
Starts when its cold, shut it down and it will not restart
My blower will start when its cold, but after it runs for a few minutes and shut it off, you can hang it up, it will not start for anything. Got any ideas
    President:
  • 1,902 Answers
Carb needs to be cleaned. This is happening because you are flooding out the piston and the air mixture is not being aloud into the mixture to cause enough spark. Take some carb cleaner to it and make sure you let it sit in the carb and into the other orfices long enough to work this will solve your problem
Posted on May 27, 2009
Exmark lazer HP 19 Kawasaki 50" deck new PTO and new relays blades engage for 30 minutes then shut off engine on. After cooling will engage for 10 minutes then shut off
Engine valves need adjusting.
symptoms: starts ok, runs until engine reaches max temp loses power then stops. can't restart when hot. once restarted runs for a while stops again.
There is very little clerance in these valves and temperature alters the lenth by a few thou and the valve don't close fully losing compression, once cold the valves shrink back enough to create enough compression to start again.
Aug 13, 2015 | kawasaki Garden
Start snow blower runs for 3 min. and starts to over heat checked oil its ok then stats to shut down like its not geting oil
Why do you say its over heating .Runs for 3 minutes the oil is OK .
Do you understand how the choke works .
bacsicly you prime the mechine in cold condutions 3-4 pumps choke to max throttle at 3 /1/4 .
Start backing off the choke after 3-to4 mins .
The choke shuts the fresh flow down to the engine in cold condutions ware it needs more fuel then air to run.
When the engine starts to get hot it can't run with out fresh air to mix with the gas it won't run anymore because there is to much gas and not enough air
Its simple fool prof will work everytime if you adjust it right
Mar 01, 2015 | Craftsman Snow Blower / Snowblower Bottom...
I have a GE Profile dryer that stops 10-15 minutes into cycle. Seems to happen at almost the same amount of time in. It stops and Start/Pause light is flashing. If you hit button , starts for a few se
take a multi meter and check ffuse, thermistor, etc, etc behind the back of the dryer. Take the back off, you'll see a few little parts with wiring going to them. Take off one after another and use the multi meter in "ohms" mode to see which little part has "zero" ohms when you press the red and black points on each side of those little parts. If it has a reading of 4.6 or 7.9 or whatever, put it right back on and ncheck the next one. When you find one that shows 0.0 or 0.01 or next to nothing, zero, go buy that part and out it back on. It could be the timer fuse, the actual timer back there, the element, but you can check all those little things,like about 5 or 6 of them are back there total, with a multi meter. Then either go ton a supply house in your area or order it off amazon/ebay. Thats all you need to do at this point so far.
Jan 24, 2015 | General Electric Profile DPVH890EJWW 7.5...
Ac unit runs, inside blower shuts off after 2 mins, compressor continues to run, t-stat still calling for cool
My central AC unit decided to stop on the hottest day of the year. It would start and run normally for a few minutes and then the blower would shut off. After checking the breakers, thermostat and overflow shut off (did not have one) I saw something about a blower motor capacitor. This was easy to get to and replace and my last hope before waiting for someone to come fix it. The capacitor cost $4.04 with tax and had my AC working again. Needless to say I was beyond happy. I hope this can help others with a similar problem.
May 20, 2012 | Heating & Cooling
Starts and runs good when cold. run a few minutes, turn off does not start again for a few minutes. like simething is hot or resets.
it sounds like your coil is bad, when they are going bad they will work when they are cold but as soon as they start to heat up they shut down and quit sending spark so i would recomend starting with that, let me know
Dec 10, 2009 | 1994 Mazda 2WD B Series Pickup
Furnace runs OK, but blower runs again a few seconds later
Could be a defective thermostat in the plenum.
When a gas furnace shuts down the fan(blower) will run until the plenum cools to the safe range. Usually 1 and 1/2 minutes.
Intermittent operation is a defective thermostat or relay.
Mar 11, 2009 | Carrier Heating & Cooling
Car shuts off at red lights
sounds like a lose ground wire
Dec 15, 2008 | 2002 Oldsmobile Alero
Garden Logo
172 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
