Question about Cerwin Vega XL 600.1 Car Audio Amplifier
Protection light turn on with sound
When i connect the rca cables to the amp the protection light comes on whenever bass hits and it does it even when no speakers are connected
  • 631 Answers
It's likely that the amp is defective but you should check the shield ground of the RCA signal cables before sending the amp off for repair.
Disconnect the RCA cables from the amp.
With your multimeter set to ohms, measure the resistance from the outer shield of the RCA cable to chassis ground. If it's more than a few ohms, that could be causing your problem.
If this is higher than a few ohms, short the meter's leads together to make sure the meter will go down to 0 ohms.
To check the shield ground of the head unit (assuming that the head unit is driving the amp directly), disconnect the RCA cables from the head unit and measure the resistance from the RCA output shield to the case of the head unit. It should essentially read 0 ohms.
Posted on Oct 22, 2007
Acoustic b600h
Relay?? I've never seen a guitar or bass amp with "speaker protection relays"...usually they're either on or off. Check the simple stuff 1st...is speaker cable from head to cabinet and/or the input cable from bass to the amp good? Check the "Direct Out" for a line level signal (must be connected to a PA or other amplifier) as this is your preamp out signal. Also, plug a shielded cable from "Effects Send" to "Effects Return"...this will verify "effects" loop issues if any. Lastly, vibration test...use a clenched fist across the top, sides and bottom of wood cabinet to lightly "jar" the internal circuits. If it starts working even for an instant, I would suspect intermittent connection inside.
Jul 30, 2014 | Acoustic B600h 600W Bass Head And B115neo...
I have a 1400 watt cruch amp & i hooked it up myself. when i turn the radio on the power wire on the amp comes on, bt if the audio cords are hooked up, the protection light comes on. if i dnt hook the...
Should the amplifier go into protect mode, simply disconnect all RCA and speaker leads, while keeping +12 volt, power ground and remote leads connected.
1. Now turn the amplifier back on, and if the diagnostic LED lights, the amplifier has an internal fault.
2. If not, plug the RCA cables back, and reset the amplifier. If it goes into diagnostic now, the fault lies in the input, either with bad cables or source unit.
3. If the amplifier seems fine with RCA cables plugged in, connect the speakers, one at a time, and if one of the speakers or its wiring is faulty, it will activate the diagnostic
system.
Dec 08, 2010 | Mobile Authority A-500 Car Audio Amplifier
The red protect light is coming on
It is possible that your amp is going over the threshold limit of draining current to give out the protect signal. What could be done is to first checkout if your speakers are loading the amplifier, check the rating of the speakers and the impedance, must not be too low.below 2 ohms. Now check the source signal if this is bringing in any transcient signals to power out the outputs particularily high/low freq. So decrease off your bass and treble to mid position and test again. see if there is any improvement, if so there could be a filter problem with your set. Connect an external source and see if the amp powers better , in such case check for fault in cables, input lines and ground with in the set. Repeat this and check. Hope this helps you out. Good day
Jul 19, 2010 | Verge VGA285 Car Audio Amplifier
The saftey red light keeps coming on
It means that the subwoofer is blown. The red light is called the Protect light. Disconnect the speaker wire from the amp and then turn the amp on and see if the red light goes away. But if as soon as you hook the speaker wires back to the amp and the red light turns on that DEFINATELY means the sub is blown.
Apr 04, 2010 | Cadence TXA 1000D High Power Mono...
Protect
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty . Send to Rockford Fosgate for repair .A thumbs up would be greatly appreciated if this answer is helpful to you. protect-zb4bomd1rt4qms0dqd12kkt2-3-0.jpg
Jan 29, 2010 | Rockford Fosgate Power 1001BD Car Audio...
My infinity reference 7540a amp cuts in and out with heavy bass when the ''loud'' feature is on. I redid my ground, remote wire, shortened my power cable, and double checked all speaker connections. I dont...
sounds like ur gains are set to high and is going into protect mode
also what ive seen happen before is the speakers (if mounted in metal shelf or door and arnt bolted down correctly can flex under bass notes and flex the speaker that much the termanls short onto the metal and amp hits protect mode
(rare but worth a look if you think u have elimanted most other things Had a dude come to me when i was working in sydney with this problem )
also could be things like clipping protection , overheat protection ,amp drawing to much current from the alternator
do your lights dim when you hit the bass notes ?
get back to me and im sure we could solve this problem
Jan 22, 2010 | Infinity Reference 7541a Car Audio...
Protection light comes on
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Dou .A thumbs up would be greatly appreciated if this answer is helpful to you. protection-light-comes-lv2kkrmxrai4iihdvw4m3np2-2-0.jpg http://www.nitrobmw.com/
Jun 14, 2009 | Nitro BMW-482 Car Audio Amplifier
Unwanted bass coming out of my subs
there has to be sumthn hooked up wrong bc i have had same problem with my 12' subs but it was simply a matter of my rca jacks but sense you have checked them try rewiring the speakers if that does not work then your rca module may be burned out within the amp..iso then check the amp by taking the cover off and making sure nuthn is burned on the inside.or if any wires are loose or touching.
Feb 24, 2009 | Kenwood eXcelon KAC-X812D Car Audio...
No sound no protection light no obvious problem...
there is a wiring issue in your truck and i would get rid of the preamp
Dec 12, 2008 | Rockford Fosgate T10001 bd Car Audio...
Nitro 1000 w amp
unplug the speakers and the RCA leads from the amp, if the red protection light is still lit then its 1 of your linear amps blown or mosfet depending what your amp uses..if the red light does go off with the leads all disconnected, then connect 1 lead at a time and check the light,when you connect the bad lead or speaker then the light will come on and you know that 1 needs replacing..hope this helps
Jun 30, 2008 | Nitro BMW-481 Car Audio Amplifier
Cerwin Vega XL 600.1 Car Audio Amplifier Logo
135 people viewed this question
Top Cerwin Vega Car Audio & Video Experts
Frank de Armas
Level 1 Expert
Chris Larocque
Tygh Duval
Tygh Duval
Are you a Cerwin Vega Car Audio and Video Expert? Answer questions, earn points and help others
