Question about Toshiba Satellite A100-S8111TD Notebook
Engine 1998 Infiniti I30t diagram of engine
  • David Shaub May 11, 2010
    It isn't made by Toshiba.
Where is the fuel pump reset for 96 infiniti i30t?
Infinite doesn't have an inertia fuel pump cutoff switch (turns off fuel pump in a rear end collision > 3 G's), that is Mazda and Ford.
Oct 28, 2016 | Infiniti Cars & Trucks
How come my 2000 Infiniti i30t hesitates on acceleration? Could this be my o2 sensor
chec ignition first--change distributer/coil pact--or plug wires--probly worn tho u cant notice--------throttle body and idle air may be filthy-------fuel pump cud be failn---a sensor wud usually show engine lite--but a scan of vehicle using a factory tool can xplain system in detail
Jan 24, 2015 | Infiniti Cars & Trucks
My 1996 infiniti i30t is heating up and also blows out cold air from the heater
change your thermostat and gasket, radiator cap, and do a flush to our system
Oct 25, 2013 | Cars & Trucks
Infiniti i30t emission control system malfunction light steady on
Check for codes
One would assume you have done that
for the last 30 years
Google the codes & get an idea what system
has a malfunction
Then have a repair shop start all over & diagnose it properly
Feb 23, 2013 | Cars & Trucks
On my 1998 infiniti I30t the front end makes a whirring noise, when in motion,with any position of the steering wheel left of center. It does it in drive and in neutrul. i took of the drive shafts and they...
sounds like the power steering try this jack up the front end with engine off turn ignition key to the on position but not running turn the wheel back and forth to both stops a couple times start engine and see if whirring sound is gone
May 28, 2011 | Infiniti I35 Cars & Trucks
I have a 1998 infinity I30t, and I have problem
You may be sucking in air into your fuel system due to a crack line or hose.It's hard to find a suction problem because it does'nt leak .Look closely at the supply fuel lines.
Oct 23, 2009 | Infiniti I35 Cars & Trucks
I need to replace the xenon bulbs on my headlights it is busted, How do I do it? It is an infiniti I30t 2000
open the bonet, unlock the headlight cover latch remole the existing bulb thd replace with appropreate one.
Sep 22, 2009 | Infiniti J30 Cars & Trucks
1999 infiniti i30t oil leak appear to be coming from a gasket near the timing belt anyone out there with this problem?
cant tell you right where its coming from with out looking at it but pull out your spark plugs and if they are covered in oil it is your valve cover seal most common but if not it could be the head gasket sorry cant be more help good luck
Jul 10, 2009 | Infiniti I35 Cars & Trucks
Toshiba Satellite A100-S8111TD Notebook Logo
55 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
