Question about Microsoft Xbox 360 Elite Console
Fan does not turn on
My xbox 360 elite had three red rings, i fixed it, and now the fan turns on and cuts out straight away? is it something i've done? It's not the fan i've tried others?
    Scholar:
  • 133 Answers
That fan input could be malfunctioned. Look around to fix busted Xbox motherboards and replace the fan input/output. Also, see if your fans are hitting something.
For your fans to immediately stop, tells me it is the input/output
Posted on May 30, 2009
Xbox console three-quater red powerbutton,what can i do plse
This is called Red Ring of Death or RROD by the community, it means that the CPU or GPU or both have a bad solder joint, that is caused from rapid heating and cooling from poor cooling design of the xbox 360. To fix it is pretty simple. Follow these instructions to take apart your 360: http://www.rrodfix.com/how-to-take-apart-the-microsoft-xbox-360-game-console.html Stop once you've removed the dvd drive. Now Remove the fans from the back, and set them on the heatsink on the right the flat one, and make sure they are pointing where the air is going up. Put a peice of of carboard or plastic something non conductive in between the heatsinks to prevent airflow from the fans. Turn on the 360, and leave it til it goes from 3 rings to 2 rings, wait 3 minutes, then switch the fan over to the other side. Wait about as long as you did for the other one then turn off the 360. Wait 1 hour for the 360 to cool off. DO NOT move the 360 while it is cooling down durning this period or you will permantly ruin it, the solder is being reflowed. After an hour, put the fans back, and turn the 360 on, it should work. Once its working, I recommend doing a 12 volt mod on the fans to prevent RROD from happening again, and changing out the thermal paste with artic silver 5.
Oct 24, 2011 | Microsoft Xbox 360 Console
Three-quater red power button
My xbox always suddenlly shut down while im playing it will not reach 20 minutes its shuts down again.
If before it shutdowns it has 2 red light its a Overheating issue, if still under warrenty send it back to microsoft or... you can, open it up by following this guide: . http://www.rrodfix.com/how-to-take-apart-the-microsoft-xbox-360-game-console.html Stop once you've removed the dvd drive. Get a can of air, make sure its all aired out, and you hold the can horizontal don't tilt it, and short bursts. Once thats done. If you want to make sure it never overheats you can do whats called a 12v mod on the 360 it forces the fans to run at full speed. Now if you have a slim you just snip the grey wire. If its a older model you get the fans, and wire it up to a external 12v 1amp ac to dc adapter or solder it to this point :http://www.llamma.com/xbox360/mods/360-12V-fan-Mod.htm this link also shows what wires are postive and negative. And I would also suggest changing the thermal paste out for some better stuff like artic silver five. Now if you're getting Red Ring of Death which is 3 red lights you need to follow this guide :This is called Red Ring of Death or RROD by the community, it means that the CPU or GPU or both have a bad solder joint, that is caused from rapid heating and cooling from poor cooling design of the xbox 360. To fix it is pretty simple. Follow these instructions to take apart your 360: http://www.rrodfix.com/how-to-take-apart-the-microsoft-xbox-360-game-console.html Stop once you've removed the dvd drive. Now Remove the fans from the back, and set them on the heatsink on the right the flat one, and make sure they are pointing where the air is going up. Put a peice of of carboard or plastic something non conductive in between the heatsinks to prevent airflow from the fans. Turn on the 360, and leave it til it goes from 3 rings to 2 rings, wait 3 minutes, then switch the fan over to the other side. Wait about as long as you did for the other one then turn off the 360. Wait 1 hour for the 360 to cool off. DO NOT move the 360 while it is cooling down durning this period or you will permantly ruin it, the solder is being reflowed. After an hour, put the fans back, and turn the 360 on, it should work. Once its working, I recommend doing a 12 volt mod on the fans to prevent RROD from happening again, and changing out the thermal paste with artic silver 5.
Oct 23, 2011 | Microsoft Xbox 360 Console
Sometimes it opens and sometimes it dont , sometimes it plays discs and sometimes it dont turned it on and had the red rings of death turned it off then on and they were gone some times the fan dont start...
This is called Red Ring of Death or RROD by the community, it means that the CPU or GPU or both have a bad solder joint, that is caused from rapid heating and cooling from poor cooling design of the xbox 360. To fix it is pretty simple. Follow these instructions to take apart your 360: http://www.rrodfix.com/how-to-take-apart-the-microsoft-xbox-360-game-console.html Stop once you've removed the dvd drive. Now Remove the fans from the back, and set them on the heatsink on the right the flat one, and make sure they are pointing where the air is going up. Put a peice of of carboard or plastic something non conductive in between the heatsinks to prevent airflow from the fans. Turn on the 360, and leave it til it goes from 3 rings to 2 rings, wait 3 minutes, then switch the fan over to the other side. Wait about as long as you did for the other one then turn off the 360. Wait 1 hour for the 360 to cool off. DO NOT move the 360 while it is cooling down durning this period or you will permantly ruin it, the solder is being reflowed. After an hour, put the fans back, and turn the 360 on, it should work. Once its working, I recommend doing a 12 volt mod on the fans to prevent RROD from happening again, and changing out the thermal paste with artic silver 5. As for reading discs, open up the drive air it out, but not the laser, use a qtip and some rubbing alchol, clean it off and put it back together. Fans all you can do is replace them which I recommend just buying off of ebay or llamma.com
Sep 16, 2011 | Microsoft Xbox 360 Console
My xbox 360 fan turns on for 3 seconds then shuts off right away
for the red rings fix rap your xbox in two blankets turn on xbox wait till it shuts it self off wait for 35 min and you wount have any more problems i did that to mine over 2 years ago and i have not had any problems yet brian
Nov 10, 2010 | Microsoft Xbox 360 Console
2 and 3 red rings
The 2 red rings error is an overheat problem. Something you did when you attempted the previous repair has prevented the 360 from cooling properly. I suggest having a professional examine your machine.
Jan 21, 2010 | Microsoft Xbox 360™ Pro White Console
Scratched Xbox 360 motherboard
Usually if a motherboard has been scored or damaged.
( tracks or resistors/capacitors dislodged et,c )
The board is in the Bin. ( scrap ) unless the damage can be repaired. The RROD Or red-ring of death. Is usually due to the x-clamps fitted to the console initially, by the manufacturer.
Replacing the x-clamps, with a kit ( bolts/washers thermal Compound ) And 4 x heatpads recommended. Can cure the RROD. And in my own experience the 1 red light And E74 error.
Bottom line, if the boards scratched. it,s in the Bin.
Mike @ Compurepair.
May 29, 2009 | Microsoft Xbox 360 Console
Ive modded my xbox and now the fans dont work
Modding an Xbox 360 is illegal, and Microsoft is anal about it.
I would say you probably severed a connection somewhere wrong and fried your motherboard or corrupted your hard drive.
Apr 08, 2009 | Microsoft Xbox 360 Pro System Console
Xbox 360 won't work at all now
this sounds like your xbox is overheating. If you could try to run it in an area that has a lot of air that flows over the back. you could also plug in a usb fan on the back of the 360. note, if you continue to let the xbox overheat, this could lead to the rings of death which is three rings flashing. If that happens you have no hope. Hope this post helps.
Jan 11, 2009 | Microsoft Xbox 360 Console
360 Xbox problem Three red rings
3 Red lights problem is one of the most common problem of Xbox 360. You will have to either get it repaired from Microsoft (in case your Xbox's warranty is not expired, but one thing to note is that you will have to wait for at least 3-4 weeks to get back your Xbox) or you can Fix your Xbox's 3 Flashing red lights problem yourself with the help of DIY Video guide available on Internet. You can fix yourself without any technical knowledge.
Nov 15, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Elite Console Logo
326 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
