Question about GN Netcom GN 9120 Professional Headset
No sink? I can not get my headset GN netcom 9120 to sink-up with the base GN1000 RHL, anyone have a solution
    Problem Solver:
  • 4 Answers
Yap i did solve the issue, thanks
Posted on May 28, 2009
Is a replacement battery available for 9120 I've used for a number of years?
GN Netcom probably would know. If you can identify the battery type, you can try obtaining a replacement from some other source.
Jul 07, 2014 | GN Netcom GN 9120 Professional Headset
The handset will lift when I press the mfb but I get no volume or mic from the headset. It does not seem to be communicating with the phone. Tried unplugging the power, but that didn't solve it. We...
Your solution will depend on what type of phone and headset you have. I have a Polycom 501 IP phone with a headset jack and a GN Netcom 9125. I'm not using the lifter right now, but I seem to recall that an easy way to make it work was to plug the curly cord of the phone's handset into the bottom of the base unit, so that the cord went from the base of the headset to the headset jack on the base of the phone.
Jul 11, 2011 | GN Netcom GN 1000 RHL Wireless Headset
I have lost the power adapter for the charge base. How many volts is the power cord? This is a GN netcom 9020
I have a 9120 headset and the mains adapter has the following spec if it's any help
input 230v 50 Hz 70 mA
output Dc 7.5v 700mA
I have found the manufacturer very helpful in the past and they would be able to supply an adapter
Feb 16, 2011 | GN Netcom 9020 Consumer Headset
Hi
this has not synch up keep headset in cradle and remove power at mains plug or power lead from base count to 5 and replace power if no flashing is seen then you might have to repeat the same procedure a few times for synch to happen
the only other reason for no synch is battery in headset is not charged enough
Steve
Aug 08, 2009 | GN Netcom GN 9120 Professional Headset
GN 1000 lifter/GN9350 headset with Nortel NTDU92 phone
I was wondering if you had installed the external ring sensor, this sensor most be over the telephones speaker, if the speaker isn't under the handset. hope this can help.
Feb 19, 2009 | GN Netcom GN 9120 Professional Headset
Battery Light Won't Go Solid. Lot's of clicking sounds and lights flashing (GN Netcom 9120).
It sounds like it may be a defective unit in that the charging points on the base and the earpiece are making intermittant contact, hence the clicking noise you get when the unit goes into headset mode and the fact that the battery never reaches a fully charged status.
A couple of things to try:
  • Check the charging points/contacts on the base and the earpiece for damage.
  • If they look ok, gently clean them with some spirits and try again.
Nov 07, 2008 | GN Netcom GN 9120 Professional Headset
Pairing
No... But you can connect the headset to the base, unplug the base for about 20 seconds, re-plug the base and it should sync together.
Jun 13, 2008 | GN Netcom GN 9120 Professional Headset
GN Netcom GN 9120 - can't hear
Hi There, I had the same problem with a headset one of our call centre reps were using. It's usually due to some one fiddling with the button. I got it working by removing the battery from the headset then resinked the headset to the base unit. Hope it works for you
Jan 30, 2008 | GN Netcom GN 9120 Professional Headset
GN Netcom GN 9120 Professional Headset Logo
723 people viewed this question
Top GN Netcom Radio Communications Experts
TO Lady
bigdawg7299
Tom Chichester
Are you a GN Netcom Radio Communication Expert? Answer questions, earn points and help others
