Question about Acer TravelMate 5520 Notebook
The computer has been shut down and after a few hours it boots itself up on its own. I've been finding it turned on in the morning. Just started doing this. The computer is about 8 months old and is l
  • jcoady
    jcoady May 11, 2010
    Is this computer on a network?
    If so, are there any hosts or devices that could be issuing a remote "Wake On LAN" command?
    In case you are unfamiliar, WIKI defines this as, "
    Wake on LAN (WOL, sometimes WoL) is an Ethernet computer networking standard that allows a computer to be turned on or woken up remotely by a network message sent usually by a simple program executed on another computer on the network.
    (If you are using unsecured wireless, could a prankster neighbor be messing with you?)
  • 674 Answers
Check you program maybe some program install in you laptop. programs for adware and spyware or virus. maybe there are a lot of hiden file and auto run program..
you do this also to check the hiden file. open may computer then tools, folder options.view check then box. SHOW HIDEN FILES AND FOLDERS. THEN OK..
SOME HIDEN FILE YOU WELL SEE THEN REMOVE IT. IF CANNOT REMOVE USE ANOTHER TO REMOVE. OR REMOVER PROGRAMS. IF YOU DONT FINE REMOVER PROGRAM REFORMAT YOU LAPTOP. BUT B CAREFULL SAVE FIRST YOUR DATA IN DRIVE D. IF THE OPERATING SYSTEM IN DRIVE C:/. DESADVANTAGE... ALL PROGRAMS INSTALLED WILL BE REMOVE.. IF YOU HAVE BACK UP FOR THIS PROGRAM JUST INSTALL AGAIN
THANKS
Posted on May 27, 2009
System worked for 2 hours then shut off came back on a few times
It shuts down to protect itself from overheating, looks like you tried to use it too much without sorting the problem out.
You can try and give it a good clean out. Google cleaning computers.
I usually use a small brush, my vaccum cleaner and sometimes an air duster
Jul 26, 2010 | Spherex Xbox 5.1 Surround Sound System...
My laptop turned off but it has 35% remaining battery
Laptop turns off suddenly? Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage.
If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed.
Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot.
The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated laptop is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down.
Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning.
May 29, 2010 | Computers & Internet
Turns off suddenly
Mar 27, 2010 | Toshiba Satellite M55-S331 Notebook
Dell Dimension 2350. After I shut it down and try
Check that the computer is not hibernating rather than shutting down. It will be in the power settings.
Mar 06, 2010 | Dell Dimension 4600 PC Desktop
The computer will just randomly do a windows shutdown and then restart. Cleaned, changed the power supply and still does it.
Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage. If the smart person keeps turning the computer back on and figures out a way to foil the protection, the unit is probably doomed. Once a unit shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot. The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated unit is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down. Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning. Check the CPU fan if it is spinning and also the CPU itself put thermal paste. So that the heat from CPU will absorbed by the heat sink.
Jan 19, 2010 | Dell Dimension 2400 PC Desktop
When I boot up the screen is all colors and lines
It sounds to me like your cable is loose to the lcd or the video card is not properly 100 percent seeded into the mother board. Prolly the cable in one way or the other, perhaps bad cable.
Nov 21, 2008 | Toshiba Satellite A215-S7422 Notebook
HP Pavilion a 1600n Starts by Itself
My DVD drive on my Hp 1600n pc does not work all the time I tried the cleaner with brushes that did not fix the problem what else can I try Thanks
Sep 09, 2008 | Computers & Internet
Compaq notebook won't boot up
Hi
When you boot the computer back up go into Safe Mode and check to see if you can roll the computer back to the point before you installed the software.
If so this should work. If it works then run a virus scan, a defrag of the hard drive and cleans the temp files.
OR
You can do a diagnostic startup and uninstall Onecare. So once that it is uninstall ed it should be smooth sailing.
Here is a link for some startup / diagnostic software you could try after booting.
I hope this helps
/Shawn
May 19, 2008 | HP Compaq Presario V2000 Notebook
Aspire 3610 fails to run for more than a few minutes
does the laptop get very hot ? Aspire know to over heat.
You also might want to reinstall OS.
May 08, 2008 | Acer Aspire 3610 Notebook
Mac G4 Laptop wont boot up
This can often be fixed using a tool like Disk Warrior, but you will have to have another Mac to make the repair. See if you can boot into Firewire target mode (by holding down the T key while starting up the computer. You will get a big Firewire icon on the screen if this work. If you can do this, then you can attach the computer to another Mac using a firewire cable and use disk utilities to check out your disk and attempt to repair it. My experience is that Apple's disk repair will rarely fix this, but Disk Warrior almost always will.
May 16, 2007 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Acer TravelMate 5520 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
