Question about Dryers
My dryer heats up, but the clothes dont get dry w/o 3 full cycles
You can see the heating elements glow orange when you open the door, but, for some reason, the clothes wont dry. I'm talking a small load of whites in for 100 minutes, and still damp.
  • 10,865 Answers
Hello. sorry for your trouble, let me help you. Let me begin by saying that the most common cause for what you describe is lint partially blocking the exhaust, either in the pipe, outside where the pipe exhausts, or when you remove the pipe from the back of the dryer, in that hole.
that being said, here is a detailed explanation of all of the possible causes
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Posted on May 27, 2009
  • Dryers Master
  • 3,361 Answers
Remove the exhaust vent from the rear of the dryer. Run a timed load at 45 minutes. If it dries correctly clean your connecting vent your wall vent and the lint from inside the machine.
Sears dryer back left vent has an orange glow form heating element is this normal bought in May of 2012
Yes, this is normal for the element to glow orange like this. It's getting full 240 volts and good heating.
Dec 01, 2012 | Dryers
Having heating problem with Roper REX4634JQ0 dryer?
probably have a weak hi-limit thermostat on the element housing or cycling thermostat on the blower housing
Apr 26, 2012 | Roper Dryers
My GE Dryer is not drying my clothes completely on the first cycle but when I feel inside the dryer it feels hot? Do you have an idea of what could be the issue Model# DJXR433EG1WW
If your dryer still heats, but your clothes take longer than usual to dry, you may want to check the dryer interior cabinet and/or the entire run of the exhaust ducting from where it exits your dryer to the point where it leaves your home to ensure you have no kinks, clogs, or excessive bends. The following link explains many of the common problems that can cause poor drying efficiency and longer dry times:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. This is the NUMBER ONE cause of poor drying efficiency. A dryer that is clogged, or has restricted air flow, will not dry efficiently and will cause the heating circuits to OVERHEAT. This will eventually will lead to component failures and is the source of many fire hazards.
Exhaust ducting that runs to the attic is usually the worst configuration, because the air has to be forced up. The blower fan will meet more resistance and any lint that does not exhaust completely, ends up stuck in the vent. Water appearing in the drum is another sign that you have a clog somewhere causing condensation to develop. FYI: There are no adjustments that can be made to any of the internal thermostats or heating element to make it run at a higher temperature. All these components have a fixed setting. If the dryer still produces heat, this is generally a sign that the heating element IS working. If the dryer is clogged, however, the internal protection devices, such as the Hi-Limit Thermostat and Internal Bias Thermostat will shut the heating element off prematurely to prevent the dryer from overheating, and to prevent damage to the heating element. Eventually, the Thermal Cut-Out (TCO) or Thermal Fuse will trip and the dryer will not run.or produce heat. If you have any questions, please post back and let me know. I hope you find this information helpful.
May 19, 2011 | GE DBXR463EDWW Electric Dryer
I a have a kenmore 417 dryer that is not heating I followed the steps
Check to see if the electrical coils are glowing or not...... they are located right behind the cloths drum. (sounds as though they are NOT heating up) In order to see these coils...... first, remove all the cloths from the drum. second, while the dryers door is open 7 the drum is empty look all the way to the rear or the metal drum, it has a flat back in which you will notice there are quite a few holes. During the next step you will want to watch these holes as we check to see if the heating coils are lighting up (they will glow like the heating element in your oven... or burners on your stove top as they get hot.... ORANGE IN COLOR IS WHAT YOU WANT TO SEE) Now.... with the dryer drum empty & the door OPEN..... you will find a small pushbutton located somewhere around the outide of the drum opening thats activated (pushed in when you cose the door), depress this little button and hold it IN (this is tricking the dryer into thinking the door is closed... but its not, your holding the button NOT the door.... luckly the dryer isn't smart enough to know this) You must continue to hold the button in till the test is over.... if you let go it will IMMEDIATELLY STOP the dryer! Now, push the start button located on the console like you normally would do so during normal operation (it is recommended that the temperature be set to the HIGHEST SETTING during this test). As the dryer starts and the drum turns.... watch those holes located in the back of the drum! It takes a minute for the coils to get hot enough to glow so give it a few minutes before giving up..... after 3 minutes an ORANGE GLOW should appear through those little holes. The glow you see is the coils getting hot like the element in your oven. If after 3 minutes..... NO ORANGE GLOW can be seen through any of these holes..... the heating element needs to be replaced (this is a common problem & is usually inexpensive to replace..... $15 - $20) Replacement heating elements are available at most appliance stores..... remember to write down the manufacturers name, the dryers model number, and serial # prior to going to the store for a replacement. You MUST provide this information to the dealer for proper replacement parts! Once you've got the new heating element (it will look similar to a really long spring) you'll be Up & Running in No time!!!!) Just follow the instructions which are usually provided by the manfacturer to properly replace the broken element! Hope this helps...... GOOD LUCK!!!!!
May 15, 2011 | Kenmore Dryers
Dryer does not dry all the time sometimes it dry fast other time you have to reset 2-3 times
You can put this machine into the field service mode to view the errors here is how to do that.
  • Turn the dryer on.
  • Go to the home screen.
  • Press help.
  • Press and hold my cycles and back simultaneously for 3 seconds.
Once done you can view the errors, post what it says. Note that once you exit this mode it will erase the errors so write them down.
Feb 28, 2011 | GE Profile Harmony DPGT750EC Electric...
Dryer taking to long to dry
Overloading
1. One of the simplest problems to remedy could simply be that you are putting too many items inside the machine during the drying cycle. Avoid overloading your dryer, as this might cause your dryer to work extra hard to dry your clothing, extending the length of the dry cycle.
Wrong Heat Setting
2. A common issue with clothes dryers could be the wrong heat setting. Most home dryers feature several settings, from low heat settings to high heat and permanent press. Be sure the setting you choose is right for your needs. Another setting to check is the load size of your dryer. If you are drying a large amount of clothes, be sure the setting for large loads on high heat is selected. Choosing the wrong heat setting or load size can cause your clothes and linens to take longer to dry.
Lint Trap
3. One of the simplest fixes for drying issues might just be that your lint trap is clogged. Each time you use your dryer, lint will form in the trap. If the lint trap and vents are full, this could block air going into your dryer and slow down if not completely stop the drying process. After you use your dryer, remove this lint trap and empty it fully. Even if the lint trap is full, your other dryer vents might be clogged as well.
Clogged Vents
4. If your clothes are in the dryer for a long amount of time, but still not drying, the reason for this could be a clogged vent. A sign that your vent is clogged is if your clothes are warm or hot to the touch after sitting in the dryer, but still damp. To unclog your dryer vent, you may need professional assistance. This is especially necessary if your dryer vent leading out of the house is particularly long.
Heat Source
5. If the dryer is not getting enough heat to dry your clothes,something could be wrong with the heating system. After the drying cycle, touch your clothes to see if they are warm. If not, this means that the heating mechanism is malfunctioning. It will need to be repaired or replaced by a professional.
Feb 28, 2011 | GE Profile Harmony DPGT750GC Gas Dryer
No heat
Most likely you have a burnt element....A good handy man could replace the element fairly easily.. Cost of a new element about $50-$75
Apr 20, 2010 | GE DVLR223 Dryers
Amana les60aw gets hot in dryer but clothes wont dry. cleaned out vent, shortend exhaust hose. noticed an orange glow coming from back vents when i turned it back on???
The orange glow is the heating element working. It mush have good air flow or the coil will burn out and stop heating. Also the thermal limit will stop the heat if to great. If you went all through the vent and the tubing is not smashed or flat check the outside vent for air circulation, if good try to dry a load of clothes. Are you sure your washer is spinning out well? Wet clothes take longer to dry.
Oct 20, 2009 | Dryers
My Electric Dryer's Heating Element Glows orange while in use
Hi. this is quite normal when you dry heavy items. the dryer has sensors inside the compartment that will sense cotton and wool garment. if needed, the thermal regulator will adjust the element to the appropriate range. If there is a problem, the electronic thermal fuse will blow. this is the safety feature that will trigger itself if a fire or over heating is sensed. Also, if your selector knob is set to a cotton or high heat mode, the element will normally glow intensively during this cycle.
Please rate and god bless.
Mar 19, 2009 | Whirlpool Dryers
Whirlpool dryer - element heats, then shuts off quickly
Sounds like you have a stopped up vent on your home, when the vent gets stopped up the dryer can't circulate the air properly in the dryer and causes it to get to hot which causes the high limit thermostat to kill power to the element. If you need more help with this visit the link below:
Appliance Repair Guides
Mar 18, 2017 | Whirlpool Dryers
Dryers Logo
452 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
