Question about Intermatic & Indoor/Outdoor Rain Tight Timer
Wiring intermatic pool timer
T104P/CD104 Intermatic 5 terminals, 2 pole
I have one red wire I didnt label and cant figure out where it goes. HELP!
5 terminals 5 colors blue-nothing, green-ground, white in terminal 1 & 3,
black in terminal 3, red in terminal 1 & 4, third red wire is lost with no home. I know this is a long shot but I cant get a pool guy out for a week.
  • pnunez7 May 27, 2009
    Charlie
    The red wire is comming from the line source.
    Patti
  • Samuel Charles Spriggs May 11, 2010
    Need more info. The red wire you can't position: where does it "come from or go to"?
    Is it from source (line) or to pump (load)?
    Meanwhile, need to look for the labels: "Line" and "Load" on the timer connections. There should be two of each -- there should be a diagram on the inside of the door.
    Once you get me the additional info, I can help you hook it up.
    Charlie
3 Suggested Answers
john224
  • 1378 Answers
SOURCE: Bought an Intermatic T104 Timer for a 120v pool
T104 series intermatic timers are 208/230/277 volt clocks, not 120. I believe you have the wrong model and need a T101 series instead.
Posted on Jun 13, 2009
  • 366 Answers
SOURCE: clock does not turn on
make sure the small white wires coming from the clock itself are installed on the "line" side of the terminals, those power the clock. If not, the switch will power the pump but the clock will not run.
Posted on Sep 15, 2009
Pool pump breaker tripping
1) Not likely the timer is problem, unless there was fire or overheating in timer box. Use nose and eyes to inspect for signs of high heat.
2) Eliminate timer as suspect:
Move wires on timer to test if timer relays have gone bad.
Move terminal 4 to terminal 3
Move terminal 2 to terminal 1
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T104
3) Check watt rating of Hayward pump, and voltage.
1Hp motor at 240Volt draws 8 amp, and can draw 6 to 8 times that amount when starting. Up to 100 feet, should be at least 12 gauge wire and double-pole 20 amp breaker. Over 100 feet, 10 gauge wire and 30 amp double-pole breaker is best.
http://waterheatertimer.org/Color-codewire.html#motor
4) Intermatic T104 240V timer is rated 40 amps
Can safely handle 1 Hp motor without nearing heat-rating capacity of timer
5) Make sure the motor is wired correctly for 240Volts.
If motor is wired for 120, and 240 is applied, then tripped breaker can result.
Apr 14, 2013 | Intermatic 220v T104p Swimming Pool Pump...
I want to replace a Paragon 4004 20M with a Intermatic T104M. The Paragon has 4 screws along the bottom and one more on each side higher up for a total of six. The Intermatic has six, plus the ground. ...
1) These timers are interchangeable.
2) These timers can be complicated. Both handle multiple voltages and can be wired many ways depending on load requirement, wire from breaker box.
3) Description of Load(s), voltage(s) and wiring is not described in question. Add a comment with specific information for detailed help.
4) The 4004-20 timer has wiring terminals 1 2 3 4, plus terminals 5 and 6 that are connected with a brass bridge to terminals 1 and 4.
Since the terminals are connected with brass bridge, terminals 5 and 6 can be considered same as terminals 1 and 2.
If the brass bridge is removed, then the timer can be wired many ways to control multiple voltages, and then terminals 5 and 6 are independent.
5) Intermatic T104 timer has terminals A 1 2 3 4
Intermatic T104 terminal A is not used except as a bare post for Neutral wire, and if timer is wired to control 277V or 440Volts. Or if timer is adapted in other manner.
6) When controlling ordinary 2-wire 240Volt load like a pool pump, here is crossover wiring.
Paragon terminal 1and5-bridged goes to Intermatic terminal 1
Paragon terminal 2 goes to Intermatic terminal 2
Paragon terminal 3 goes to Intermatic terminal 4
Paragon terminal 4and6-bridged goes to Intermatic terminal 3
Intermatic terminal A is not used in this case.
Sep 13, 2011 | Intermatic T104M 208-277Volt 40-amp Timer...
Timer not working on 4000 series, think its 4014 single pole single switch for pool pump. pump turns on when manually turn switch on but timer does not move. I feel the normal resistance and can move the...
1) If circuit breaker is not tripped or shorted, then timer clock motor has probably gone bad.
2) Some places still sell paragon timers, depending on model number.
But model number given is for 240Volt timer.
3) The clock motor is not available that I can find.
Paragon is no longer making the 4000 series timers or parts
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
4) Model number given does not match wiring terminals shown in manual.
4014 is DPST 240Volt timer with 4 wiring terminals labeled 1 2 3 4.
http://waterheatertimer.org/pdf/Paragon-4000-series.pdf
5) Paragon 4000 series timer with terminals 1 2 3 is 120Volt timer.
6) Replace 120Volt timer with Intermatic T101 indoor timer or T101R outdoor timer.
Crossover wiring:
Paragon terminal 1 goes to Intermatic terminal 1
Paragon terminals 3 goes to Intermatic terminal A
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
7) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 29, 2011 | Paragon 4001-00 24-hr Timer Control 120v...
I had an intermatic 220 timer that died. I am trying ti reconect my wires to a replacement timer from GE. The GE is the 208-277 VAC. On the intermatic there was two red wires connected to the second...
Necessary for you to match up terminal numbering with actual numbers for each timer.
Information below is for 240volt timer controlling one single 240Volt load.
GE15601 has terminals L 1 X 2 from left to right
Intermatic T104 Has terminals A 1 2 3 4 from left to right
Here's the crossover from 240Volt T104 Intermatic to 240Volt GE 15601 for single-240Volt-load
Intermatic terminal 1 connects to GE terminal L
Intermatic terminal 2 connects to GE terminal 2
Intermatic terminal 3 connects to GE terminal 1
Intermatic terminal 4 connects to GE terminal X
Intermatic terminal A is not used in typical 2-wire 240volt circuit.
More links:
http://waterheatertimer.org/GE-timers-and-manuals.html#15601
http://waterheatertimer.org/images/GE-15307-wiring-250.jpg
http://waterheatertimer.org/images/T-104-control-240V-Load4-35.jpg
Jul 30, 2011 | RTO Intermatic T106M Timer Mechanism Only...
I have 2 intermatic T104M timers...one for my pool filterand the other for my pool cleaner. I am replacing the timer for the pool cleaner and when I was connecting a red wire to the first terminal, the...
You might have to add a comment to help sort this out.
USUALLY but not always, if your red wire is connecting to terminal 3 on one timer, then it also connects to terminal 3 on other timer BUT these timers can be wired many different ways.
I have T104 timer on my desk and know the terminal numbers and wiring but I can't see your wiring.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Always take a photo of wiring before starting the replacement process.
Timers should not have both solid and stranded wire connected to same terminal because screw plate will tighten down on solid copper wire, but stranded wire will be loose.
Also make sure that no part of insulation on wires is under the screw plate.
Open following link for T104 wiring help:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#T100
Apr 30, 2011 | Intermatic T104M 208-277Volt 40-amp Timer...
I have a T104 timer that runs my pool pump. I also have a switch that lets me turn on the pump from my house. The switch is wired to the timer. I switched out the T104 with the same and I think I messed up...
The instructions are available from Intermatic if you click on the below link.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t104%20-%20english.ashx
240 volts will have two 120 volt lines and a ground(green or bare) or neutral (white) wire.
If your system is 240 volts the Red and Black wires are hot should be individually connected, one to terminal 1 and the second color to terminal 3. The load or pump in your case should be connected to terminal 2 and 4. If you want to wire a switch to the load you need to decide on how you want the switch act, 1) as an auxiliary on 2) as an emergency off. If you want an auxiliary on for the pump, you need a DPDT (Double Pole Double Throw) 40amp switch (what should be in the house). Run the appreciate gage of wire (AWG 8 for 40A) from terminal 1 to one pole of the switch and a wire from terminal 3 to the second pole of your switch. Next run wires from the switch contacts from the two remaining switch terminals to terminals 2 and 4 on the timer matching the Red side on the switch to and Red on the timer and Black side on the switch to Black on the timer. The timer will control the function of the pump, and the switch will turn the pump on when the timer is off. If you only have two hot wires coming from the house attach them to terminal 2 and 4. If you want an emergency stop you need to wire a second DPDT 40amp switch and disconnect the load wires from terminal 2 and 4 and connect each one to the opposite poles of the switch. Using the correct gage of wire you need to connect a red and black wire to the two separate terminals of the switch. When the switch is off the pump will not work but the timer will keep the current time. The color of wires may not be the same in that situation you will need a multi meter to identify the wires.
I need a little more information on the pool sweep timer. Are you using the same timer or just the power? Is the power 120 or 240 volts? When do you want the pool sweep to be active?
Mar 21, 2011 | Intermatic Timer Pool/Spa 125 Amps Control...
I have an Intermatic T103 DPST timer installed now (120v). The clock mechanism has failed. I bought Tork 1103 guts to replace it. The wiring is a bit different. Can u map for me which wires go to which...
T-103 has 120V clock motor with 5 terminals A 1 2 3 4
Tork 1101 has 120V clock motor with 4 terminals L 1 X 2
T103 is DPST and can control one-or-two 120Volt loads, or one-or-two 240Volt loads.
Tork 1101 is SPST can control one 120Volt load
Common ground between these timers one 120 Volt load
Changeover for one 120 Volt load:
White wires T103 terminal A go to Tork terminal X
Black wire T103 terminal 1 goes Tork terminals L and 1 (there is brass connector plate that connects L and 1 - if connector is missing, jumper between L and 1)
Black wire on T103 terminal 2 goes Tork terminal 2
If Load requirement is greater than T1101, Grainger sells T103 clock motor for $16
http://www.grainger.com/Grainger/INTERMATIC-Time-Clock-Motor-1PNK1?Pid=search
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
How to wire T103
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T103
T1101 wiring manual
http://waterheatertimer.org/pdf/110111021103WIRING.pdf
Dec 02, 2010 | Intermatic T103 Indoor 120-Volt 40-amp...
Timer stopped running so I replace timer motor. However the timer still does not run. I can still turn pool pump on manually. Will I have to replace entire unit?
T103 clock motor is 125 volt WG1570
1) If you bought the 240V WG1573, the clock will not operate
2) If you connected the motor wires to wrong terminals, then clock will not operate.
3) If original box label says T103, but 240V T104 was installed in same box, and you bought wrong voltage motor
4) Test for 120Volts across terminals A and 1, and make sure clock motor matches voltage of timer, and clock motor wires are connected to terminals A and 1.
Open following links:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#103
Jun 26, 2010 | Intermatic T103 Indoor 120-Volt 40-amp...
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
1,163 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Hippy_dd
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
