Question about Kenmore 22422 Top Load Washer
But will start with hot.kenmore 70 wont start with the cold water
Washer stopped working in the cold cycle, swiched to hot andit will wash,but wont rinse.
  • sinclairserv May 28, 2009
    the reason i swiched to the hot water was because i heard a hum,but no hum with the cold will try inlet mixer valve.thanks for your help.
    President:
  • 1,136 Answers
Hi, First thing you want to do is start the cold sysle and listen for a faint hum. If there is a hum,turn supply valve off and remove fill hose.
Look inside the valve on the washer and see if something is plugging the screen. If the screen is plugged flush it out (do not remove the screen.
If the screen is not plugged, and there was no hum when washer was trying to fill with cold water, you will need to change the inlet mixer valve.
Please let me know if this has helped or if I can assisst you further.
Thanks
Vic
Posted on May 27, 2009
Kenmore 70 series washer
If you can see a constant water pressure from the hot and cold, chances are the water solenoid valves are ok.
I would look towards resetting to factory and checking the main control unit.
May 11, 2014 | Washing Machines
I have a top loading Kenmore Washing Machine. I don´t have the excat model but looks like a KENMORE HEAVY DUTY SERIES 70 AUTOMATIC WASHER, MODEL # 110.92273100. The problem presents after finishing...
You may have 2 defective parts.
First,make sure the hot and cold water hoses are connected correctly and both turned on.
If the water fill problem is the same,the water temp switch is bad.
The not filling after the wash cycle could be a bad lid switch.
Set the machine for SPIN and turn it on.
If it does not spin,replace the lid switch.
Sep 20, 2010 | Kenmore 24042 Top Load Washer
Kenmore stackable washer wont work on Cold cycle only hot water
Here are a couple of tips that I wrote to help people that are having problems with the washing machine not filling...
Washing Machine2_bing.gif Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
Washing Machine Fix Washing Machine No Water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
May 07, 2010 | Kenmore 98702 Stacked Washer/Dryer
My Kenmore 26962 Washer will start its cycle once
check you lid switch
most machines will not go into the cycle
if that switch is bad
some models have a tab on the lid that dresses this swich when you close the door
but with out the proper model number i cannot help you more sorry
Oct 09, 2009 | Washing Machines
Hot water just trickles in both of my Kenmore top loader washers
Try reversing hot for cold hoses and see what happens. That will test your valves, hot water pressure, etc. As far as I know, the valve screens are right where the hoses hook up.
Apr 30, 2009 | Kenmore 22422 Top Load Washer
Won't complete cycle, stops at rinse. and can't get hot water.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
the machine probably has a cold only final rinse so it won't work properly.
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
My kenmore 70 series wont stop filling with cold water. the hot water stops filling.
you need to replace the water inlet valve on back of washer as the cold water side is not opening,it's easy,remove the 2 top head screws,flip the head up,use a screw driver to pop the 2 clips out(1 on each side top),unplug the wire jack,now pull the back,back so you can get to the valve-mike
Mar 21, 2009 | Kenmore Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Kenmore 70 Series will not load hot water
It sounds like need to make some voltage checks on this job. When you set the fill cycle to hot & start the machine do you hear the valve buzz? If you do then the valve is causing the problem.
Feb 06, 2009 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
