Question about FastMac (APP-5693) for PowerBook G4 Titanium Burner
PowerBook G4 discs won't get snatched in discs just float freely
Help! I insert  a cd or dvd in the slot.... makes a weird sound  twice... then spits it out. Is the cd / dvd burner player toasted? Can I fix it or should I just get an external burner player drive? Thanks, DB PowerBook G4 -all discs float in optical slot where they  used to get "sucked in" and then read  by hard drive   -did some of the reboots and "type in" OS commands -did not install or uninstall anything new -no existing disc in slot
  • 2 more comments
  • ksbdesign May 27, 2009
    under about this mac - disc burner-  it says No burning device was found.
    ksbdesign     under about this mac - disc burner-  it says No burning device was found
    yeah, I guess I'll take the ol' girl to a pro...
    first problem ever with this machine in 6 years
    of abuse. Had to hear it from somebody
    who knows their S**T. Thanks again.
  • ikkenom May 11, 2010
    Replacing a CD-reader inside any "laptop/notebook" computer should only be done by certified technicians, not by "amateurs".
    If you cannot "diagnose" the problem, take it to an authorized Apple dealer, to analyze the problem.
    Scholar:
  • 152 Answers
Yes, it sounds like the disk transport mechanism is shot.  You can try www.macsales.com for a replacement internal, but those are usually a) pricey and b) a REAL pain to install (LOTS of small parts and such) - www.ifixit.com has real nice tear-down guides for just this purpose.  Or, for lots cheaper, you could just use an external drive.  Good chance to upgrade to a faster drive/one with more features.  Go for a bus-powered one to cut down on the extra cords.
Posted on May 27, 2009
Powerbook G4 is not working When I put a CD in 2C the computer spits it back out without reading
You need to replace the optical drive. Go to web site of Other World Computing and order a CD/DVD super drive which will burn/play discs and even burn on dual layer discs. Cost about $80 US plus your free labor to install the thing.
Mar 08, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Reboot powerbook g4 17 inch without password
Use the install discs that came with the machine. Insert the disc 1, shut down the machine, turn it back on and press and hold the option key until the DVD icon shows. Then click on the icon and then click on the right arrow. When the disc boots you need to go to the top and find the disc utility folder. Then select reset password. Then choose restart.
Mar 07, 2010 | Apple PowerBook G4 Mac Notebook
Cant install so 10.2 onto powerbook g4.
Remove both RAM chips and re-insert, because sometimes they come loose. Now give it a shot old chap. Also, your RAM chips may have died, so insert new ones and give it a shot.
Don't install Panther 10.2, because that operating system (OS) is too old. The PowerBook runs best with the Tiger 10.4 OS. You need to install a retail version disc with black label instead of a gray label disc, because those discs are computer specific to certain models only.
Cheers
Jan 24, 2010 | Apple PowerBook G4 Mac Notebook
My dvd rom on my mac g4 powerbook won't read my disks, I insert it then it spits it back out.
Try different DVDs and then try different CDs. If it spits out all of them, then its time for a new optical drive.
Jan 22, 2010 | FastMac (APP-5693) for PowerBook G4...
When i insert a cd or dvd into mu MAC powerbook
Check to see if your discs are dirty. Clean them and try again. Also, check to see if you got heavy scratches on the discs. Also, click on the blue apple logo at the top of the screen, then click on about this mac,then click on more info. Under the hardware click on the disc burning title. Look at CD write and DVD write info to see what the burner will play. If no info is there, then your optical drive is disconnected from the logic board or your optical drive is toast. If your optical drive spits out every single disc, then that also means it needs to be replaced.
Nov 05, 2009 | FastMac (APP-5693) for PowerBook G4...
My powerbook won't accept any cd or dvd. it won't even go into the computer. help!
maybe there is a disc in there? try starting with the "clicker" below the touch pad depressed, this should cause it to eject.
Jul 07, 2009 | FastMac (APP-5693) for PowerBook G4...
PowerBook G4 won't eject cd by any means found on apple support
If you can hear that it's trying, it might be getting pinched while trying to eject, especially if something pressed down on the case at that spot. Try gently widening the opening with a flat head screwdriver while you are ejecting the CD. just put the driver in and twist a bit to widen the slot. Also, check to make sure that the fuzzy stuff that brushes off the disk when you insert it - and keeps out dust - hasn't been damaged. If it is partially missing, the missing part may be inside, keeping the CD from ejecting.
Apr 16, 2009 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
DVD player skips audio and/or frames
PowerBook G4 is at least a five-year-old machine at this point. A DVD drive can **** in lots of dust in five years. Try hooking up to an external DVD drive. If it plays the same discs with no problem, you need a cleaning or replacement. Frankly, an external DVD drive is cheaper than replacing your internal drive.
Mar 07, 2009 | Apple PowerBook G4 Mac Notebook
Mac Power Book G4 - Won't accept ANY Media in Cd / DVD
Yes, your burner is toast. Go order you a new one, open this puppy up, and install it. No need to worry about voiding the warranty, cause your warranty has long expired on this old beast. If your hands are unsteady or your tech skills a bit rusty, then pay someone to do it.
Jan 22, 2009 | FastMac (APP-5693) for PowerBook G4...
Disc drive ejects blank discs...plays dvds
Hi Again,
Sorry I didn't get back to you sooner. Work!
You need to let me know what type of PowerBook G4 it is as the instructions for each are different. However, what I will do is give you the links to the appropriate sites and some instructions for them:
  1. First you need to reset the Power Management Unit (PMU). To do this refer to THIS page. A little way down is a heading 'PowerBook and iBook models covered in this document'. Select the model listed in blue below this which will take you lower down the page to the instructions for your model.
  2. After restarting try your drive again. If it doesn't work, try a dvd drive cleaning disc.
  3. If it still doesn't work your drive is Kaput! If you're near Kent in the UK then I can help you out. If not find a local Apple Specialist who can replace the drive for you.
All the best
Sean
Dec 22, 2008 | Apple PowerBook G4 Mac Notebook
FastMac (APP-5693) for PowerBook G4 Titanium Burner Logo
303 people viewed this question
Top FastMac Computers & Internet Experts
David Payne
David Payne
Are you a FastMac Computer and Internet Expert? Answer questions, earn points and help others
