Question about Ovens
Delonghi DFS901SS I hava a Delonghi DFS901SS. The oven has just stopped working. The light inside has stopped as well. Any clues?
  • 5 more comments
  • siamak1000 Dec 12, 2007
    the clock and the timer is on and i do have the steamming pan sign on as well but nothing in the oven department works . the little light above the selector switch is not on, neither is the interior light as well as the elements. i suppose it is possible that the selector is burned out but can anyone tell me where i can get a cheap one or can they think of anything else i should check short of replacing the selector. what i mean is could it be anything else?
  • Anonymous Feb 21, 2008
    my self clean oven tells won't do its job or lock the door and it tells me to press f9
  • chr8 Oct 05, 2008
    DFS901SS : fan goes on, light goes on, but no heat in oven.  when u turn the thermo knob, there is a slight click but no red light and no heat.  i had a guy round about a year ago who said he replaced the fuse - this got the main oven but not fan oven fixed.  it's gone again so no heat for either now.  where do i look to "replace the fuse" or is it something else?  i cannot move cooker from where it is lodged into worktops.  i can only access from front.  i have removed back panel inside to expose fan but can't seem to find anything to replace or repair... please help!  charles
  • Anonymous Dec 13, 2008
    How do I replace the circular element, I can only access the oven from the front. The element does not appear to pull out, is it secured from the back?
  • Anonymous Dec 27, 2008
    fan comes on but light doesn,t. oven does not heat up
  • Anonymous Jan 26, 2009
    No power to oven. Screen, hob or oven.
  • rwgallas Apr 19, 2009
    Have the same problem. No light come on and no heat.
I just had the same problem, oven wouldn't come on after a power cut. if the timer is flashing, set the clock, and the cooker comes to life (i have a zanussi electrolux gas/elec combo oven). Hope this helps. Debbie
Posted on Mar 04, 2010
Have the same problem as you all. i myself removed the top of the hob to reveal a burnt out control switch . i have looked online for a replacemrnt , and it is £66 plus vat from delonghi but have found a cheaper one for £42, cant remember which site it was but type in cooker name and model on google and you will see it for yourself . good luck to you all, it seems like an easy fix
Mark
Posted on May 06, 2009
If the timer is flashing reset time with the 2 buttons until you get the staeming pan logo on timer,should conect the circuit and make the oven work again
Posted on Nov 26, 2007
Hi
I have the same problem with my cooker can you tell me if you found a solution and how much it cost please
ali
Posted on Nov 21, 2011
Is this fix really as easy as it sounds? Just been quoted £300+ for new part and to fix this. Guy said it's a nightmare job which needs 2 people as the wires go here there and everywhere. At that price not worth it but should it be a lot less than that?
Posted on Jun 17, 2009
How do i clean inside my delonghi glass door the inside
if you pull the oven out a little bit and look under the the door there should be 3 screws you only need two undo one on each side but when undoing the last screw hold the bottom of the door tight as it will fall when you have door frunt off job done ok
Oct 12, 2012 | DeLonghi DEBIE24SS Stainless Steel...
Delonghi Oven temperature problems - ESF 461
Certainly not working right with those readings. I would replace it
Sep 20, 2017 | DeLonghi Ovens
.oven not working delonghi DFS901SS. light on dial
Hi Lyndsay,
Sorry to hear about your oven,
Are you in the GTA , If so call 905-501-8436 for a free quote
If you are elsewhere , how handy are you or a friend.
With the plug pulled, put a Ohmmeter across oven elements.
They should short out. That is good. if not replace element that didn't short out.
If both elements work then it is you thermistat, which is not to hard to replace
Aug 05, 2010 | DeLonghi Ovens
I have a elecric delonghi oven with a gas hob with 6 burners. the oven does not work at all no heat. the light comes on but no heat. the turkey is stuffed an no hat to cook it HELP PLEASE
if the temp indicator light comes on and/or oven fan circulates then its most likely the heating element. if neither then its thermostat or selector switch...
Dec 22, 2009 | DeLonghi DEBIGE 2440 Electric Double Oven
Oven has stopped heating up;delonghi oven906gwf
hi this is abhishek,,,,,,,,
its actually a thermostat or its sensor problem check it,,,,,,,,if its not then its a timer problem.......better to fix it
thank u...
May 03, 2009 | Ovens
DeLonghi Debige 2440 Electric/Gas Double Oven Fan Failure Light
I had the very same problem. I slid the oven out of the wall about 6" or so, unplugged it, plugged it back in. It worked. I'm not sure if I jostled some connection, or if unplugging/repluging it in reset some sort of circuit fault.
Feb 02, 2008 | DeLonghi DEBIGE 2440 Electric Double Oven
Delonghi professional dfs903 cooker
have a Delonghi dual fuel DTC90DF range.
The oven has been temperamental for a whil, working then clicking off so that you had to turn it on again and it would work for a while again. Eventually there was a bit of smoke coming through the hob and it smelt of electrical burning and stopped working all together. It is the main fan oven that is now not working.
Please help
Bev
Jan 03, 2008 | Ovens
Ovens Logo
1,377 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
