Too much ink to few padges printed
Gx3050fsn printed less than 350pgs now low on ink suppose to print 1000 to 1500 pgs
    Brigadier General:
  • 10,406 Answers
Read the "fine print". The 1000 pages is based on "10% coverage", i.e., print a page of text, and less than 10% of the paper will be covered by ink.
If you are printing "pictures", with lots of colour, then 333 pages, with 30% coverage, is to be expected.
Posted on May 27, 2009
    Scholar:
  • 152 Answers
The 1000-1500 mark is usually just a guess - it usually assumes no more than 15% coverage of the page.  If you are printing out very large pictures (full page images) or are printing lots of a single color (green landscape images), then the ink will run out a LOT sooner.
Ink is low epson me10
if your ink is low, you need to buy more ink. OR you can buy ink refill kits ( super cheap ) just be careful filling the ink cartridges so you don't over fill.
If you have only printed a few things ( photo's aside) and are low on ink, then try NOT printing the best quality. adjust the ink quality settings in the properties when your about to print.
Note: if your just printing text and it's not for anything super important ALWAYS go with draft. it prints faster and uses a lot less ink.
Jan 01, 2014 | Office Equipment & Supplies
Test pgs print ok, jobs= no black only blue faintly appears.
Hi, check if the black toner is properly inserted and check the printing configuration
Dec 09, 2013 | HP PhotoSmart Office Equipment & Supplies
Printer prints bottom half of page with less ink
Either your ink cartridge is low or your print head is going bad. Try printing in 'draft' mode.
Dec 13, 2012 | HP PSC 2410 Multifunction Ink Jet printer
No print on the page even though the printer appears to be printing.
The print head is either plugged or daamaged. If you print infrequently say less than a few times a week the ink actually starts to dry inside the print head. if this is mild then a few (but sometimes a few dozen) cleaning cycles will get it printing again. The cleaning cycle can be acessed bybeither the printing manager or by the printer properties through the conrrol'panel or from the all programs/start menu. On a real bad print head it can take a dozen or more cycles before you see any printing at all. once it starts usually a few more cycles will have it printing normally or printing at least. If it is real bad you basically will have two choices. One is tomreplace the printer or manually clean the print head using vinegar. The peintee is not out of ink so don't rush out and replace the ink carts. If they were empty the printer would detect the low level and not do anything. Cleaning the print head just needs a roll of paper towel and some ordinary vinegar. You just wet the towel with the vinegar and gently rub the bottom of the print head. The vinegar disolves the dried ink. So you wipe and change the tpwel until it comes clean. At this point you may need to ru one cleaning cycle but normally it will now print just as good as day one. This is the shop trick to revive ink jets. If you can do it, the worst that happens is your house smells like pickles and you just saved yourself buying a new printer.
Apr 30, 2012 | Canon MP610 Photo All-In-One Printer
We are going through ink like crazy on our Epson 600 Workforce fax. It's supposed to yield up to 500 copies, and we just replaced cartridge yesterday and it already says ink low. Can I change a setting...
just so you know, the # of copies are based at 5% coverage, so make sure that is whats happening. When you are telling the printer to print, in the printer drivers, you can select rough draft type printing where it will use less ink.
Also, make sure your not using generic ink.
Aug 25, 2010 | Office Equipment & Supplies
I put new ink in my hp F4280 printer and I printed about 100 sheets and my light turned orange and it started printing slow. Can you tell does it need new ink already?
The ink level indicator is only an estimate. See page 72 of the user manual which you can obtain here: http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
The HP 60 holds enough ink to print approximately 200 pgs. By the way, it also can evaporate from the cartridge quickly too so try to keep a refill kit or new cartridge on hand.
Jun 08, 2009 | HP DeskJet F4280 All In One Printer InkJet
Epson RX650 with a G5 Mac. Printing beautifully,now pgs are blank
It definately sounds like blocked print heads, try head cleaning 4 or 5 times, leave overnight and try another 4 or 5 times the next day. This usually works, if not you will need to try something a little bit stronger. Try this link:
http://websites.uk-plc.net/UK_Inkjet_Cartridges_PLUS/products/Print_Head_Cleaner.htm
Blocked print heads are more far more common if you are using non-genuine Epson inks. Please take a moment to rate this solution. Thanks.
Mar 04, 2009 | Epson Stylus Photo RX600 All-In-One InkJet...
I have a Canon Pixma ip 1600 printer. My coloured cartridge has just run out but I mostly print in black and white anyway so don't really want to buy another one just yet. The problem is my printer just...
That is the way your printer operates - if cartridge has no ink or is low it will stop operating completely. It sucks but..........................Those bastards want you to buy their ridiculously overpriced ink!
Jun 20, 2017 | Office Equipment & Supplies
Brother MFC-420N : Color Problems
You need to start the ink cartridge changing procedure over. Try unplugging the machine for a few minutes.(from the wall and the computer) Then try the ink change over...If that doesn't work don't waste time. Download and install the latest drivers for your printer. Uninstall then reinstall with newer drivers. Let me know what happens. Good Luck, Tim
Feb 19, 2007 | Brother MFC 420CN All-In-One InkJet...
77 people viewed this question
jasbo
jasbo
