Question about Sony Computers & Internet
Screen not illuminate
I went on a trip and had my laptop secured in my suitcase. Upon arriving home, the idits at the TSa left a notice that they had serched my suitcase. Now my laptop does not seem to power up correctly. Actually, the power light comes on but the screen does not illuminate. Can you help??
  • 1 more comment
  • rob_hitlan May 27, 2009
    When I start up the computer the screen stays black - no illumination at all. When I push the power putton there is a green light and a red (looks like battery light) illuminated. The laptop fan seems to be coming on for a couple seconds and then turning off. it seems to be doing this continuously. help!
    I forgot to mention, I do have the computer plugged in. The yellow charging light does not illuminate. I took the battery out to examine. Everything seems fine. Still not yellow light....given the red light associated with the battery. It seems like the battery is dead but not charging. The computer is only about a month old.
  • ikkenom May 11, 2010
    When you turn the computer on, do you see *ANY* messages at all?
    Does your computer have different lights:
    * computer is connected to AC power-supply
    * battery is completely discharged ("red")
    * battery is charging ("yellow")
    * battery is full-charged ("green")
  • Sony Master
  • 32,281 Answers
Check the power adapter plug with a multi-meter, the voltage reading should be slightly higher than the voltage that is printed on the label on the bottom of the adapter.
If the voltage is incorrect or near to zero then you have a faulty adapter and you need a replacement.
If the voltage is OK, when you plug the connector into the laptop power socket and wriggle the connector, does the charge indicator light flicker but not stay on. Then you have a faulty connector or a faulty power socket on the laptop. This can be repaired.
Posted on May 28, 2009
Our suitcase is locked, and we forgot the combination. how can we reset the combination for our TSA approved luggage?
resetting the combination is only practical if the suitcase is open as the reset tab is located inside where it cannot be tampered with when locked.
if it is a set of dials lock a locksmith could help you.
regards,
Mar 25, 2018 | Luggage & Travel
How can I check on the status of my TSA Precheck
On the TSA Website.
UES - TSA Pre ®
https://universalenroll.dhs.gov/programs/precheck
TSA Pre?® is an expedited security screening program connecting travelers departing from the United States ... Passengers can apply for the TSA Pre?® Application Program to determine if they are low-risk and ... Check My Service Status.
TSA Pre ® ' Transportation Security Administration
https://www.tsa.gov/precheck In October 2017, 97% of TSA Pre? ® passengers waited less than 5 min. Check Icon ... 200 airports and 42 airlines provide TSA Pre? ® ... TSA Precheck Icons ...‎FAQs · ‎TSA Pre?® Participating ... · ‎Airports & Airlines · ‎Schedule
status of my TSA recheck Google Search
Nov 19, 2017 | tsa.gov Computers & Internet
TSA opened our lock on our Delsey luggage, I now am unable to lock the suitcase. How can you reset the lock on the Delsey luggage after unlocked by TSA?
1. Look for a small recessed button below (on the bottom side) the TSA key access.
2. Push in the button with a paper clip or pen.
3. While the button is pushed, change the combination to the desired numbers.
4. Then release the button and the combination has been reset.
I also found this, but it needs to be open/
http://www.ehow.com/how_6927475_reset-tsa-lock.html
Dec 08, 2015 | Delsey Helium Shadow - 25 Trolley Luggage...
Can you take bottles of alcohol in your carry on luggage or checked luggage
Carry on is OK, but must meet the TSA standards, same as all other carry on liquids. 3 ounces or less.
Checked is also OK, no limits, but pack securely to avoid breakage and pilfering by baggage handlers.
Mar 15, 2015 | Luggage & Travel
2004 Audi A4, 1.8 T Continued Cooling System Issues
The best test for this is a cooling system pressure test. You need to have that done. The other thing to check are the freeze plugs.
Feb 20, 2014 | Cars & Trucks
Tsa lock instructions
I have forgotten my lock code on a task lock on a Tripp suitcase anybody know how to resolve the problem
Dec 06, 2013 | Samsonite Silhouette 11 Hardside Spinner
Eminent luggage lock
TSA lock on Eminent Osmosis Luggage, three digit TSA lock (HOW to change it to YOUR personal number)
Put the code numbers to '000'
Take the lock levers OFF the lock
Push the round opening button UPWARDS.
IMPORTANT :
KEEP holding the button UP until you have changed the numbers
Change the TSA code numbers to what YOU want
Release the round opening button
Now your case combo lock numbers have been changed.
To lock the case put the two lock levers into the holes, spin the numbers and your case will be locked.
To UNLOCK the TSA code spin the numbers to YOUR lock code, push the lock button UP and, hey presto, your case will open.
If you forget your NEW lock number you will NEED to go through ALL the numbers, starting at '000' to '999', to be able to open the lock/case.
REMEMBER to PUSH the ROUND OPENING button UPWARDS on EVERY number change.
Only THEN, when it finds YOUR correct three digit number, will it eventually open the suitcase/luggage/baggage.
Good luck
Aug 31, 2013 | Luggage & Travel
I have a somesonite 30in hardshell , uprite about 20 yrs old. has 2 key locks, as well as combanation center lock. question how can i set these locks so that, they are TSA excessable locks??? PLS. Help ...
You can have the locks changed but, that will cost almost as much as new luggage. They will have to be kept unlocked and a TSA strap will be needed around the suitcase.
Oct 07, 2010 | Samsonite Silhouette 11 Hardside Spinner
Problems to open a Samsonite TSA 007 lock on suitcase
Hi I have a problem to aopen my luggage I think my niece has change my security code accidentally , but now I cannot open my luggage can you please chelp me out?
Nov 08, 2009 | Samsonite Tripod
Memory Card Error after Airport Security
In suitcase? Checked baggage? Bad idea. Here's why. I damaged an LCD display that way. Not cracked or broken, but the baggage area is not a heated or insulated space. The temperature can reach well below -40 F (or C). Most electronics is not rated for such and my LCD on the device I put in my checked luggage shows the effect. Lesson learned firsthand....
Sep 15, 2005 | Toshiba PDR-M25 Digital Camera
Computers & Internet Logo
114 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
