Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front-load
Wanted to wash something...i pushed the power button and opened the door. i loaded the items and closed it. when i turned it to the selected program i realized it didn't show the time it needs for the cycle and the power button has been stuck on steady green light ever since. what did i do wrong and what can i do to solve this problem? i tried unplugging but nothing happened....
    Scholar:
  • 146 Answers
Sounds like you have done everything right. Is the door closed firmly? Did you hold the pus to start button long enough?
Posted on Nov 06, 2007
Whirlpool duet sport washer power button problem. I have to push power button a 10-15 times and the power will be on. Please help.
pushing the button that many time is not the problem on this type of unit you push the start and hold of about 5 sec's then you'll hear the unit start door lock and oper through a normal cyc a word of advice don't close the door very hard push into place these things are plastic and will break the latch assy then will cost $$$ for parts good luck
Aug 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
When I wash comforter in whirlpool duet front load water comes
first an foremost your washer isn't designed to wash comforters, the capacity isn't large enough. only clothes sheets . the reason ur door wont stay closed is the bulk item is pushing it open. overloading washer will cause $$ major problems. simiply take that to the cleaners an save urself some big bucks.
May 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F22
I have search for this and found:
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
More info can be found on The Whirlpool website:
Whirlpool Front-Loading Washer
Jan 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Intermittant trouble with code d 11
Answer Duet HT®
Duet®
duet_f_dl_actualsize.gif Duet SportTM
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GEW9200LQ0 Dryer
can oyu oppen the door nad physically push in on the door switch( little grey switch atop the door opening). do you hear it clicking on/off??? if not you have a bad door switch.
Mar 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet
sounds like the on/off button is faulty. It may need replacing, but try a squirt of WD40 on the switch WITH THE POWER TURNED OFF!! COS WD40 IS COMBUSTABLE
 But like my dear old Dad said ''it works like magic in a tin''
Oct 21, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Pause mode stuck
Is the door firmly closed? Open the door and close it firmly. If the pause button is really stuck, you will need to repair/replace the board.
Oct 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Front load Whirlpool Duet
Hi, Has the door catch,which protrudes and goes into the hole, broken off, it should have a sort of hooked end. Tom.
Mar 14, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
263 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
