Question about Western Digital 320GB MyBook External USB 2.0 Hard Drive
Not recognised Hello I have just purchased a 320 gb external hard drive, and plugged it in. I have a really old PC (running on XP)and the USB connection is not 2.0. However, was informed at purchase that this is not a problem. Instructions indicated that following connection, go to my computer, and follow the set up. However, no icons are shown in my computer, the hard drive does not seem to be recognised. Any ideas? Alan
  • 102 Answers
if you have networked drivers, some times windows assigns the new drive a letter that allready exisits as a mapped drive. do you see any active partitions that do not have a drive letter or share a drive letter? if you do you can click change drive letter. select a letter that is not in use.
(this is very common in windows)
you could also try clicking on safely remove hardware and eject it. then plug it back in again and see what happens.
Posted on May 27, 2009
  • bassass May 27, 2009
    or you can install Tweak UI
    Problem Solver:
  • 6 Answers
Did you go to control panel and ran add new hardware to see if it would find the HD? Try this first.
hope this helps
  • 674 Answers
There are problem if the usb connection is not 2.0 then you plugged 2.0 usb then computer will be hang and connot open my computer, somtime can open but it long time to open it.. you can try in another computer the latest. you well see the defferent betwen them...
thanks
My WD external hard drive has suddenly stopped being recognised by my computer
Unplug the power supply from the hard drive, leave for 15 seconds.
Plug power supply back in.
Try another USB cable if that does not work.
Aug 08, 2011 | Western Digital Elements powered by WD 320...
Instal in XP
Hello, This external hard drive does not need a driver, even in XP. If you're using a desktop, don't connect it to the usb ports in front of your CPU case, instead, connect the usb at the back USB ports, if this doesn't work, try using a shorter USB cable and connect it again at the back.
Jun 19, 2011 | Western Digital Elements powered by WD 320...
My new WD 320 GB external drive won't detect in my pc and laptop? pls help....
Hello there,
Please try to plug it into another USB port. There is a chance that your port could be faulty. If its not with the port, try to assign the drive letter if you are using windows. You have to right click on the My Computer icon, select Manage. Once on Computer Management, select Disk Management. Locate your WD drive and right click again. Finally, click on the Assign Drive Letter and follow the wizard.
Dec 26, 2010 | Western Digital Elements powered by WD 320...
ST300003U2 hard drive powers up ok, power light on, message on pc "usb device not recognised " .one of the usb devices has malfunctioned and windows does not recognise it.
Try to plug it in to another PC to see if you get the same message. See if you can run a scan disk on it from Windows to see if it's bad or going bad too.
To be honest, device not recognised is a bad sign. :(
Dec 22, 2010 | Seagate (ST3320820U2-RK) 320 GB USB 2.0...
How to load backup from one computerWindows XP (now on Verbatim USB 320) to a new computer running Windows 7
This is not really a solution but for information. There is no direct upgrade path from Windows XP to Windows 7. So, unless you have a compatible program installed on your Windows 7 PC, you will not be able to import a backup from your XP PC. (To My Knowledge).
Oct 16, 2010 | Verbatim External, USB 2.0, 750GB...
Iomega 320 external hard drive computer wont recognise
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked (with the computer and hard drive plugged in). I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 15, 2010 | Iomega Portable Hi-Speed USB 2.0 40GB,...
HARD DISK NOT RECOGNISED BY MY LAPTOP
try with changing the data cable and the power connector.
Have a nice day and do not forget to rate please...!
Apr 12, 2010 | Western Digital Elements powered by WD 320...
I CONNECT EXTERNAL HARD DRIVE TO PC WITH XP AND IT DID NOT RECOGNISE EXT HARD DRIVE HELP PLEASE
dear sir
good day
try to replace the USB cable and test the Hdd on an other computer system to make sure it is function and good luck
Dec 29, 2009 | Verbatim 160GB USB FireLite: The "drive...
Transcend external hard drive not working.
Contact Transcend Support:
support@transcendusa.com
Jun 09, 2008 | Transcend Computers & Internet
Western Digital 320GB MyBook External USB 2.0 Hard Drive Logo
265 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
