Question about Casio Exilim EX-P700 Digital Camera
Casio ex720 The screen would trun on followed by a constant beeping. Then the screen would shut down. If you tried to turn it on again it would say " power retry is on " or " lens error. "
  • 34 Answers
SOURCE: Casio EXILIM camera lens will not extend fully!!!
It's the focus lens gears. The often times get knocked out of alignment by an impact, or debris gets in there. This can be fixed, but Casio won't help. Hint...google my username. ;)
Posted on Jan 25, 2008
SOURCE: Casio EX-Z120 Lens Stuck
i have also same problem what should i do ???/ plz help ma e-mail is xcuz3@yahoo.com
Posted on Apr 19, 2008
pauman
  • 248 Answers
SOURCE: casio ex-z77/ lens error
you might have pushed the lens into the barrel. small lens barrel has 3 metal pins that ride inside the larger lens barrel as it twists. Pushing it sometimes cracks the plastic holding these 3 pins in. one way to fix it is to carefully disassemble the entire lens barrel. be careful...sometimes a part just snaps, or is already snapped. The easiest way would be to replace the lens assembly with a good one you can get from another camera like this. There are no spare parts for cams like this so you can try to get another cam that has a different damage other than the lens barrel.
Posted on Jul 05, 2009
SOURCE: casio exilim ex-z60 lens error retry power
the same thing happened to me &nd i took it apart &nd nothing happened .
Posted on Jul 20, 2009
BillB-SA
  • 2761 Answers
SOURCE: Casio exlim EX- Z29 lens error upon power on
If you've recently dropped the camera you may have damaged the lens tube (housing) or jarred the zoom mechanism off of its track -- either of these problems will require professional repair. If the camera has not been dropped, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may be too weak/worn to properly power the camera, or the camera may require professional repair.
Posted on Oct 17, 2009
My ps3 12GB slim line truns on for about 1min an turns off an it wont go on the telly screen
Have you tried replugging all the cords in? Also have you cleaned the vents to remove dust bunnies? Any beeps or error codes other then start up/ shut down.
May 04, 2014 | Sony Playstation 3 (PS3) Console
Casio Exilim won't turn on
My guess, only support people know what the two beeps mean.
Try to remove the battery and after a few seconds insert it again.
Then again switch on. If the error returns, contact the dealer or Casio support. Still it could be you think the battery is charged, but the capacity is not enough to power up your camera.
Dec 31, 2013 | Casio EXILIM EX-ZS10 Digital Camera
I have a balance laptop cn 6301 modle 1 535 when you trun it on it just beeps and the screen is black and then it shut down and get very hot
Try unseating the memory and reseating it back into its slot.
If you don't get video after that and the motherboard still is getting real hot then either the cpu fan or motherboard is bad.
Dec 15, 2009 | Computers & Internet
Pc beeps.
Uninstall the audio driver and install it again.
Otherwise tick the mute box on the sound volume or turn the sound volume right down.
Apr 14, 2009 | Dell Latitude CPX Notebook
Turns on four beeps and it shuts down
I was all over this site and the only solution was to send it into repair for the "4 beeps and shut off" problem. I found another site that talked about lense errors, and one of their suggestions was to take the camera, lense up, smack it into your other hand (not too hard) (screen down toward your receiving hand) while the lense was out. You have to be fast, because when you power on, the lense comes out, and you have about 2 seconds to do it. My first light smack, and the camera came alive again! They also talked about lightly tweaking the lense while it was out in case it fell off track or skipped a tooth, but that wasn't my problem apparently!
Aug 08, 2008 | Casio Exilim EX-S600 Digital Camera
Camera beeps and won't turn on
Try playing with the lense I had the same problem. I would turn it on and the screen was frozen, the three beeps then it turned off. I played with the lense since it was sticking out and I tried turning it on again and it worked. :]
Jul 24, 2008 | Casio Exilim EX-V7 Digital Camera
Exilim camera turns on and then truns right off. Won't stay on!
Ok everyone.......if your light is blinking while it's charging that means you have a battery error and need to call techincal support and they can possibly replace the battery for you if it is a certain model and within their time frame of replacement.
Usually beeping and then shutting back off means that the lens has sustained some kind of damage and it is just a matter of time before "lens error" shows up on your screen. The only way I know to fix that is to send it into repairs or an authorized service center if you are out of warranty.
Jan 25, 2008 | Casio Exilim EX-S880 Digital Camera
Alarms
Hello, find the BIOS Beep Codes at http://www.amptron.com/html/bios.beepcodes.html and try to find your problem. It is not a software or Monitor problem. It could be RAM or Video Card failure
Aug 04, 2007 | Biostar M7VIZ Motherboard
Casio EZ Z60
This is a major malfunction take a look here http://www.fixya.com/support/p472784-casio_exilim_zoom_ex_z60_digital_camera and contact the makers Tech Support
May 21, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Casio Exilim EX-P700 Digital Camera Logo
120 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
