Question about Logitech Z-5500 Computer Speakers
Popping Audio I get a popping sound when audio is playing through the Optical Audio connector of my Logitech Z-5500 Speaker System. What could be on the go?
    Problem Solver:
  • 6 Answers
You may have blown the speaker and need to replace it. Try at a low volume and then at high to notice any difference, if the popping occurs only at higher volume then it needs replacing. I hope this helps
Posted on May 27, 2009
Logitech speaker system z323
Unfortunately, manufacturers have decided we no longer need analog audio output jacks. I will never understand why. They do however still include an optical audio output connection. Go on Ebay and look up optical to analog audio output adaptor. Should run you about $20. You may also findnone at Best Buy but will set you back $60. Be sure to set the TV settings to PCM audio output. Otherwise you'll get no sound.
Dec 29, 2013 | Logitech Audio Players & Recorders
Speaker leads shorted on right rear channel of Logitech Z-5500 system
First check the speakers by connecting to front connector if thr no sound then replace the speakers.If you here sound while swap the rear amp IC might be damaged replace the IC .
Dec 19, 2011 | Logitech Z-5500 Computer Speakers
No sound from MSI K8MM3-V.. Can't get my Logitech z-5500 working with my MSI K8MM3-V.. There arent comming any sound out of the ports in the back.. :( I can get the stereo working in the front...
Try reinstall drivers (if dont have download here) then find VIA AUDIO DECK in the system tray and check under the "phone jack" and under the "speaker" parameters and correct if anything wrong. Choose 6 channal and if your motherboard has self detection function of sound devices when plug it pops up and choose correct channal per jack. your logitech connectens here see how to install.
Aug 03, 2009 | MSI K8MM3-V Motherboard
One speaker making a popping sound
try switching the popping speaker to the other side and see if it still pops if it does then you have probably damaged the driver in the speaker if it doesnt pop then the problem probably is in the receiver
May 27, 2009 | Samsung Audio Players & Recorders
Hook up z-5500 suround to a tv
The Sony has (http://b2b.sony.com/Solutions/product/KDL-46S4100)
Digital Audio Output(s): 1 (Rear) Optical Digital Output
The Logitech speakers have (http://www.logitech.com/index.cfm/speakers_audio/home_pc_speakers/devices/224&cl=GB,EN)
Source Inputs:
Digital optical for DVD or CD players, PlayStation®2, Xbox®**
To do this, you need a Digital optical cable--Search Googe for this: Cables Unlimited Pro A/V Series - Digital Audio Cable (optical) - 6 ft
Should work.
Oct 22, 2008 | Audio Players & Recorders
Woofer popping
Sounds like a loose connection or a blown speaker. I would try just playing around with the wires to see if you can make it pop, if so, the wire you were messing with is the most likely culprit. Also, verify the sub cone has no damage or cracks. I am betting it i a bad connection or a loose wire.
Jul 21, 2008 | Logitech Z-5500 Computer Speakers
Popping and fading of sound
The "popping" sound could be electricity jumping from one place to another.An internal SHORT in a transistor, an internal OPEN in a resistor.Intermittent [sometimes it does,sometimes it dose not] arcing electronic parts.
Dust [metal filings,very fine hair that burns like a fuse] & dirt [anything metal], arcing (shorted) capacitors.Bad connections on ANY ground connector.
Possible:: your surround sound MASKED the popping sounds by acting like a FILTER.Which lets me to think that your problem is in the audio section.
Jun 24, 2008 | Samsung DLP HL-P5663W 56" TV
Z-680 optical acting very strange
I bought a new cable. The old one was bad.
Mar 18, 2008 | Logitech Z-680 Computer Speakers
Intermittent popping sound
Its due to earthing leakage! Get your Earthing wiring checked by electrician! then your system will ROCK!
Dec 08, 2007 | Logitech Z-540 Speaker
Problem with optical & coaxial
Good Morning Pulpy
First things first,
1) did you have a digital Sound Card?
2) did you install all drivers on Sound Card? and set to Digital Audio?
3) your speakers are analog? or Digital Input?
do a speaker test and see if center spk. work..again.
good Luck
Nov 17, 2007 | Logitech Z-5500 Computer Speakers
Logitech Z-5500 Computer Speakers Logo
226 people viewed this question
Top Logitech Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
JP Services
JP Services
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
