Question about HP Photosmart C5180 All-In-One InkJet Printer
I have installed a replacement ink cartridge and the printer is not recognizing it. Same problem, replacing ink cartridge but not recognized.
    Problem Solver:
  • 6 Answers
Oftentimes you must do a self cleaning plus realignment with newly installed ink cartridges. Try to locate the manual on performing these tests and it should get you started. Also, look to see if your new package came with a self cleaning kit to clean the heads on the cartridge, but be careful not to damage the parts -which are sensitive. Hope this helps
Posted on May 27, 2009
SOURCE: printer won't recognize cartridge
i had the same problem! I replaced two cartidges at once and one of the lights continued to stay red,The red light stayed on and therefore the printer would not print !!!!!! I decided to fool the printer-----I took the cartridge out and inserted into my chip resetter and then back into the printer--bingo worked like a charm.....I noticed the same type of problem when I changed ink cartidges befor when I was using different types of ink.
I think that the printer doesnot always know that there is still ink in the cartridge that has been removed and then reinserted into the printer again even if its a new one. Using the chip resetter reprograms the cartridge. Make sure the cartridges are not expired. The chip resetter cost about nine dallars--buy one on line. good luck-----Glenn
Posted on Dec 20, 2007
SOURCE: MP150 Error code 4 and 5
Don't use refill cartridges, because it will damage your printer someday. and will cost your parts as brand new. so better use the original ink.
TRY THIS STEPS...
Mp150 Reset Counter
Service mode operation procedures -
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
IF THIS STEPS DOESN'T WORK, YOU NEED TO BRING THE UNIT TO YOUR NEAREST SERVICE CENTER...
Posted on Feb 11, 2008
SOURCE: Epson R1800 printer won't recognize new ink cartridge
ughhhh I'm having the same problem... STUPID MAGENTA
Posted on Oct 13, 2008
Joed911
  • 4338 Answers
SOURCE: Computer won't recognize a replaced ink cartridge
Follow the steps in this HP document:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01135910&cc=us&lc=en&dlc=en&product=3194498
copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Nov 10, 2008
SOURCE: cannot recognize ink cartridge
I had the same problem. I was using original brand cartridges and it was still not working. Here's how I got it to work. I recommend doing each step and then trying to print a test page to see if it is working.
1. I used a Q-tip with Isopropyl Alcohol and cleaned the gold contacts on both the cartridge and the mating contacts in the printer.
2. Then from the Setup Menu, I found a menu called Tools. From there I ran "Align Print Cartridges".
3. From the same menu I also ran "Clean Print Cartridges"
4. I then ran a few test prints by going into the Setup Menu and then choosing "Print Report" and then selecting "Self-Test Report". It prints grid patterns in black & white as well as magenta, yellow and blue. The black grid pattern had some missing lines until I printed this report a few times.
5. I made a few photocopies and now the printouts no longer have large stripes of missing ink as it did in the earlier steps.
Good luck. Hope this helps.
Posted on Dec 03, 2008
Epson Stylus NX415 does not recognize ink cartridges. Cartridges are Epson 88's. Worked for awhile, and then stopped recognizing them. Tried powering down the printer, cleaning the cartridges, turning...
Epson Printers are sensitive in terms of Ink Cartridges.. The latest Epson Printers does not have ink reseter.. Ink reseter are already built-in on the ink cartridges.. The problem on this printer is when you have a cartridge on your printer, let say, 30% of the ink level, even though your ink is new, and you change it without using the right ink replacement method, it will recognize your ink as a 30% ink level. When your ink level drops to 0%, but you have remaining 70% of the ink, it does not recognize it anymore. The chip on the ink cartridge is already registered as an empty cartridge.
May 28, 2011 | Epson Stylus NX400 InkJet Printer
Hi. My printer will not recognize the magenta ink. I tried replacing it with 3 different new ink cartridges, but when I try to make the printer charge the new ink, it does nothing and says I'm out of...
Hi
Some ink printer had ink resetter and just go to ink set up.
If your printer have ink resetter, do it otherwise it will not recognized new ink installed.
If not, some new ink cartridge when the tape is remove, there are cases that the sticky leaf on the ink cartridge, just rinse it with warm water or alcohol to detect the ink cartridge. Turn off your printer and your computer. Then return the ink and open your printer and computer to print again.
Note : Use only ink that is compatible with your printer because it you use other cartridge it will damage the chip set of your printer and it will not recognized any cartridge at all. SO beware.
I hope it helps you.
Jan 12, 2011 | Epson Stylus Photo R1800 InkJet Printer
I replaced the ink cartridge with a new one, and the printer does not recognize it. Will not print. I opened a second new ink and installed it, but still no recognition. Help!
Sometimes ink will get on the contacts in the ink cartridge cradle causing the cartridge to not be recognized. Use a cotton swab with a little bit of alcohol to clean the excess ink from the contacts where the ink cartridge plugs in.
If this doesn't fix your problem, it's time for a new printer.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jan 13, 2010 | HP DeskJet 6122 InkJet Printer
Epson Stylus SX400 "Ink cartridges cannot be recognized"
Try this: First check which cartridge(s) are not being recognized. In my case where I replaced all three color cartridges, two were recognized right away but one was not. You find out by sending a print request to the printer and looking at the ink cartridge levels diagram in the dialog window. In my case two of three were fine but one had a red X on it. So I removed it and cleaned the contacts with alcohol then rocked it in the slot after pressing it in. It was recognized and the charging process began as normal.
Nov 17, 2009 | Epson Office Equipment & Supplies
Epson rx680
one ink cartridge is out of ink but...
when we try to replace one of the color ink cartridges we get this error message:
ink cartridges cannot be recognized. make sure ink cartridges are installed correctly - how do I get the printer to recognize my full ink cartridge?
Sep 18, 2009 | Epson Stylus RX680 Color All-in-One InkJet...
My ESP 7 printer will not accept that a new black ink cartridge has been inserted. I've tried 2 new ones, same with both.
Black ink cartridge is not recognized. I installed a new cartridge last week and had no problems printing till 2 days ago. What can I do to resolve this?
Sep 13, 2009 | Office Equipment & Supplies
Epson Workforce 600 "ink cartridge cannot be recognized" error
My printer quit printing blue after I cleaned the print heads. What can I do? I tried recharging the cyan cartridge and cleaning the print heads again. it's still not working! GRR!!
Aug 22, 2009 | Office Equipment & Supplies
Ink cartridges cannot be recognized in canon printer
Hello!
Remove the cartridges and gently wipe the cartridge contacts with a dry cloth, then put them back in. Then, hold the "resume" button for 10 seconds for each cartridge, that should reset them.
If that doesn't work, one of your cartridges (sadly) needs to be replaced.
Apr 15, 2009 | Canon PIXMA iP1300 Printer
New Magenta Ink is not recognized after installed
Hi, it sounds that the issue can be caused by a defective ink cartridge that installed or a printhead that can recognize magenta ink cartridge. To identify which causes this issue please try the following:
1. Reseat ink cartridge
2. Replace ink cartridge with a specified ink cartridge for your printer.
3. If above steps wont resolved that issue, please call your printer manufacture and ask for service referral or process warranty options.
Tirzo
Oct 21, 2007 | Epson Stylus CX6000 All-In-One InkJet...
HP Photosmart C5180 All-In-One InkJet Printer Logo
307 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
