Question about Hampton Bay 52 In. White Redington III¿ Ceiling Fan w/ Remote Control & Light Kit
Ceiling fan with light and remote stopped working
Hi. I have a ceiling fan in my bedroom that has recently stopped working. I need to change the lights which have burned out, but the fan stopped working in the night the other night. It has a remote with it, and when I click one of the fan speeds on the remote the fan blades jump just a bit, like they want to start turning, but that's it. Is it repairable? I don't know the model number, but the house is only 4 years old, and has only been lived in for a little over 3. We have a 52 inch Redington III fan which has stopped working. The light still works but the fan doesn't. The remote will not work the light but light works with pull chain.
    President:
  • 1,489 Answers
It's most likely the receiver for the remote (transmitter) -- it's located under the cover at the top of the fan -- will need replacing.
Posted on May 27, 2009
SOURCE: we have a hunter type 2 ceiling fan installed on a bedroom ceilin
Okay. Turn off circuit breaker. Take the bottom off the fan. Mark how the wires are connected. Remove switch by unscrewing the sleeve you mentioned. Take the switch to Home Depot (or the like) -- buy a replacement.
If you have to turn the breaker back on during this process, make sure you have a wire nut over the end of each of the loose wires you disconnected from the switch.
After you take the switch out, you'll know how to reinstall it, so I won't go thru that.
Charlie
Posted on May 12, 2009
mohammed387
  • 1952 Answers
SOURCE: need replacement blades
Although we do deal with Hampton Bay fans ourselves, here's a link to someone who does:Contact Mike Evans
Website: www.eceilingfans.com
Phone: 979-553-3260
Ceiling Fan Parts & Service
Posted on Jul 22, 2009
  • 5 Answers
SOURCE: hampton bay ceiling fan works, but can not change
your pull chain for the fan is bad u can go to home depo & buy a new pull chain but when u replace it on the back ot the switch their is A 1,2,3,4, make sure the wires go to the correct #'s
Posted on Oct 05, 2009
farmerbear
  • 490 Answers
SOURCE: 52 inch ceiling fan hampton bay--Humming.....
Sounds like you have covered all the bases already, but there is the small possibility that it is the housing vibrating. You can remove it and buffer the adjoining parts with electrical tape on the inside (so as to be hidden). Otherwise, you have a fan that hums (many just do). May need to exchange for a known quiet model like a Hunter or Panasonic.
Farmerbear at FixYa.com
Posted on Oct 02, 2010
woobie dog
  • 1273 Answers
SOURCE: Where can I get replacement
Hi, W/D here.
All the big box hardware stores have replacement sets along with new hardware, if you need that too.
If they don't have what you're looking for, you can order directly from Hampton Bay at:
http://www.hamptonbaylighting.net/Hampton-bay-blades.html
Best regards, --W/D--
Posted on Feb 07, 2011
Why Ceiling Fan Fixture does not work
You get what you pay for! Shouldn't buy a store brand.
Jul 14, 2014 | Hunter 52" Ceiling Fan With Light And...
Hunter ceiling fan remote will not turn off light it just dims the light
Try this. Remove power from the fan. Remove batteries from the remote. Press butttons on remote (might be stuck). Apply power to the fan. Install batteries in the remote and try all functions. If this doesn't work, the remote may be defective or the remote receiver may be defective. I can tell you from my own experience I have a ceiling fan that loses its mind whenever there is a power outage. Has to be reeducated from scratch
Oct 06, 2012 | Hunter Ceiling Fan Remote Transmitter...
Hunter Ceiling fan remote is operating all the other ceiling fans as well
Sounds like all the dip switches are set to factory still. Easy enough to fix.
Slide open the battery compartment on the back of the remote control and remove the fan's canopy against the ceiling. Then just change the switch to a different setting but make sure that the remote and fan have the same setting. Repeat this in each room so that all the fans have a different setting to each other.
Hope this makes sense.
Aug 02, 2012 | Hunter 52" Ceiling Fan With Light And...
We have 2 Hunter ceiling fans with remotes. We can get the one in the bedroom to work great but the one in the living room now will not turn on the fan or light. Also when we are trying to get the living...
The remote might have wrong orders. Get the battery out and insert it back and see if the problem solved.
Do you set the dip switchs correctly on the fan and on the remote? Numbers set must be matched. Otherwise, the fan won't work either.
Aug 11, 2009 | Hunter 52" Ceiling Fan With Light And...
Ceiling fans on same frequency
There should be dip switches in/on both the remote control and the ceiling fan that enable you to change the control frequency. The only thing that you have to ensure is that the two components are set to a matching frequency.
The switches in the remote are located in the battery compartment just above the batteries. Remove the dome on the ceiling fan and you should find the switches for that unit. Just compare the two and match whatever changes you make from one unit to the other.
Originally answered by d0n0r in this question
May 25, 2009 | Universal Remote Control Hampton Bay...
Motor Hum
check your grounds and all other connections. remote wiring has to be precise. somes times not for the do it your selfer. all the labor youve encountered somes the cheap can turn out to be very expensive.
Apr 26, 2009 | Hunter 52" Ceiling Fan With Light And...
My home is pre wired for a ceiling fan in the master bedroom. There are two light switches that control the pre installed wires. One for the light on the fan and one for the fan. There are four wires
The usual wiruing for these fan/light circuits is that the black wire on one switch is for the fan and the red on the other switch is for the light. If you are using a remote set up for both fan and light, then hook the remote wires to the black and white wires in the ceiling, You can cap off the red wire in the ceiling as this will not be used.
Apr 24, 2009 | Hampton Bay 24002 Ceiling Fan
I have a bedroom ceiling fan that recently started to have a surge issue. It was working fine before (although the remote control for this fan also worked on the Hampton Bay fan in the living room and the...
Sounds like you could have a problem with the fan....but there is also an equaly good chance it's the wiring of the fan. Perhaps a loose connection. If you are not familiar with checking electrical connections, you probably need to call an electrician to check the wiring SOON, before there is a short. If all connections are good, then you will know it's the fan (or the remote receiver on the fan).
Hope this helps!
Chad
Oct 14, 2008 | Hunter 52" Ceiling Fan With Light And...
Hello jluiken,
The motor in the fan is going bad. Unfortunately it will not be cost effective to repair the item as you will be doing an overhaul on the main component. It would be cheaper for you to just purchase a new one. If you leave the fan on for a long period of time you will see that it will become hotter and hotter, which could be a fire hazard so please be careful. Sorry for the bad news.
If you do not mind, please rate my help, I would greatly appreciate it.Thanks
Jul 04, 2008 | Dryers
Hunter ceiling fan
Sounds like the remote receiver units (located where the mains connect to the fans) took a surge and have failed.
Jun 16, 2007 | Hunter Ceiling Fan Control Switch
Hampton Bay 52 In. White Redington III¿ Ceiling Fan w/ Remote Control & Light Kit Logo
1,419 people viewed this question
Top Hampton Bay Dryers Experts
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
