Question about Stoves Kitchen Ranges
CODE F7 When stove gets hot code f 7 comes on I can get it to go off but back on. It will stay off when stove cools off. Here the last couple of times I have used the stove the oven will cut off before the oven preheats and it will take awhile before I can turn it back on.Can this be fixed,cleaned or new stove helen1948@bellsouth.net
  • helen1948 May 28, 2009
    Model # RST 376-UW Caloric Prestige Series This is clarification
    from jumptrout51 When code 7 starts I just let it cool off Its really a pain when you are cooking bread and the oven justs cut off and you have to wait to cool off to finish cooking.What brand do I have?
    and where I get that ERC clock.
  • steve
    steve May 11, 2010
    Model number?
  • Stoves Master
  • 3,361 Answers
Most models it will be a stuck keypad. You can try pushing all keypads several times each to try and un-stick the key.
If that does not work you will have to replace the ERC. (clock).
Posted on May 27, 2009
Getting a PF7 code with beeping on my stove. Reset breaker, didn't fix it. Any help would be appreciated.
GE oven error code "F7" and how to fix it ' AskGene.com
www.askgene.com/.../oven...codes/ge-oven-error-code-f7-and-how-to-fi...
Jun 23, 2007 - The error code "F7" will be displayed along with a beeping sound if the ERC (Electronic ... We have a GE Spectra Oven - GAS - we keep getting F7 errorcodes and the oven will not heat. ... In my case it was the keypad.
Why is my GE Range model number JBP80SM2SS making ...
www.shopyourway.com > Manage My Life > Questions
Apr 6, 2010 - Get shopping advice from experts, friends and the community! I was boiling water on back burner of ceramic stove top GE range Model ... When anyappliance picks up an error code or starts beeping the problem that caused it ...
Jan 08, 2016 | GE Profile 30" Self-Cleaning Slide-In...
Error code f7
Hello Samir Girgis - Typically F7 indicates that it is a potentiometer failure error code has occurred and indicating that one of the surface burner switches has failed. Contact a professional to move forward accurately and to assist with the repairs.
Feb 15, 2013 | Electrolux Frigidaire Professional Series...
I have a Thermador model smw272 and F 7 is flashing on the lower oven display, with a beeping sound every second.
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 30, 2011 | Thermador SMW272 Electric Double Oven
Error Code F7
F7 Function key shorted Replace touch padThis is what the code means. The key could just be stuck. Try pushing it several times to see if it will unstick. before you replace the touchpad.
Mar 11, 2010 | Kitchen Ranges
Ge gas range code f7
Hi. This is a Shorted key panel membrane switch. This will require you to replace the oven control board in this case.(F-7)
Oct 01, 2009 | Dryers
Beeping won't stop and the F7 error code appears on the monitor
You may have got water into the control panel or cooktop causing an electrical short. Hopefully if you give a few days to dry out and plug it back in the code will be gone.
Sep 10, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Maytag stove with f7 code
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Dec 19, 2008 | Maytag MER6772 Gemini Electric Kitchen...
F7 code flashes and beeps
F7 stuck keypad
Dec 10, 2007 | GE Profile JDP47 Electric Kitchen Range
F7 Code and stove beeps
F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button F7 Shorted key sensed for 32 seconds 1. Membrane shorted, or,
2.
Display board defectiveIf touch pad is a separate unit then unplug it and see if code comes back.  Unplug range before doing so.  Once touch pad is disconnected, plug range back in and see if code shows.  Wait a few minutes.  If no code then replace touch pad.  If code does come on while touch pad is disconnected then replace main control.  If touch pad and main control are all one part then replace the whole control.  Doubt if you would have any luck trying to unstick the bad button as stated above.
Oct 15, 2007 | Jenn-Air JGR8850 Gas Kitchen Range
Kitchen Ranges Logo
256 people viewed this question
Top Stoves Kitchen Ranges Experts
paulcarew
Ismael Rodriguez...
wayne murphy
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
