My fujifilm finepix screen is displaying a blank white screen, i dontunderstand b/c it iis still fully functioning but icant see the photos thati am taking. hep?
Try leaving the battery out of it for up to 24 hours, let it fully reset, then try again. If it still doesn't work, it sounds like the mainboard could be bad - is it still under factory warranty?
Needs a degree of investigation to establish the problem. From your description it could be motherboard defect or less likely the LCD. The screen comes as a two-part assembly - LCD and backlight. The screen is accessed easily if you have a small tri-blade screwdriver and a small pozi. I would suggest you search eBay for a faulty Z5 with a broken screen but which displays a portion of the data. Don't pay more than £10 plus postage. Swap -out the screens and see if your camera reproduces the limited data. It takes about 10mins and a steady hand to do this. This will establish if your m/b has gone west or your LCD. Then you are in a position to decide your next move at a minimum cost.You'll find tri-blades on eBay. Should it be the LCD, they cost about £23.00, again on eBay, and with a little more care can be assembled with your functional backlight. I hope this helps.
