Question about Lands Phones
Telephone/answering machine I have an older model telephone/answering machine - 298244-- and the light on the unit has burned out. I cannot determine if the answering part of the machine is on. Is the light bulb replaceable?
  • 77 Answers
Yes the light is replaceable but you will go through more trouble to open the unit and replacing the bulb than buying a new one
Posted on May 30, 2009
HOW DO i RESTORE THE ANSWER PHONE FACILITY?
The KX-A142 is an accessory handset. It's not an answering machine. There is no answer phone facility to be restored with this unit.
If you have an answering machine on your telephone line then please specify the make and model of that.
Sep 06, 2014 | Lands Phones
KXTG9341 Top light flashing and 'New Voicemail' message on handset display, but no new message recorded on the answering machine.
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone.
Please contact your telephone company for instructions on accessing their voicemail system.
Feb 27, 2014 | Panasonic DECT 6.0 Expandable Cordless...
How to check voice messages from coreded base L702c model, or how to turn answering options on from the base unit
Hi, in idle state, from base unit press cassette icon botton (mute), the messages will be played from newer to older.
Oct 07, 2012 | Motorola Mobility L702C DECT 6.0 Telephone
Number of rings uniden 6465
The DCT6465 isn't an answering machine. It will continue to ring until someone picks up or the caller hangs up.
If something else (fax, answering machine, computer, etc) is picking up the call after three rings, a good first step would be to determine the make and model of that device. A good second step would then be to repost your question giving the information from the first step.
Jul 10, 2012 | Uniden Telephones 6465-2
Even though my answering machine indicates it is on, noone can leave a message.The response is that the mailbox has not been set up.Can you help? Thank you.I have had this system for quite a while and have...
A "mailbox not set up" message is coming from your telephone line voice mail system, and not from your telephone answeringmachine. What this means is that the voice mail on the phone line is picking up before the answering machine has a chance, and since the mailbox hasn't been set up it can't take any messages. So there are two things you'll need to do.
First, you'll need to set up your voice mail. You may need to contact your telephone service provider for setup instructions since not all systems are the same, but here's how it usually works. From your home phone, call your own number so you reach your voice mail. You should get the message that your mailbox hasn't been set up, and will be prompted for an access code to get to the setup menu. The access code is usually the last four digits of your phone number, and you'll be prompted to change it to something else as part of the setup. Through the setup main menu you can record your greeting and set up other options like the ring count before the voice mail answers. Set it for a number larger than the setting on your telephone answering machine. (I have my answering machine set to 4 rings, and voicemail set to 6.)
Step two is to verify the ring setting on your answering machine. Four rings is a common default setting, but it's adjustable on the phone. Most newer phones have menus that you access from the handset to set change settings, while older models have a switch on the base unit.
Once the mailbox is set up and you have your answering machine set to pick up first, everything will work as you want.
Aug 14, 2011 | Uniden DECT 6.0 Cordless Phone
How can I get the telephone on my Brother Fax T96 to work?
Step by step information at the link below.
Brother Fax T96
The F/T Mode is used to allow the fax machine and the telephones to share the same telephone line. When a call comes in, the fax machine and all extension telephones on that line will ring according to the number of rings you have set for the Ring Delay.
When the Ring Delay is completed, the fax machine will answer the call and determine if it is a fax call or a telephone (voice) call.
The fax machine can determine this by the signal it is receiving on the telephone line. If someone is sending a fax automatically , the sending fax machine will transmit a fax tone (a series of beeps every 3 seconds).
If your fax machine hears these tones, it will receive the fax.
If the fax machine does not hear any fax tones, it assumes it is a telephone (voice) call and will begin ringing the F/T ring tones (double ring) for the length of time you selected for the F/T Ring Time. These tones will only ring on the fax machine's handset (extension or external phones will not ring). At the end of the F/T ring time the fax machine will go into the receive mode in order to receive a manual fax.
(If the call was a voice call and was not answered, the caller will hear the fax receive tones also).
  • If you answer the call before the fax machine(during the ring delay period) and determine it is a fax, you can transfer the fax to the fax machine for receiving.
  • If you answer the call on an "extension" phone and hear a beep every 3 seconds (automatic fax) or silence (manual fax), press *51 or *91 for New Zealand (remote activation code) on the telephone keypad, wait to hear the fax machine turn on (chirping sounds) and then hang up.
  • If you answer on the handset of the fax machine and hear a beep every 3 seconds or silence, press the Fax Start or Start/Copy key on the control panel of the fax machine and then hang up the handset.
  • If you answer a call on an "extension" phone during the F/T Ring Time, you will hear the F/T ring tones.
    To release the call from the fax machine, press #51 or #91 for New Zealand (remote deactivation code) on the telephone keypad and you can speak to the calling party.
  • If you pick up the handset of the fax machine during the F/T ring time, you may talk to the calling party immediately.
Mar 28, 2011 | Office Equipment & Supplies
Manual for an older model Sony telephone/answering machine system
http://esupport.sony.com/US/perl/model-documents.pl?mdl=SPPA400
Jun 16, 2010 | Sony SPP A700 Cordless Phone (SPP-A700)
Cannot receive faxes
Faxes cannot be received but they can be sent Review the following information to determine why faxes are not being received.
  • Phone company services: Do you have any of the following telephone line services from your telephone company: Voice Mail, Privacy Block, Security Screen, Anonymous Call Rejection, or Privacy Manager? These phone services are meant to prevent unwanted calls, but they will aslo stop faxes. Contact your telephone company for their recommended solution for receiving faxes on the same line with these services.
  • If you wish to receive faxes automatically, verify that automatic answering is enabled on models that have an Auto Answer button, or that the Rings to Answer setting is set to a number equal to or larger than one for models that do not have an Auto Answer button. On models with an Answer Mode setting, it should be set to Fax, FaxTel, or AnswerMachine depending on your setup.
  • If you have a HP PSC 2200 or an Officejet 6100 that interrupts calls or will not receive faxes, download and install the HP Firmware update for these products.
    1. Click here to go to the Drivers and Support page .
    2. Type in your model number (HP PSC 2210xi for example).
    3. Click the search arrow to the right of the text entry box. You may be asked to select your product from a list of models.
    4. On the software download page, select your operating system version.
    5. Locate and select the firmware update.
    6. Follow the directions to download and install the update
  • If an answering machine is connected to the same line, fax reception problems can occur. These problems may be corrected by changing settings or phone line connections. For more information on using a TAM or distinctive ring service, go to Using the HP All-in-One and Fax Products with a Telephone Answering Machine (buu04072) (in English).
  • If you have a PBX phone system, or an ISDN or DSL modem connected to the line, there may be some phone line configuration problems. Fax machines are analog devices and cannot be used on a digital phone service such as those used in many businesses (PBX systems). Install an analog phone line for a fax machine. Refer to document Using an HP All-in-One or Fax Product on a PBX, ISDN, or DSL Phone System (buu50333) (in English) to learn how to correct these problems.
  • If the problem still exists, continue troubleshooting in the Faxes cannot be sent or received or the problem cannot be determined section of this document.
Jun 24, 2009 | HP Officejet 4110 All-In-One InkJet...
#1739 answering machine hooked up but keeps asking for "password"
The unit appears to be stuck in "message retrieval mode) and is asking for your password to give you access when you call in(remote answering). You need to return the unit to it's factory default settings. If you don't still have the instructions you can get them here:http://telephones.att.com/docMgt/public/art/309494/1739_manual.pt2.pdf. Hope this helps!
Mar 28, 2009 | AT&T 1717 Digital Answering Machine
Need to connect ans. machine to single line on a multi line business phone. Help!
Out of box, the AT&T 1738 is designed to operate on a single telephone line. I don't know of any device on the market today that could automatically switch it between multiple telephone lines.
Some options include (in no particular order):
1) Purchasing additional 1738s to cover the other telephone lines.
2) Some cordless telephones on the market are designed to handle 2 telephone lines. Their answering machines will cover both lines. AT&T and Panasonic offer such phones.
3) Check out AT&T's line of NoKSU small office telephone sets. The phones will handle up to 4 telephone lines and 1 model features a built in answering machine. In order for the telephones to function 100% all phones would have to be replaced with the models within the AT&T NoKSU family.
4) If this is strictly a business application, consider purchasing a true business telephone system for the office.
Sep 24, 2008 | AT&T 1738 Digital Answering Machine
Lands Phones Logo
53 people viewed this question
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
