Question about Uniden Cordless Phone
Disconnection my phone seems to hang -up/disconnect while call is in progress after less then 5 minutes of conversation. This occurs on all three handsets. G E
  • drakmoses May 31, 2009
    I have Suddenlink communication service which combines cable, phone and internet service through a modem box. Do you think that this is what is affecting this particular phone--I say this particular phone because I have another cordless phone system with two handsets which has never had this problem
  • 77 Answers
Sounds like you are using the same line to talk and surf the internet..If so you will need to disable call waiting on your modem of your PC.
Posted on May 30, 2009
  • Steve Williams
    Steve Williams Jun 06, 2009
    Try to plug a corded phone (regular phone) in its jack to see if you drop the call...sounds as if you have a frequency problem with this phone. I think no matter what if you didnt have the cable phone combo it will happen even on a regular telephone line or as we say in the telephone world POTS line. try another phone.
    I really suggest to stay away from cordless phones for security measures.
How do I get the fault codes up on a Panasonic split air conditioning system CUE24FKR
14.2.2 To Make a Diagnosis1 Timer LED starts to blink and the unit automatically stops the operation.
2 Press the CHECK button on the remote control continuously for 5 seconds.
3 "- -" will be displayed on the remote control display.
Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed
and signal will be transmit to the main unit.
5 Each press of the button (? or ?) will increase error code
number and transmit error code signal to the main unit.
6 When the latest abnormality code on the main unit and
code transmitted from the remote control are matched,
Power LED will light up for 30 seconds and a "beep" sound
(continuously for 4 seconds) will be heard. If no codes are
matched, Power LED will light up for 0.5 seconds and no
sound will be heard.
7 The breakdown diagnosis mode will be canceled unless
pressing the CHECK button continuously for 5 seconds or
operating the unit for 30 seconds.
8 The LED will be off if the unit is turned off or the RESET
button on the main unit is pressed.
Diagnosis
display Abnormality / Protection control Abnormality
Judgement Emergency operation Primary location to verify H00 No abnormality detected - Normal operation H11 Indoor / Outdoor abnormal communica
tion > 1 min after starting
operation Indoor fan operation
only • Internal / external cable connections
• Indoor / Outdoor PCB H14 Indoor intake air temperature sensor
abnormality Continue for 5 sec. - • Intake air temperature sensor (detec
tive or disconnected) H15 Outdoor compressor temperature sensor
abnormality Continue for 5 sec. - • Compressor temperature sensor
(detective or disconnected) H16 Outdoor Current Transformer open cir
cuit - - • Outdoor PCB
• IPM (Power transistor) module H19 Indoor fan motor mechanism locked 7 times occurance
continuously - • Indoor PCB
• Fan motor H23 Indoor heat exchanger temperature sen
sor abnormality Continue for 5 sec. O
(Cooling only) • Heat exchanger temperature sensor
(detective or disconnected) H24 Indoor heat exchanger temperature sen
sor 2 abnormality Continue for 5 sec. - • Heat exchanger temperature sensor
(detective or disconnected) H27 Outdoor intake air temperature sensor
abnormality Continue for 5 sec. O • Outdoor temperature sensor (detec
tive or disconnected) H28 Outdoor heat exchanger temperature
sensor abnormality Continue for 5 sec. O • Outdoor heat exchanger temperature
sensor (detective or disconnected) H30 Outdoor discharge air temperature sen
sor abnormality Continue for 5 sec. - • Outdoor temperature sensor (detec
tive or disconnected) H33 Indoor / Outdoor wrong connection - - • Indoor / Outdoor supply voltage H38 Indoor / Outdoor mismatch (brand code) H50 Ventilation motor abnormality 7 times occurance
• Ventilation motor H51 Nozzle lock abnormality 2 times occurance
continuously - • Nozzle H52 Limit switch abnormality - - • Indoor PCB H97 Outdoor fan motor mechanism locked 2 times occurance
within 30 minutes - • Indoor PCB
• Fan motor H98 Indoor high pressure protection - - • Air filter dirty
• Air circulation short circuit H99 Indoor heat exchanger anti-freezing pro
tection - - • Insufficient refrigerant
• Air filter dirty F11 Cooling / Heating cycle changeover
abnormality 4 times occurance
within 30 minutes - • 4-way valve
• V-coil F90 PFC control 4 times occurance
within 10 minutes - • Voltage at PFC F91 Refrigerantion cycle abnormality 2 times occurance
within 20 minutes - • No refrigerant
(3-way valve is closed) F93 Compressor rotation failure 4 times occurance
within 20 minutes - • Compressor F95 Cool high pressure protection 4 times occurance
within 20 minutes - • Outdoor refrigerant circuit F96 IPM (power transistor) overheating pro
within 30 minutes - • Excess refrigerant
• Improper heat radiation
• IPM (Power transistor) F97 Outdoor compressor overheating protec
within 10 minutes - • Insufficient refrigerant
• Compressor F98 Total running current protection 3 times occurance
within 20 minutes - • Excess refrigerant
• Improper heat radiation F99 Outdoor Direct Current (DC) peak detec
tion 7 times occurance
continuously - • Outdoor PCB
• Compressor
Note:
"O" - Frequency measured and fan speed fixed.
The memory data of error code is erased when the power supply is cut off, or press the Auto Switch until "beep" sound heard following by pressing the "CHECK" button at remote controller.
Although operation forced to stop when abnormality detected, emergency operation is possible for certain errors (refer to Error Codes Table) by using remote controller or Auto Switch at indoor unit. However, the remote controller signal receiving sound is changed from one "beep" to four "beep" sounds.
Oct 13, 2017 | Panasonic Heating & Cooling
Why does my hands free link hang up my calls?
Try going to settings and update software. It should download the latest software and fixes for your device. Note: this is a known problem with Samsung Galaxy s series devices when mobile or moving.
Feb 18, 2015 | Samsung Lands Phones
Phone keeps hanging up during conversations
What is the model of that phone? It could be something else that transmits on that same frequency and is causing interference/ Things like routers, flourescent lights, basically anything that can send a signal. Someone might also have a phone that is close to that ones frequency.
Apr 24, 2014 | Emerson Lands Phones
Panasonic KX-7431 Call limited to 60 minutes
A year later. I looked at the manual for your model phone and didn't see any reference to adjusting the time a handset can be in use before disconnecting. Does the phone give any kind of warning before it disconnects? My suggestion is even if the battery is well charged that might be the limit of the battery. If not the battery and you get a warning that the handset is about to disconnect you might try pressing and releasing the talk button to reset the handset timer if there is one before the 60 min. has expired. Doing this shouldn't disconnect your party.
Jan 09, 2014 | Panasonic Lands Phones
I just replaced the batteries in my 2 D LED maglite with duracell alkaline batteries and after about 5 minutes use seem to have blown the led. Torch is less than 1 year old and has had limited use. Looking...
The resistor needs to be disconnected at one end -- if the LED is removed this should have the same effect as disconnecting one end of the resistor.
Put the probes of an ohmeter on each end of the resistor -- if it reads 0 ohms (or near zero), it is shorted.
Charlie
Mar 26, 2011 | MagLite Mag-Lite& Flashlight
Disconnecting from google talk
it means that network slow in progress due to that it disconnects
Apr 28, 2009 | Google Talk
Bluetooth disconnects after 5 minutes
I know this sounds silly, but try having your cell phone more than a couple feet away from the base of the DECT phone. Bluetooth can have issues when they are really close together. I have mine setting about 6ft away without problems.
Jan 21, 2009 | GE Lands Phones
Magic jack problem
I have a magic jack and I can talk for 10 minutes only or less and then i hangs up , this problem is happening in three majic jacks with other friends
please advise
Jan 15, 2009 | Lands Phones
Handling Two Calls
Actually, if you hang up on the two calls, the one call isnt "really" hung up on. Example:
Bob hasa treo and is talking to Phil & Jane swapping back & forth. Bob says goodbye to Phil and hangs up and both calls appear to get disconnected. Jane's phone never hangs up. A few seconds later, BOb's Treo rings again... it's Jane. But to Jane, it's the same call. She was never disconnected. Bob just clicks answer and he's back...
Nov 03, 2008 | Palm Treo 700w Smartphone
Vtech cordless phone appears to be mute
Try the "hard reboot". /1/ Unplug power from base station. /2/ Disconnect battery in each handset. /3/ Wait a few minutes. /4/ Reconnect battery. /5/ Re-plug-in power to base station. /6/ Place handset in base station, and wait a few minutes for it to recover.
You may have to reset time/date and/or the handset ##.
Aug 24, 2008 | Vtech 9009111 Cordless Phone
Uniden Cordless Phone Logo
102 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
