Question about Bushnell Trail Sentry 11-9200 Digital Camera
Bushnell Trail Sentry is locked on flashing SD card icon
My Bushnell Trail Sentry camera turns on, but then rather than going to the password entry sequence it goes to a flashing icon of the SD card (lower right corner of LCD).  It is as if it does not reconize that the card is already inserted.  I've tried different cards, bumping the camera, holding all buttons down for a period of time, turning on the power with and without the card inserted, taking out the batteries, etc.  Nothing works.  Is there a way to reset the camera?
  • clowe1 Dec 24, 2009
    Have this same problem on my Trail Sentry camera. Did you find anything to fix this?
SOURCE:
SOURCE: bushnell trail sentry 11-9200
is there anyother way to reset a password without sending it backto
bushnell fepair shop? Heck its deer season and I need it now.
Dave
Posted on Oct 27, 2008
  • 186 Answers
SOURCE: SD Card size
Hi. I tried to use a 4GB card in my dig. camera which has a max limit of 2GB and I got a" card error" message. No harm was done to camera or card.
Posted on Sep 23, 2009
I put a cheap PNY Wal mart 2G in mine and it worked fine, no errors, yet anyway. I did not know the manual stated up to 1G until I got home with it.
Posted on Sep 26, 2009
  • 4 Answers
SOURCE: Bushnell Trail Sentry Camera- forgot password
Trail Scout and Trail Sentry camera re-programming procedure.
1) Turn unit on and wait for screen to prompt password
2) Press the enter button and hold until camera switches into 5-digit password mode _ _ _ _ _.
Trail sentry cameras will not indicate 5-digit mode on the screen, but will indicate _ _ _ _ instead of HHHH .
3) Press enter to confirm 5 digit mode (for trail scouts go to next procedure).
4) Enter 5-digit code 66214 and press enter button( trail sentry cameras will accept a 5th Digit after the 4th 0ne is entered in the _ _ _ _ screen.
5) Camera will now go into operating mode, and user can now program a new password from the setup mode
Posted on Oct 08, 2009
todd0708
  • 247 Answers
SOURCE: Bushnell Trail Sentry Model 119320C Problem
maybe the deer are turning the the camera off.they are pretty smart .just kidding ,im a minnesota deer hunter,and i have downloaded the manual for this camera,and am currently looking for solutions,as far as formating the card ,you need to know what format first,then using your computer,right click on the card reader in my computer and you should see format,click on that and you should see options for fat 32,ntsc,if it uses other format,may need software,or possibly the camera has the capeability to do it ,still reading the manual,try a test with it in your yard after dark,and monotor it for a couple hours,maybe you will notice something
Posted on Oct 15, 2009
How to format a trail camera
I'm sure the Bushnell Trail Sentry User Manual can help you with this. See -Setup and Operation Guide - If the Sentry is turned on without a card in place, it may not turn off. Reset it by pulling one of the batteries out partway, insert a new or empty SD Card and put the battery back in place. Only remove or insert cards with power off.
Click on this link for more information or to buy additional Bushnell Trail Scouting Camreras
Aug 16, 2010 | Bushnell Trail Sentry 11-9200 Digital...
Trying to figure out a pass code for my camera
If the Bushnell Trail Sentry 11-9200 is turned on without an SD card in place, it may need to be reset. Reset it by pulling one of the batteries out partway, insert a new or empty SD card, and put the battery back in place. Read this Set Up Guide for instruction how to set up your passcode.
If you are looking for a replacement trail camera, or you want to buy another, go to my Hunting Supplies Website and browse through the different name brands offered for sale here.
Jul 01, 2010 | Bushnell Trail Sentry 11-9200 Digital...
Trail Sentry 11-9200 Digital Camera: I bought this camera from a store that used it as ...
Bushnell recommends to only remove or insert cards with power off, or it can damage the SD card.
Borrow an SD card that fits in your camera and test it. If this solves the issue, buy a new SD Card here.
May 16, 2010 | Bushnell Trail Sentry 11-9200 Digital...
Bushnell Trail Sentry camrera will not accept any code
If the Bushnell Trail Sentry 11-9200 is turned on without an SD Card in place, it may need to be reset. Reset it by pulling one of the batteries out partway, insert a new or empty SD card, and put the battery back in place. Read this Set Up Guide for instruction how to set up your passcode.
The camera will not Make sure the power is off before installing or removing the SD Card. If you forget, you need to do the reset procedure above.
Buy Name Brand Trail Scouting Cameras here.
Feb 07, 2010 | Bushnell Trail Sentry 11-9200 Digital...
Cant get my SD card that came with my bushnell trail sentry to work in my digital camera. It says card is locked. Do I have to bring card home every time I want to view it?
SD cards have a slide switch along one edge. The position nearest the contacts unlocks the card. If the switch is already there, try sliding it fully in the opposite direction and then back.
Does that help?
Jan 25, 2010 | Bushnell Trail Sentry 11-9200 Digital...
My camera is locked and i cant get the password to reset
I'm sure the Bushnell Trail Sentry User Manual can help you with this. See -Setup and Operation Guide - If the Sentry is turned on without a card in place, it may not turn off-reset it by pulling one of the batteries out partway, insert a new or empty SD card, and put the battery back in place. Only remove or insert cards with power off.
Click on this link to buy additional Trail Scouting Camreras
Oct 30, 2009 | Bushnell Trail Sentry 11-9200 Digital...
Oct 01, 2009 | Bushnell Trail Sentry 11-9200 Digital...
Password camera
Here is a Bushnell Trail Sentry 11-9200 manual in case you lost yours.
To reset it, pull one of the batteries out partway, insert a new or empty SD card, and put the battery back in place.
Read my Hunting Blog for industry information and a good buying source for your next Trail Camera.
Jan 03, 2009 | Bushnell Trail Sentry 11-9200 Digital...
Forgot password on bushnell trail sentry game camera
If you are looking for a replacement trail camera, or you want to buy another, go to my Hunting Supplies Website and browse through the different name brands offered for sale here. http://hunting-supplies-net.com/
Dec 09, 2008 | Bushnell Trail Sentry 11-9200 Digital...
Bushnell Trail Sentry 11-9200 Digital Camera Logo
198 people viewed this question
Top Bushnell Cameras Experts
luckyp32
Level 1 Expert
pictureman4u
Are you a Bushnell Camera Expert? Answer questions, earn points and help others
