Question about Zebra LP 2844 Thermal Printer
LP 2488 not printing
LP 2488 is not printing after I installed drivers. When I try to print the lable come out blank. How can I solve this?
  • Stephen Clouthier
    Stephen Clouthier May 11, 2010
    Are you sure you have THERMAL labels & not non thermal which requires a ribbon? If your not sure take a label & run a lit lighter under it to see if the heat turns it black. If it does then they are THERMAl labels if not install a RIBBON.
SOURCE: Reg. zebra S600 lable
I had this happen when I changed from one label to a different size label. It needs to be calibrated. There are several types of calibration to do to the S600. Here is the solution that worked for me.
  1. Check the position of the laser Media Sensor (figure 13). It may need to be moved to match the type of label that will be printed.
For CARD labels, the media sensor needs to be set at the edge of the card so it can “see through” the notch that is cut on the edge where the perforation is.
    1. For STICKY labels, it can “see through” the backing which shows between each sticky label, so the Media Sensor could be set anywhere for it to work, but will probably be set towards the middle.
Set to Factory Defaults. This is so that all of the following steps will work. I do not need to change the steps based on the type of mode that printer is set up in because it will erase all that by setting it to the factory default. (See figure 14 for buttons)
    1. Turn off the printer.
    2. Hold the FEED and PAUSE buttons down as the printer power is turned on.
    3. Press MODE button four times.
    4. When the defaults are saved to the printer, the CALIBRATE, DARKER, and POSITION lights will all flash.
Test to see if the calibration is set correctly for the label. If not, proceed to the following steps.
  1. Do a Manual Calibration.
    1. Hold the PAUSE, FEED, and CANCEL buttons down as the printer power is turned on, keeping the buttons depressed.
    2. This will run through several labels and do some printing.
    3. Release all three buttons after the CALIBRATION light comes on and then goes back off.
Put the printer into Auto-Calibration Mode.
    2. Hold PAUSE, CANCEL, and MODE down as the printer power is turned on.
    3. Release the buttons after printer is powered on.
Posted on Dec 19, 2007
  • 4 Answers
SOURCE: Zebra LP 2844 printer will not print anything but the test page
possibly not a real LP2844 but an LP2543, a printer mass produced for and used by UPS. refurbishers change the label and sell as LP2844 because they are almost identical.
if it has an AC-AC adapter, it is an LP2543. LP2844 uses a AC-DC adapter, and all LP2844's have USB ports.
Posted on Apr 10, 2009
Madison99
  • 18 Answers
SOURCE: zebra 2488-z
Unplug the printer, place your finger on the green button and with the other hand turn the printer back on. Let the light flash four times (flash, flash flash, flash flash flash, flash flash flash flash) then immediately release the green button. The printer will cycle and feed out a couple of labels. Press the green button one more time and you are ready to go.
Posted on Sep 20, 2009
  • 31 Answers
SOURCE: I am having problems with Zebra printer MDL#ZM400
I agree with Dustproof's suggestion regarding setting defaults. After you do that, you will need to set up your firmware and driver for the correct density, speed, media handling (tear-off vs. peel - labels with gaps or black marks) , etc. If your driver does not relfect the same settings that you have saved in the printer's firmware, the driver will send commands to the printer that will change its settings. Lastly, you will need to calibrate the printer to the media that you are using. An easy way to do this on the ZM400 is to set the power on setting in the LCD menu to calibrate and the head close setting to feed, save these settings in memory and then reboot the printer. This way, you will only need to reboot your printer to calibrate when there is a problem or if you change media types. The feed setting on head close will make sure that your label advances to the the next gap or mark if you open the printhead.
If all ese fails, call Zebra tech support (800) 423 0422 and open up a support case. It is possible that the media sensor or media led is not working properly requiring that your printer be sent in for repair.
Posted on Jan 30, 2010
  • 35 Answers
SOURCE: Zebra LP 2844 Printer Error, Cannot Print
Try this
START
SETTINGS
PRINTER/FAXES
in the pop up window go to
FILE/SERVER PROPERTIES
DRIVERS
SELECT THE MFC5440 DRIVER AND REMOVE
SELEST THE LP 2844 DRIVER AND REMOVE
Now go to www.seagullscientific.com and download the Zebra driver pack, once downloaded run it and install the Zebra Lp2844 to with the USb port.
This should solve the problem, if not please come back.
trevor
Posted on Feb 16, 2010
Hi, thanks in advance for any solution suggestion. My xerox pe 220 prints blank page. Cartridge is new. Th poblem should be with the driver, installed it several times, but it doesn't help. Can anybod
Does it sound like it's trying to print or does it just quickly spit out a blank page. If you print something three pages long, do three blank pages come out??
I know this may sound silly, but did you remove the piece of tape that covers the contacts on the new print cartridge?
Nov 25, 2013 | Xerox Computers & Internet
Zebra TLP 2824 Plus does not print barbell labels
You need to run win7 in XP mode. I am not sure the Zebra software will run in 64bit.
Feb 27, 2017 | Zebra Office Equipment & Supplies
Try this
START
SETTINGS
PRINTER/FAXES
DRIVERS
trevor
Feb 15, 2010 | Zebra LP 2844 Thermal Printer
We have a LP2844 printer that prints multiple blank labels sporadically. How do we stop it?
Make sure the label size is set correctly and the printer is calibrated. If this doesn't work download drivers from Nice Lable or Seagul Scientific websites to suit you Printer, these are more adjustable than the original Zebra drivers and handle small labels better.
Oct 15, 2009 | Zebra LP 2844 Thermal Printer
LPT Zebra UPS Thermal 2844 Printer Printing Slowly
Turn off the printer and place your finger on the green feed button. With the button depressed, turn the printer back on. Let the light flash2.gif (ONLY!) four times and release the button. Printer will cycle through 2-3 labels. Press the feed button one more time.
You've just set the printer back to factory default and dumped whatever settings where mucking it up.
If this doesn't fix you, it is an issue between the software you are using (? what kind is it?) and the printer driver.
Aug 05, 2009 | Zebra Eltron LP 2824 Thermal Printer
Zebra LP2443 thermal label printer wont print
Hi Buck,
What type of labels are you using?
Cheers
Bob
Jan 12, 2009 | Zebra LP 2443 Thermal Label Printer
Prints half of label
Restart your computer. Turn your printer off and back on again. Restart your software for printing lables. When updating the printer drivers, all software needs to be restarted to make sure that the form controls are working properly.
Oct 06, 2008 | Zebra Eltron LP 2824 Thermal Printer
TLP 2824 don't print
Only one suggestion, do a memory dump, switch off the power switch (should be back corner of printer) , hold down the green feed button, power on and watch the feed button, take Your finger off it after the third flash.
Leave it for a moment and press once more, it might say something on the label like out of dump. Try a label again.
Do this two or three times if it still acts up.
After this all thats really left is to clean it with an alcohol swap or check settings in the program You're using
Some times they cant store the amount of print jobs being sent to them and the zebra just freezes up or spits out labels
Apr 08, 2008 | Zebra Eltron LP 2824 Thermal Printer
Printing 'Form information: No form stored' non stop
rchamorro,
Sometimes, resetting the printer to the factory defaults solves some of the problems. For troublehooting and to overwrite all stored parameters, send the ^default command.
Mar 14, 2008 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 Thermal Printer Logo
562 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
