Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet I wanted to wash sg and pushed the power button. placed the items in and closed the door well. when i tried to choose quick wash it wouldn't light up and i had to realize that it didn't show the time for the wash also the power button was sort of stuck. i unplugged and plugged it back but the power button is still on steady green....what can i do?
  • 64 Answers
Sounds like the on/off button is faulty. It may need replacing, but try a squirt of WD40 on the switch WITH THE POWER TURNED OFF!! COS WD40 IS COMBUSTABLE
 But like my dear old Dad said ''it works like magic in a tin''
Posted on Oct 21, 2007
Was working properly but now display error Door open? while door is closed , what can be the problem? plz help me
Item 7 this link has most likely falied:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5135314&diagram_id=28209694#d28209694
Detailed Views:
http://www.appliancepartspros.com/part_details.aspx?part_id=3837611
The interlock switch is part of the above assembly.
Make sure that the door strike assembly item 9 is not broken first.
Thanks for choosing FixYa,
Kelly
Jun 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport washer power button problem. I have to push power button a 10-15 times and the power will be on. Please help.
pushing the button that many time is not the problem on this type of unit you push the start and hold of about 5 sec's then you'll hear the unit start door lock and oper through a normal cyc a word of advice don't close the door very hard push into place these things are plastic and will break the latch assy then will cost $$$ for parts good luck
Aug 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
When I wash comforter in whirlpool duet front load water comes
first an foremost your washer isn't designed to wash comforters, the capacity isn't large enough. only clothes sheets . the reason ur door wont stay closed is the bulk item is pushing it open. overloading washer will cause $$ major problems. simiply take that to the cleaners an save urself some big bucks.
May 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer door is open. I can't close it because the latch is stuck in the "locked" position.
The first thing to try is to hold the cancel button for 15 seconds. The more labor intensive solution is this: Remove the panel beneath the door (2 or 3 screws). Reach up, there is a little "ring" beneath the door lock. Pull this down, it releases the mechanism.
May 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Intermittant trouble with code d 11
Answer Duet HT®
Duet®
duet_f_dl_actualsize.gif Duet SportTM
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GEW9200LQ0 Dryer
can oyu oppen the door nad physically push in on the door switch( little grey switch atop the door opening). do you hear it clicking on/off??? if not you have a bad door switch.
Mar 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet problem with door lock
I've had this same exact problem and that's why I'm at this site.   I have had success with holding the start button and hitting the door right over the place where the switch is on the other side.  That worked good until today so I've called a service tech to come out later this week.  Give that a try and maybe it will work for you.
Oct 22, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front-load
Sounds like you have done everything right. Is the door closed firmly? Did you hold the pus to start button long enough?
Oct 21, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Pause mode stuck
Is the door firmly closed? Open the door and close it firmly. If the pause button is really stuck, you will need to repair/replace the board.
Oct 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
301 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
