Question about Haier HD656E Dehumidifier
Dehumidifier Brand haier HD456E does not pull water and the tank is empty, after 24 hours of running with water on wood floor. Can't find manual or online info for this model. My HD456E was purchased in June of 2008. Worked last summer & fall, but plugged it in this month, & now it's not collecting water. I took it apart & made sure the filter & coils were clean, but still, no water collection. Everything seems to work, except the water collection. Do I spend another $150 for a new one? Not this model, thats for sure.
  • 883 Answers
SOURCE: No water collection
compressor may be starved for freon or blockage in freon line...tech must troubleshoot.
Posted on Jun 08, 2007
  • 225 Answers
SOURCE: Dehumidifier Does Not Collect Water
A dehumidifier is just a refrigerating machine with it's shirt hanging out and there is not much in the way of serviceable parts inside.
If the compressor runs - the throbbing sound - and it doesn't collect water then either the intake filter screen is totally clogged with fluff or the compressor has leaked it's gas away, in which case it might run continuously and get hot to no good effect.
If it doesn't run then it may be that the motor capacitor has failed, but that can soon lead to the compressor motor cooking itself; leaving you with an expensive doorstop.
The one thing you might get checked is the "bucket full" switch. There will be a floating part on the bucket which rises up when the bucket fills and eventually makes contact with another part which is connected to a small switch. If that switch has failed you might be lucky and get an inexpensive repair job done.
If these suggestions do help you solve the problem, please give my reply a suitable rating. If they do not, please add a comment with more details so I can try to help you further.
Cheers, D
Posted on Jul 01, 2008
SOURCE: Dehumidifier Brand haier HD456E does not pull
I have 3 HD656E Haier Dehumidifier with the same problem runs but no water in bucket. How many did the Haier company make with this problem?
Posted on May 20, 2009
SOURCE: I have a Whirlpool dehumidifier that doesn't collect water
I have a Whirlpool dehumidifier model AD50LJ0: the compressor starts but then appears to trip out. The fan keeps running. It does not condense and water. Can you help?
Posted on Jun 12, 2009
  • 334 Answers
SOURCE: Frostguard 36 Dehumidifier runs, but collects no water.
unfortunately it sounds as though your refrigerant leaked out. If your compressor is running and no moisture, this is probably the case. What is the temperature of the air coming out?
Posted on Jun 20, 2009
HD456E dehumidifier shows it is on but nothing happens - no compressor running. The humidity is 75% in basement and have it set to run at 45%. Any possible fix or is it time to replace eventhough it is...
You can normally hear a humidistat open and close if you listen closely. Also, the water tank has either a float or pressure switch that will shut it down.
Jul 30, 2013 | Haier HD656E Dehumidifier
I have an haier hd456e. The unit turns on and the control panel set humidity shows Hi. The compressor does not go on and no water shows up in the bucket. Could this be the 15 amp fuse -- I pulled it and...
I suspect from what you have described, that the humidity extraction level is set to high. Lower it (Arrow Down) to 30-32%. If the filter is clean and the water collection bucket is installed properly, the unit should start working, shortly there after.
To assist you further, I have included a link to the Owner's Manual for your unit. Just in case you have misplaced yours. You can download and print the manual for future reference.
http://www.haieramerica.com/en/asset/product/b9373cda75
I hope this helped you. Please let me know. Thanks.
Jun 17, 2011 | Haier HDN655E Dehumidifier
Have had the unit on for 24 hours now & the water tank has remained empty all this time. Any ideas on this Amcor Dehumidifier dc100 ?
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Feb 21, 2011 | Amcor AHD65 Dehumidifier
Unit runs but will not puu moisture from air....possibly the compressor has kicked off due to control problems. Model HD456E Haier 45 pint dehumidifier
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why a dehumidifier will not work or collect water.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Sep 02, 2010 | Haier HD656E Dehumidifier
Non-standard bucket connector on Haier HD456E / HD656E
A regular brass 3/4" FIP to 3/4" MHT connector with a garden hose washer between the bucket and brass connector was close enough to make things work.
Jun 16, 2009 | Haier HDN655E Dehumidifier
Apr 12, 2009 | Haier HD656E Dehumidifier
Extra cup in my water bucket??
that is just a float for the water when it fulls to that level it pushes the float up and that shuts the unit off it is the bucket float lever control
Jan 22, 2009 | Haier 45-Pint Dehumidifier
Haier HD656E Dehumidifier Logo
240 people viewed this question
Top Haier Dehumidifiers Experts
greg54308
Level 1 Expert
Mike Kolbay
Level 1 Expert
Bill Long
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
