Question about Life Fitness 9500RHRT Recumbent Bike
Life Fitness Bike 5500 No DISPLAY!
All of a sudden the display on my life fitness bike is not lighting even after i changed the nine volt battery.. Please someone give me some help..
  • 1 more comment
  • elacesar May 27, 2009
    Thanks micromaster but i have already checked for current up to the display motherboard to make sure it wasnt a wire problem .. On this type of bike you have to begin pedaling before pressing the start button.. Thanks for any help..
  • elacesar May 28, 2009
    Hello Alex and thanks for the help but this unit is powered by a nine volt battery under the display console.. Thanks again..
  • elacesar May 29, 2009
    Thanks alot for everyones help!
  • 19,396 Answers
To start open the door at the bottom of the control panel and remove the 9V battery. Eventually replace it with a fresh batttery to reset the control board.
If that does not fix the problem the control assembly should be replaced, this is sold as a single part and is normally considered not serviceable at component level.
Posted on May 28, 2009
  • Ginko
    Ginko May 29, 2009
    I forgot to mention that the parts for your model can be purchased here. They do not sell the single replacement board, or LCD display for example , and for that reason the part is difficult ro fix.
    Give them a call , either to purchase a replacement console , or to send the one that you already have for repairs.
    Let me now how it goes.
    Do not forget to leave feedback at the end.
    Thanks
    Scholar:
  • 148 Answers
Check the Life Fitness treadmill for the following:
  • Make sure there is proper power to the Life Fitness treadmill and that it is plugged into a dedicated 15-amp circuit.
  • Check the stop switch for proper operation.
  • Check to see if the ground plug is broken off the power cord.
    Brigadier General:
  • 3,614 Answers
disconnect for a while the panel from any battery connections for an hour. also better check battery terminal for any dirt or corrosion due to some leak on the battery liquid.
Let me know and update me again here.
Posted on May 27, 2009
How to replace a battery on the life fitness 5500 stepper
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Some of these units have 9 volt battery found in the back of the console. Also some of these units that do not have the 9 volt battery, still used the same console shell. If you have an empty spot with no wiring in it, then you are fully relying on your external power supply. I am attaching a link to the picture of the back of the console I am referencing. CASE BATTERY DOOR 0K36 01187 0001 SPORTSMITH net
Dec 08, 2013 | Life Fitness Exercise & Fitness
Our life fitness 9500hr recumbent bike stopped working
If this unit has not been used for that period of time then the 6v batt has died ans needs replacing call National Gym Parts @ 1-800-496-7278 to order part# LC001.5
HERE IS THE PROCEDURE TO REPLACE THE BATT:
Tilt the bike on its side, remove mounting screws securing the battery to the bracket. Remove the battery just enough to access and disconnect the black (neg) wire from the (-) terminal and the red (pos) wire form the (+) terminal. Replace battery and reverse procedure when installing battery
Apr 17, 2010 | Life Fitness 9500RHRT Recumbent Bike
I have lifefitness life cyle that the display does not work also...already replaced 9 volt battery and checked all push on connections. Help!
Inside the side panels there is a 6v @ 2.5 AH batt check this with a multi meter any thing less than 6v replace it go to gymparts. com they will have this batt.
Apr 09, 2010 | Life Fitness 9500RHRT Recumbent Bike
My Life Fitness 5500R (like 9500R ) Recumbent's display works but when I press the program button it doesn't cycle through to Hills, etc.! Suggestions?
sounds like the keypad is not functioning since this is one of their older model I recommend call Life fitness and see if parts are available their # is 1-800-351-3737 they will probably will ask for a s#
Feb 28, 2010 | Life Fitness 9500RHRT Recumbent Bike
DOA Life Fitness 9500rhr exercise cycle
You should check your battery-it must be putting out at least 6 volts to get the computer started up-depending on the era there will be a battery near the bottom frame-you will need to remove on of the side covers to reach it-
Dec 27, 2009 | Life Fitness 9500RHRT Recumbent Bike
Life fitness recumbent bike problem
Hi
We had exactly the same thing. If you take the covers off you will find a black battery pack in the bottom. It is about the same size as a cordless drill battery. We got a replacement from Maplins - cost about £10. It works perfectly now.
Jun 16, 2009 | Life Fitness 9500RHRT Recumbent Bike
Can't get any power running on my 5500 hr life cycle
You have to start pedaling to get it to start up, some times you have to pedal pretty fast to get it to start up
May 27, 2009 | Life Fitness 9500RHRT Recumbent Bike
Change the battery. It is a 9v battery behind the small door on the back of the display panel.
Mar 15, 2009 | Life Fitness 9500RHRT Recumbent Bike
Life Fitness 9500RHRT Recumbent Bike Logo
433 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
sajeel1978 .
Level 1 Expert
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
