Question about Crunch Powerzone P480 Car Audio Amplifier
Hooking up system using HI-INPUT amp wires.
I have a 4-channel crunch amp. How can I Hook up my system using hi-input amplifier wires?? CD Player has aux jacks but the jacks on my amp are all broken.
  • 3 Answers
This may sound dumb, but are there any other inputs left on the amp? Most amps that i have worked with have a special set of inputs for high input. (by high input you mean speaker level right?) If those exist the obvious answer is to use those. They should be labeled, so just hook them up according to them. You may need a special adapter from the amp manufacturer. If you dont have any high level inputs or any not broken inputs left you have two options. You can either A: junk the amp or B: open it up and solder new connectors back on. (it sounds harder than it really is. There are four large pieces of metal to solder onto the board for a set of inputs)
Posted on May 27, 2009
How do i get a cd player to hook up to a sansui au 9900a amplifier as well as the sansui tu 9900 tuner
You can connect the CD player to the amplifier using a standard set of RCA cables (left and right channel / red & white connectors). Connect the CD output to an input on the amplifier (usually one designated for CD or possibly "Aux") Then select this input source in order on the Amplifier.
There would be no reason to connect the CD player to a Tuner. Not even sure a tuner whould have any inputs in order to connect a CD player.
Sep 29, 2014 | Audio Players & Recorders
I need to know how to hook up Sony amplifier ta-ax 295,Sony tuner st-jx 295, sony cassette tc-w295 with a RCA 5 disc CD player and a Samsung DVD/ video CD/CD player in stereo. It always worked when my...
There are a number of amplifiers in the TA series, but the connections are basically the same.
In your system, the amplifier serves as master control. How do you know? Look for the component that offers input selection -tuner, cassette, CD, video, phono and probably auxiliary. Every other component plugs into and is controlled by the integrated amplifier. For example, plug the tuner wires from the tuner output to the amplifier input marked "Tuner." To use the tuner, just select that input from the front panel. Same with all the other components.
On the back of that unit will a bunch of RCA jacks for left and right channels. Take the hook-up wires, usually RCA cables with colored plugs on each end, and connect the OUTPUT jacks on each separate component to the INPUT jacks on the amp. Power may also be controlled from the amp. On audio plugs, red is right and white is left. Keep the polarity constant as you connect each component. Connect the speaker wires to the speaker outputs, usually spring clips or screw terminals on the amplifier end and the same on each speaker. The DVD video cable will have three wires: Yellow, red and white. Yellow is always video. It may also have a little round video connector for S-VHS which provides a much better picture when using DVD.
Select your desired input and enjoy the show. Service Manual free download schematics datasheets eeprom bins pcb...
Jul 13, 2014 | Audio Players & Recorders
I am setting up 4 bose 901s to my home stereo and am unsure how to connect my components to tha 901s active equilizer. the 4 901s are connected to 4 marantz ma 500 amplifiers. the amplifiers are...
Hi -
Sony CD player Red / White RCA - > CD input RCAs on the Arcam.
From the Arcam Preamp Output RCA's, go to the Bose "Input". From the Bose "Output", you need RCA splitters to make them into four outputs to run your amplifier connections.clmrt5000_2.jpgclmrt5000_3.jpg
Jan 15, 2011 | Bose 901 VI Main / Stereo Speaker
Amplifier doesnt seem to be amplifying sound like it should can barelly hear it but works just fine when hooking amp up to tv or something else
Try a different input on amp. If youre using "cd", try a different input. Temporary fix. If not, then switch it with the tv input.
Nov 19, 2010 | JVC XL-SV22 CD Player
SUV500 2-Channel Amplifier: Hi! can I connect another technics cd-player,sl...
yes you can connect another cd player to the DAT input of your amp.
input connections like DAT, TUNER, CD, AUX etc (except phono) is just to differentiate between what sources are connected, the amp cannot tell what source is connected and will output the sound no problem.
as for the remote operation, if the 2 technics cd players are switched on at the same time they're going to do what you command from the remote together but you'll obviously be listening to 1 at a time.
May 17, 2010 | Technics SUV500 2-Channel Amplifier
My head unit has 1 set of preamp outputs can i conn. 4 speakers
Yes you can use a y to go to all four. Or you could bridge the four speakers wires onto the two outputs for 1 channel
Mar 31, 2009 | Alpine MRP-F320 Car Audio Amplifier
1000w fli sub has 5 wires on high level input. What do these wires connect to?
Also called speaker level inputs, an input on an amplifier specifically designed for higher voltage and lower impedance signals, typically between 1.2 to 12 volts and 4 to 8 ohms, as found on the outputs of low powered speaker connections. Hi-level inputs are commonly used as an easy and convenient upgrade path to connect factory-installed head units to after-market amplifiers.
high level inputs are less subjected to interference and can travel further without signal loss.
Factory radios do not have dedicated outputs for amplifiers (preamp outputs). So you'll want an amplifier with speaker-level (often called high-level) inputs; these inputs enable you to tap into the factory speaker wires for a signal flow.
They're called high-level inputs because the voltage level is significantly higher than with a standard preamp output connection. These inputs convert the high voltage to one the amplifier can handle. Once connected, you'll hear clean, well-defined sound (including the lyrics to your favorite song).
Speaker-level inputs are a standard of many two- and four-channel, and mono subwoofer amplifiers.
All the power wires no the amp will be ran the same with the exception of the remote turn on wire. +12v constant will still go to the battery(properly fused with 12" of the battery!), and the ground will still go to the chassis. You can hook the remote turn on to the +12v ignition wire behind the radio, or the equivilent fuse in the fuse box. I would not recomend hooking it up to the pwr ant wire on the stock deck as it often goes off when the radio is off, or cd is playing.
As I said, most cars have no issues with any of this, but cars with "PREMIUM SOUND" systems often do not mesh well with aftermarket equipment. Fords JBL or chrystlers infinity (And bose in darn near anything!) are often cause issues. Sometimes you can easily bypass this system(Ford), sometimes you have little choice but to rip it all out and start fresh(Bose). I can walk you through the scenarios for most makes and models, but certainly do not have the time or patience to give every one. Hit me up on the forum and I will be happy to help you further....
Jan 03, 2009 | Jensen LXA300 Car Audio Amplifier
Hooking up an amp
yes of course!! since it has pins provided on the wire but make sure you how to connect it OR it will fry your amp.be careful!!! have it consult to a technician for sure.
for better instructions, go to this link:
http://www.caraudiohelp.com/how_to_install_a_car_amp/how_to_install_a_car_amp.htm
this will help you a lot..Goodluck!! rate me here as fixya!!! tnx!!
Feb 05, 2008 | Car Audio & Video
Installing pyramid 795cd equalizer
cd player or dvd player output------------to equalizer input---------equalizer output---------amplifier input--------amplifier output ----------to speakers
May 26, 2007 | Pyramid PR333E Home Equalizer
Crunch Powerzone P480 Car Audio Amplifier Logo
358 people viewed this question
Top Crunch Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Matthew Spark
Matthew Spark
Tygh Duval
Tygh Duval
Are you a Crunch Car Audio and Video Expert? Answer questions, earn points and help others
