Question about GE DCL333EA Dryer
How do I remove the drum??
I have a GE DCL333 dryer and want to replace the rear bearing. How do I remove the drum??
  • 864 Answers
From the diagram at:
http://genet.geappliances.com/IPCNet/Dispatcher?REQUEST=IPCNETGETPDF&file=00000000/00013300/00013301.p03.pdf
It appears that you get access to the drum by removing the front panel.
Posted on May 28, 2009
Why is it now squealing when in spin mode
If your dryer is the kind with rotating drums, might be a bearing. You should disassemble it and check if can be replaced
Dryer Repair Replacing the Drum Bearing GE Part WE3M26
Dryer Repair Replacing the Rear Drum Bearing Assembly Frigidaire Part...
Dryer Repair Replacing the Rear Drum Bearing Kit Part 1 GE Part WE25M40
GE Dryer Repair Noisy or Screeching Rear Drum Bearing WE25M40
you can fine more youtube video tutoriala looking in google for terms
Youtube DRUM DRYER
Sep 02, 2015 | Dryers
GE dyer DWSR483EG3WW is making a ginding noise on the fron right side (looking at dryer). I have replaced the four slides. It sounds fine for about 3 min, then the noise starts. Could the back bearing...
Hello Donna, it's hard to say without physically seeing it for myself, but I would say that you might need to replace the front bearing. Not just the slides, but the half moon looking piece that you put the slides on. They are easy to replace.
http://www.do-it-yourself-washing-machine-and-dryer-repair-help.com/drum-support-bearing-GE-dryer.html this will help with the front bearing.
You should also check the rear bearing while you're at it. It can cause a bunch of problems as well.
You will be able to tell if it's worn by looking at it. You will however, need to pull the drum forward off of the rear to get to it. You dont have to remove the drum, just prop it up with a piece of wood while you look at the bearing. They are easily replaced as well. I would think that between the two, that should solve your problem. The rear bearing when worn, usually causes a squeeking sound. If the dryer is getting to the point where things are wearing out. It's always a good idea to check the others too.
this should help with the rear bearing....
http://www.do-it-yourself-washing-machine-and-dryer-repair-help.com/rear-drum-teflon-bearing-GE-dryer.html
Also, a parts list with diagrams:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5202037&diagram_id=25749124#d25749124
I hope this helps you out. I will be happy to assist you further if you need it. I'm always happy to help. thanks,
Mike
Jul 31, 2011 | Dryers
Hi i have a GE DRYER and it is making a horrible grinding sound,i took out all the cloth's and tried it again,it is still making the grinding sound,what could be the problem. Thank you
The drum rides on glides in the front and a center bearing in the rear. Those glides are probably gone.
Unplug the dryer and remove these screws then raise the top.
Remove these screws and lift off the front to check those glides
If it is scrubbing you probably need to not only replace the glides
but the glides mount also (called a bearing oddly enough).
Remove the drum and inspect the rear bearing for wear
I have More repair photos HERE
Dec 27, 2010 | GE 5.8 Cu. Ft. Extra-Large Capacity...
When my GE electric dryer is on, its making a loud squeaking noise. The drum is not off kilter.
Possibly one of the following : Could be a seized drum bearing, at rear of drum. It will get worse if you keep using the dryer, and eventually cause permanent damage to the drum. Or it could be something like a button or hair-clip is stuck between the front edge of the drum, and the normal rubbing surface at the front of the dryer. In both cases, you need to remove the drum to remove whatever is stuck in there, or to replace the rear drum bearing also. Hope this helps!
Aug 20, 2010 | Dryers
Constant squeaking when running model # DNSR473EWOWW
You will need to replace the rear drum bearing,a fairly common concern on these models. you should also inspect the front bearing surface the drum rides on for wear since replacement of the rear bearing requires removal of the drum anyway, when ordering the rear bearing kit make sure it comes with the special high temp grease that is used on the rear bearing. Good Luck
Aug 14, 2010 | GE Dryers
We have a GE Prodigy clothes dryer that makes a very loud sqeacking noise when it runs
sounds like a rear drum bearing thats gone bad very common with these units, the front bearing and slides should also be checked for wear at the same time,to replace bearing in back drum has to be removed completely. if your handy with tool and have and afternoon to kill its not that bad ,just rember to UNPLUG UNIT BEFORE ANY WORK
Aug 06, 2010 | GE Profile Prodigy DPSR513GA Dryer
GE electric dryer (model #: DRSR483ED2WW) sounds like grinding metal when dryer starts/runs
you need to replace the rear drum bearing by removing the front panel lower screws and then remove the top cover and lean back and secure so as not to break wires to control panel,then remove drum belt,lift out drum and replace with bearing kit
Feb 01, 2010 | Dryers
GE Dryer Model DWSR483EA1WW squeaky noises
Un-plug dryer. Remove screws from front panel into dryer top. (just inside the door, at the top of the opening) Swing top up and remove screw near top of front panel on each side. Tilt front panel forward and lift off, set to the side. (leave wires attatched) Pull drum ahead about 4 inches. Do not remove belt. (it's a little tough to get the drum past the sides of the dryer) Remove the old rear drum bearing and replace it. If I remember correctly, it is a part number WE3X37. Replace drum. Check the front drum support slides on the front panel. They should be about 1/8 inch thick. If the rear bearing was squeaking, they may need replacing also. Finish re-assembly, plug back in and test.
Oct 18, 2009 | Dryers
My dryer squeaks when it's on? It's a G E. How do I get inside to look around?
Check Idler pulley and rear drum bearing first. One of those is likely to cause squeaking when it fails. Idler pulley can be checked by removing lower rear panel. It's located right next to Motor.
Rear drum bearing is replaced by raising top and removing front and drum. Often just the bearing sleeve needs replacing unless the support shaft or housing is deformed.
Aug 21, 2009 | GE Dryers
Dryers Logo
285 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
