Question about IBM ThinkPad T42 Notebook
IBM T42 gave fan error, replaced and can not get it to reboot
My IBM notebook T42 gives FAN ERROR message and switches off. It is an intermittent problem and many times I am unable to get it started. Once I was able to get it working, since then I have not switched it off. I just close the LCD panel and put it in hibernation mode. I can also reboot in this mode during automatic updates. This seems to be BIOS problem connected with some hardware. The Lenovo service center failed to identify the problem. Are the schematic circuit diagrams available to trace this problem? I also want to know if I can use larger hard disk than 80 GB that came with the machine. If so what is the maximum limit. Is BIOS upgradation needed for this and how do I do it. I had the same problem and replaced the fan, only now when I attempted to turn on the computer the fan goes on but it doest reboot? The screen never turns on and I dont hear or see the hard drive running? Any help!
  • 1 more comment
  • jvasquez70 May 27, 2009
    the fan is running, I have gone over all connections to see if any we loosened. The screen is just black and the computer never boots
  • Frank Zhang
    Frank Zhang May 11, 2010
    you mean sometime your laptop "The screen never turns on and I dont hear or see the hard drive running, and while the fan never respin"? that mean no any booting and dark screen?
  • Jeff Strader
    Jeff Strader May 11, 2010
    go into the bios ans see iff you can disable the fan alarm that triggers the shutdown, also check the power management in the bios for any fan power saving features that might be enabled and disable them..
    Scholar:
  • 75 Answers
Make sure the fan is pluged in correctly and you didnt unplug anything else such as memory or etc or bump the cpu... did you put any thermal paste on the cpu when you put the fan on it? its needed to bond the too together to make a better cooling system there maybe a setting in your bios to disable fan monitoring or cpu temp etc have to look at your bios to see
Posted on May 27, 2009
  • David Grassel
    David Grassel May 27, 2009
    try reseating the ram powered off with battery out then press power button while unpluged and battery out this will drain all power might correct the issue you should be able to upgrade the hard drive to any size just make sure you get the right connection such as sata or ide
Fan error displace on my t42 ibm.I noticed the fan is working but the error do come once in a while thereby prevent the pc from working
If the fan is running but your notebook still overheats, your computer will turn itself off, and you need to wait until it cools down
The question is, why is it overheating? Try using a vacuum cleaner close to the ventilation slots to suck out any dust.
If this does not solve the problem, please get back to me
Jan 24, 2014 | IBM ThinkPad T42 Notebook
Connecting to my home wireless
Does it find a signal? do you get an error message? if so what is that message. if it does not find a wireless signal do you have the the wireless turned on most of the IBM thinkpad has a switch on the side of the computer to turn the wireless connection on and off. make sure it is on. please answer the 2 question above for more help
Dec 13, 2007 | IBM ThinkPad T42 Notebook
My ThinkPad T42 cooling fan works slow... i feel like air flow is very slow when i touch the vents... i opened the laptop and checked the fan and it was really slow.. what should i do now please help......
You should replace the fan if it is defective.
You can check inside your Bios or System Setup to see if there are any options on controlling the fan. If the laptop is not giving you any error messages or overheating the fan might be ok.
May 06, 2012 | IBM ThinkPad T42 Notebook
Not booting up
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Apr 03, 2012 | IBM ThinkPad T42 Notebook
IBM T42
Hi, This is a motherboard issue, this is a know issue on T42 you should contact Lenovo support to get a planar replacement. Thanks and have a nice day J-
Jun 01, 2010 | IBM ThinkPad T42 Notebook
Fan Error message but the fan's working on another machine
One option would be to replace the motherboard. You can use one from T40 -T43 with your monitor. I bought one on Ebay for $90 which came with the board installed to the bottom plastic tray. I only had to install my monitor, memory, keyboard, hard drive, & plastic bezel and I had a good working unit for $90.
May 15, 2010 | EliteGroup A530 Notebook
IBM T42 gives Fan Error message and stops
The fan may be faulty or clogged with dust.
Check the fan to see f it spins freely and remove dust from the heatsink fins and fan assembly.
The specification in the manual for the T40 series shows the largest hard drive is 80 Gb.
It may be possible to install a larger hard drive, but check with Lenevo first.
May 25, 2009 | IBM ThinkPad T42 Notebook
IBM Lapyop T42-message"Fan errors" does not turn on
your cooling fan is reporting as damaged you need to replace the fan unit (cooling pad as well) likely service is required and unless you want to disassemble your laptop a service center would be better suited for this job.
Dec 13, 2008 | IBM ThinkPad T42 Notebook
Thinkpad T40 2373 fan replacement: long or short?
Description
s.gif s.gif s.gif s.gif s.gif Item Specifics - Item Condition
Condition: Used
s.gif s.gif IBM THINKPAD T40 T41 T42 CPU Short Cooling Fan FRU 91P9759 91P8393 this is the fan you need. please remember to rate the solution. will send you a link to my site with the how to disassemble and reassemble
Apr 09, 2008 | IBM ThinkPad T40 2373 Notebook
IBM ThinkPad T42 Notebook Logo
673 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
