Question about Frigidaire 5 cu. ft. / 142 liter Chest Freezer FFC05M0A
Brand New Freezer, won't cool
I have just unboxed and set up a 5.0 Frigidaire freezer model FFC0522DW6. It has been 24 hours, not cooling. I read manual & followed all instructions. Temp set at coolest, plugged in, hear noise when I change temp gauge from off to on. Circuit is fine, plugged in. Did I not do something I should have?
  • Frigidaire Master
  • 4,655 Answers
You did nothing wrong. I believe it was faulty at the time of purchase. Return for refund
Posted on Oct 21, 2007
Freezer wont freeze ice cubes
Hello Friend, this is Z. Thank you for your post!
I interpret that you are having trouble with the freezer of your Frigidaire refrigerator not freezing ice cubes. It appears that your refrigerator is not properly cooling. Make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly. Please allow 24 hours for temperature to stabilize. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your freezer status has changed successfully. Thank you!
Aug 26, 2014 | Frigidaire Freezers
Why a Frigidaire freezer seems to be stuck in defrost model number LFFU17F5HWC
Good Morning Friend,
I understand that your Frigidaire freezer, model# LFFU17F5HWC, seems to be stuck in a defrost mode. Your freezer is supposed to automatically defrost for 30 minutes after every 12 hours of compressor run time. I suggest resetting your appliance, be either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. Restore power and watch to see if it is still stuck in defrost mode. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 24, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Not cold
Good Morning renee kelley, this is Z. I am happy to assist you!
Good Afternoon Jason, thank you for allowing me to assist you!
I understand your Frigidaire freezer is not cooling and displaying "OFF" on the door. It appears that the temperature control is in the OFF position. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try activating the freezer by pressing the UP arrow until display shows "4" or desired setting. Allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting. I hope these troubleshooting tips help you in some small way. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your freezer status has changed successfully.
Mar 20, 2014 | Frigidaire Freezers
Lffh21f7hwa
Hello Michael - Sounds like the temperature control was accidently turned OFF. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try activating the freezer by pressing the UP arrow until display shows "4" or desired setting. Allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
Jul 01, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
How does the Frigidaire FFU1764 Upright Freezer defrost?
Download its manual here and then read through the defrost section. It should run every 12-24 hours.
Aug 23, 2012 | Frigidaire Freezer 16.7 Upright Freezer,...
My frigidaire side by side isn't cooling properly,
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Feb 21, 2010 | Frigidaire Freezer Refrigeration White...
New freezer not cooling - temp @ 25 degrees and food is defrosted
It is probably the control board and since it's new it's still under warranty so a certified Frigidaire repair man will fix it without charge. There should be a telephone number with the paperwork you received when you bought it.
Aug 29, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My son got into my fridge lastnight-left open, now won't cool
evaporator coils is probably frosted from condinsation.shut door set at normal setting and give some time.
Jul 26, 2009 | Frigidaire Freezer Refrigeration White...
Side by side fridge not cooling, not making ice
if it seems like the evaporator is getting cold then your sealed system should appear to be ok. you need the evap fan to transfer cold air into fresh food section. if not turning u need to replace fan motor. make sure your not getting to much frost build up on the evap.
Jun 24, 2009 | Frigidaire Freezer Refrigeration White...
Frigidaire 5 cu. ft. / 142 liter Chest Freezer FFC05M0A Logo
413 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
