Question about HP OfficeJet 6210 All-In-One InkJet Printer
Can we operate HP6210 as a FAX without a computer hook up?
We were given a HP6210 and would like to use it as a copier and fax without connecting it to a computer.  Can this be done?  We do not have a manual or disc for set up.
  • 90 Answers
Yes acutally you just need to plug it into an analog phone line and it should work.
Posted on May 27, 2009
Lexmark Productivity Suite --the faxes don't go through -- error message
Are you able to send faxes when using the printer operator panel - not through Lexmark Productivity Suite application on your computer? Are you able to receive faxes without any problems? Make sure the fax line where the printer is connected is working properly. It could be a signal quality in the connection.
You can also try to decrease the transmission speed when sending faxes. On your printer operator panel:
  1. Press the Fax button, then press Options 15 times to get to ADVANCED FAX.
  2. Press Select.
  3. Press Options ten times until MAX SEND SPEED appears on the LCD display.
  4. Change it to 9600 BPS using the - (left arrow) button.
  5. Press Select.
Try to send your fax again.
Source: Problems Sending a Fax to Specific Fax Machines
Jun 23, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I was given a Lexmark x4270 and all I want to do is use it as a fax machine. What do I need to do? Do I still have to hook it up to my computer or just the phone line?
You will just plug the phone line into the all-in-one. No need to connect it to your computer if your not going to use it to print. Once plugged into a phone line, use just like a fax machine.
Mar 16, 2011 | Lexmark X4270 All-In-One InkJet Printer
I'm not very techie... I just want to ask how to use the fax in this model... is it plug and play? how to operate the fax? can i operate the fax through computer? can i receive fax? will my fax number be...
Here in the link which i have given you could find your printers manual download it and so that you can see about your fax how to use
http://www.retrevo.com/support/Brother-MFC-7840W-Multifunction-Printers-manual/id/16690ag611/t/2/
Mar 11, 2011 | Brother MFC 7840W Printer
Hp office jet 5610 all in one printer--- am I able to fax without hooking up to a computer if yes how- thanks
All the HP office all-in-ones fax without computer hookup, simply place the fax on the load tray face up until you see the window state that the original is loaded. Then on the number pad dial the fax number you want to connect to, once that is done...press the black fax button and the machine will dial the number, once a connection is made the fax will feed itself through and complete. The only connection needed is an outgoing phone line. Just make sure that the phone line is in the right socket on the back. You will see icons by the sockets, the one with the phone icon is for a line to go to a phone headset....this is not the socket for the main phone line, ise the other one that says "line".
Jun 27, 2010 | HP Officejet 5610 All-In-One InkJet...
HP6210 faxing with MagicJack---Any suggestions?
Try using the magic jack on a seperate computer, you are using two lines at once with the fax and the magic on the same machine and it sounds like it's causing a usb problem
May 23, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Receiving fax using HP6210
If sending the line is active, make sure your senders have the correct # and that their is paper in the machine. What does it do when incoming fax is ringing??
Oct 02, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Hp4300 series disc won't work with my new hp window vista computer my printer is a 4315v
Please perform the steps given below and check if yuo are able to fax
1. Open a MS Word Document.
2. Click File -> Send to -> Recipient using a fax modem.
3. Follow the instructions given in the fax wizard. Ensure that you select the HP all-in-one as the fax program.
Now check whether you are able to send the fax.
OR
Try setting up the Fax once again
=== Fax Setup wizard ===
- Double-click on the HP Solution Center to open it.
- Go to Settings --> Fax Settings & Setup --> Fax Setup Wizard.
Complete the fax setup wizard and then, try to fax
Vishwanath V U
May 19, 2009 | HP Officejet 4315v All-In-One InkJet...
Can I use the fax and phone on the brothers printer without hooking it to my computer, just to the phone line?
not knowing the model of the printer there is no definitive answer
but
a printer/fax with a fax scanning unit built in can be used as a standalone fax
Jun 28, 2008 | Brother Office Equipment & Supplies
HP OfficeJet 6210 All-In-One InkJet Printer Logo
80 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
