Question about Dell 922 All-In-One InkJet Printer
Printer does not "grab" paper but can see parts turning
Dell all-in-one 922 loaded paper tries to feed, whatever part inside is supposed to "grab" the paper and finish sending it through will not grab. the printer sounds exactly as it did when new when printing. part is rolling but doesn't grab
  • 90 Answers
You have bad rollers. you can try to clean the roller with an alchohol wipe but I doubt it will help much. You need to have the roller replaced or get a new printer
Posted on May 27, 2009
  • Troy Anderson May 27, 2009
    you have bad rollers. you can try to clean the roller with an alchohol wipe but I doubt it will help much. You need to have the roller replaced or get a new printer
Printer will not feed paper straight grabs one side and pulls the paper crooked and crumples the paper
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Aug 07, 2011 | Dell 922 All-In-One InkJet Printer
My printer won't take the paper - it makes noise but it is not grabbing the paper
The paper feed roller is commonly either dirty or has a sliver of paper inside. To clean it you should use denatured Alcohol with a lint free cloth. You have to remove all paper and the paper tray and may need to flip the machine to get access.
Nov 29, 2009 | Dell 922 All-In-One InkJet Printer
The Dell 922 printer will not feed paper through it. I can hear the noise, but the paper won't go through.
Mine does this regularly as well. If you lean over the top of the printer and look down inside where the paper is inserted, there is a gray roller on the right hand side. It's a rubber feed roller and mine usually gets dusty or sometimes coated with cat hair. I use qtips and a 50/50 alcohol & water solution to gently clean it. Be careful not to drip solution anywhere else. After it dries it usually regains enough "grab" to feed again. I hope this is helpful..
Nov 19, 2009 | Dell 922 All-In-One InkJet Printer
Wont feed paper but says ready
Paper will not feed properly.Slips or doesn't grab
Oct 27, 2009 | Dell 922 All-In-One InkJet Printer
I have a Dell all in one 922 printer When I try
If your device is out of warranty, I'd suggest to clean the rollers again completely. What I mean is to remove the scanner lid and back cover, then clean all of the rubber rollers gently with alcohol and swabs.
Jun 14, 2009 | Dell 922 All-In-One InkJet Printer
Paper feed problem with Dell 922
Take a cotton swab and some alcohol and clean the rollers. They may be filled with paper fibers.
May 03, 2009 | Dell 922 All-In-One InkJet Printer
Dell 922 All-in one ink jet printer paper feed
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 08, 2009 | Dell 922 All-In-One InkJet Printer
Dell 922 All-In-One Printer will not print anything
The printer does not feed paper from the tray and then states that there is a paper jam. I have removed all paper and there isn't a paper jam. It will feed paper through the lower roller and straight into the printed paper tray, but will not feed a new sheet.
Nov 01, 2008 | Dell 922 All-In-One InkJet Printer
Paper feed
The feed rollers are probably dirty from paper lint. The feed roller on the 922 is on the right side as you face the front of the printer. I use a damp sponge to clean it. Good luck.
Nov 12, 2007 | Dell 922 All-In-One InkJet Printer
Dell 922 All-In-One InkJet Printer Logo
354 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
