I have two socks inside my drum in my washing machine
It has just happened and I have removed the black hose that conects to the drum and there is nothing there, where are they and how can I remove them? Please help! :)
    President:
  • 1,185 Answers
They are probably wrapped around the heater element or laying in the sump that the heater sits in.
When you said you have removed the hose did you remove it from the pump end or the drum end.
The drum end should allow you to get a torch and a small mirror to take a look inside the base of the drum.
If you can see something then you are home and dry if not then:
Use a wire coat hanger and form a small 90 degree bend in the end say 18mm, dont make it too big in case it fouls on the heater.
Use that to probe along the bottom of the inside of the drum
If you can feel something soft turn the wire a couple of times to engage it in the cloth and try to pull ut out.
If it wont come out then the only solution is to remove the heater element to gain access
Posted on May 27, 2009
Something stuck underneath drum, how do you remove?
Socks and alike stuck in inner drum can be removed easy by taking off the bottom sump hose ,this will let you see where sock is perhaps/failing that you could remove the heater element,giving a bigger picture in within the drum.......Good luck.
Feb 26, 2011 | Asko 8005 Front Load Washing Machine
I have a Whirlpool Imperial Series Ultimate Care II. It will not drain after the wash cycle. This happened suddenly. I have not noticed leaks and no water backed up in the hoses.
it will be something blocking the water exit system usually a sock gain access to the drum assembly normally at the rear of the unit you should see the exit hose if you sqeeze it and there is water in it the block is there about . Get something to collect the water and remove the assembly between the drum and the pump do it from the highest piont to allow the water to be release slowly as possible. Usually a sock !!!
Aug 23, 2010 | Washing Machines
Washing machine will not drain. Check the drain filter and cleaned that. Made sure the Drain hose was not twisted or bent. What do I do???
Does the pump run when it is supposed to? If ok, check the drain hose where it is attached to the bottom of the outer drum. If there is water in the drum and you pull the hose loose at the drum, the water should run out of the hose fitting (into a bucket). If nothing or very little comes out, look for something inside the drum blocking the outlet (a stray sock or similar). If there is no removable plate nearby, then the machine must be dismantled to the point that the inner drum can be removed. Major job!
Nov 15, 2009 | LG WM2487H Front Load Washer
Hotpoint aquarius extra manual WMA44 can't find the waste pipe
Remove lower rear cover of washer, locate, and remove large black hose fastened to bottom of drum, remove and clean plastic filter inside hose.
Please rate my solution.
Thanks.
Aug 28, 2009 | Washing Machines
Not draining all the way. slow spin
replace the door switch my washer did the same thing. switch is very easy to replace
Mar 19, 2009 | Frigidaire ATF6000ES Front Load Washer
How do you remove underwire lodged between drum and outer case
hi to remove bra wire from between drums ? you might try this 1st ? if you diconnect water supply hoses and unplug power supply then remove rear panel from machine you will have access to the large rubber drain hose from outer drum down to discharge pump ? ok hose is held by spring wire clips both ends remove clips then hose you may find bra wire either in hose or close to drum drain if you need ? feel inside drom via drain hole ? or probe with a piece of coat hang wire ? you may even find the mysterious missing sock/ thong / etc when you disconnect the hose too?? any debri has to lay in bottom of outer drum and so a little patience will locate them using this method instead of removing the main front door sealto drum for access to same area also with rear panel off you can check belt tension ? hope this helps/inspires you ? best wishes from uk
Feb 26, 2009 | Hotpoint First Edition FEW12 Front Load...
Calipso washer will not drain
what you are seeing is a blockage inside the tub. when the water cant get to the drain hose it will try to **** the water in it and that will cause the hose to colapse you need to remove the hose and see what is in it causing the no drain condition. i would guess a sock or something small like that. might even be a coin but something is blocking the water from getting into the drain pump.
Feb 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Hotpoint washer dryer
1. Turn off power
2. Turn off hot and cold inlets if possible - if not then pop outside and turn off water to house
3. Unscrew all the screws on the back of the machine to take off the rear panel
4. Use a large pair of pliers to remove the clip securing the large black rubber hose to the drum chamber.
5. Remove sock. Trust me, it's a sock :)
6. Put it back together.
If there is no sock (but I'm sure there is) then work your way through the drainage system until you find the problem. I once had a label from a baby grow in the fan blades of the pump. The drainage is pretty self explanatory. There's only the internal black hose with a filter in, then the pump, then the external hose. If there really is no sock then check them all.
Jun 30, 2008 | Hotpoint Ultima WD72 Front Load...
Kenmore 44092/spin cycle
It turns out that there was a sock stuck within the pump in the washing machine. I removed the back cover and removed all the excess water, because once the sock was removed, the water was free to escape. I just removed the hose that connects to the pump and felt the sock, and was able to remove it. Once I hooked everything back up, the washing machine ran great.
Apr 17, 2008 | Kenmore Energy Star 44092 Front Load...
Front loading washing machine is having leakage problem
You need to work out where the water is coming from, either the front, back left or right hand side to give you an idea what/where to look.
Front - Open the door and check the door seal (usually grey rubber round the door) look for splits, chaffing, damage.
Rear - check the connection to the pump, there will be a (Black) rubber hose from the drum housing about 12-18"long, check for splits, connection etc.
Check and remove the pump itself, Isolate the electricity, to remove - disconnect the outlet hose from below the sink or upstand, lower the outlet hose to the floor and syphon off the water into a bowl from the machine, there will be some even if the machine appears empty. disconnect the plug on the pump (2 wires), disconnect the hoses from the pump (2 off) and check inside the hoses, bra wires, socks etc. look inside the pump for foreign objects, the pump can be wasily split open via 3 screws normally, refit in reverse order.
Top - remove the top cover usually 2 screws at back or side and will slide slightly to remove, check hoses to drawer and the hose below drawer to top of the drum housing, check the inlet solenoids at the back (where the water hoses connect).
hope this helps
Apr 08, 2008 | Washing Machines
Washing Machines Logo
55 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
