Question about Dacor Preference SGM365SS Gas Cooktop
I have six burners. Two on the left operate and the middle rear operate without the clicking continuing. The fourth in the front middle operates OK also. However when the front or back right are turned on they continue clicking as well as the front middle. It is a 36 inch dual fuel range in the epicure series I cleaned the ignitor as suggested in the solutions, but this did not correct the problem.
  • rdhillyer May 28, 2009
    Is it possible that when only two of the burners are affected that a new controller board is the possible problem?
    President:
  • 2,559 Answers
The flame sensors are not picking up the signal that the flame is present.
Posted on May 28, 2009
    Scholar:
  • 152 Answers
It sounds more like the thermocouple is not registering the flame.  The thermocouple is a small tube-like device that changes resistance based on the heat of the flame.  If the thermocouple doesn't "register" the heat, then the ignitor circuit doesn't know when to shut off (it doesn't know when the gas has actually been lit, the clicking sound is the ignitor continuing to try to light the burner).  I'd look into replacing either the thermocouple itself or (unfortunately) the controller board.  I say unfortunately because I had to get mine replaced on my Thermador 36" range that cost over $250 just for the part...!  Good luck!!
Posted on May 27, 2009
My Viking Range top has 4 burners and the automatic ignition on the left two burners do not wok. Can hear clicks and gas but no ignition. Can manually lite them. Any ideas?
Sorry to read about your problem, I hope this helps you out.
your lite tube may be clogged, or take a needle and clean the hole's next to the lite tube on the range grills..
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 19, 2010 | Viking Cooktops
We have a Jenn-air JGC8430ADS. The rear left
WE have a Jenn-Air JGC8430BDW gas cooktop. How do i replace a broken ignitor?
Feb 13, 2010 | Jenn-Air Cooktops
When lighting any burner...the igniter continues after lighting."click, click, click, click, click" and so fourth. Thank you for your time.
My parts list doesn't tell me if that is an auto relight unit or not. But since you say it happens on any burner I'll leave out stuck ignitor switch for now.
Check the house ground wire to the unit and check that the burner caps are installed properly. The auto units read a ground when they ignite so if the burner caps are on wrong or dirty they can cause this.
jim
Jul 27, 2009 | GE 30 in. JGP326 Gas Cooktop
Jenn-Air 36 Gas Cooktop
try to use macth in the burner u said,if ok the flame,the problem is the igniter wire,nid to replace,but if u use the macth then the flame is malfunction again i think the sensor is the problem,nid the tecnician coz is hard to repair,sometime after repair the sensor it problem again in next day
tnx gerbee
Jul 02, 2009 | Jenn-Air 36 in. CCGP2720P Gas Cooktop
Burner on Thermador stove top does not light
Switch for burner 4 is not working properly - could have a bad contact resulting in just one spark and nothing more.
May 03, 2017 | Thermador SGS36GS Gas Cooktop
Viking stove ignitor
the continues to click problem, for e it was only when my smaller burner was lit. theo others were ok. When I took the burner apart it was very dirty. I cleaned it up (a wire brush in my drill press) and it works fine now. I think it was just bad electrical conduction.
Aug 20, 2008 | Viking 31 in. VGSU101 Gas Cooktop
Some Burners Will Not Ignite
probably a worn wire to the electrode or a cracked ignitor. you are faced with taking off the hobtop and looking - no easy solution. you should not do this unless you are confident and don't interupt the gas path
Apr 06, 2007 | Dacor Preference SGM466 Gas Cooktop
Clicking noise on cooktop even when all burners ignite
I have a viking gas cooktop. The ignitor on one of my front burners wouldn't stop clicking even after the flame ignited. I swapped that ignitor with the ignitor from a back burner, expecting that the problem was with the ignitor and that the back burner would start to click incessantly, but at least I'd have my favorite front burner for use. Instead, the front burner was then only clicking 50% of the time and the back burner was fine, suggesting the problem was related to the burner not the ignitor. I pulled the front ignitor a bit away from the burner and now it is working normally. Hope this helps.
Dec 01, 2006 | Viking 37 in. VGSU161 Gas Cooktop
Dacor Preference SGM365SS Gas Cooktop Logo
137 people viewed this question
Top Dacor Cooktops Experts
jdthefixer
Lakeland Appliance...
Are you a Dacor Cooktop Expert? Answer questions, earn points and help others
