Question about Car Audio & Video
1991 olsdsmobile 98 regency elite - factory radio is "stuck" on 98.1 default, and clock reads "1:00". Unable to change anything from front panel. Battery was recently replaced. How do I "unlock" this radio?
    Brigadier General:
  • 3,614 Answers
HI there,
You should not attempt to use a master reset option to set your code straight because that feature is not offered, in case of a car radio security code-loss. This is a restriction set for security reasons. There may be times when you purchase a used car and its radio security code provided doesn't work. This may happen because the stereo in use may not be the one that was originally provided by the manufacturer. In other instances, the code could have been reset during an earlier lost key code situation. In such an event, your easiest way out is to have the car radio security code decoded.
Let me know for any clarifications
Posted on May 27, 2009
  • micromaster
    micromaster May 27, 2009
    there are instances when, you may not be able to recall the radio code.
    In such circumstances, it is advisable to call your car manufacturer to
    help you get started. Though your radio will only lose its code in the
    event of a flat or disconnected battery, don't assume that such events
    don't take place. It is always wise to remember your car radio security
    code at all times. You never know when you need it.
How can I check a camshaft sensor in a 1991 Oldsmobile 98 Regency Elite?
find out what resistants in ohms is suppose to be and check with ohm meter
Apr 21, 2015 | Oldsmobile 98 Cars & Trucks
1990 oldsmobile 98 Regency Brougham fuel gauge doesn't work
Most likely the float in the tank is stuck. You'll need to pull the fuel pump out and fix the float.
Nov 27, 2013 | 1991 Oldsmobile Ninety Eight Regency
1995 Olds 98 Regency Elite I'm re-attaching rear
there is a small set screw in the base of the mirror you will need to loosen this and then slide the metal plate out.
Aug 30, 2010 | 1995 Oldsmobile Ninety Eight Regency
My 91 oldsmobile 98 runs rough in idle but when driving run smooth.
Rough idle is a very common problem on 4 cylinders, but I believe the 98 Regency has a 6 cylinder in it, right?
Sometimes the coil packs get iffy, and sometimes the EGR Valve gets a leak in it causing a rough idle.
When the accelerator pedal is depressed, it can change things so that the engine seems to run smoothly.
However, I would look for codes to see if anything intermittent is occurring in the engine that may need attention.
The OBD-I scanner can help to diagnose the problem, if anything is out of specifications on the engine in question.
The owner will have to find a technician that has such a scanner.
Aug 29, 2010 | 1991 Oldsmobile Ninety Eight Regency
How to replace 1991 olds regency 98 elite crankshaft sensor?
Remove the crankshaft pulley,the harmonic balance,with a puller made for this,then you can replace the sensor,and align it,if it is not aligned,it will break it.
Aug 22, 2010 | 1991 Oldsmobile Ninety Eight Regency
I have a 1990 oldsmobile 98 and every day i have to get a boost to start it. what's the problem
it is the automatic load leveler that pumps air into the back shocks to level the car so it rides better when there are lots of people or weight in it. it is in the frontof the car opposite the battery, just disconnect it. had the same problem on my 1990 olds 98.
Aug 21, 2010 | 1988 Oldsmobile Regency
1991 Olds 98 Elite heater blower motor continues to run with key off. Will change speeds with controls but will NOT shut off..
if you haven't got your blower fan fixed yet, im sure it to be the same as mine, the blower motor relay which is out on the firewall under the big fuse block. take plastic cover off over the fuses and move the fuse block out of the way and you will see it staight under that. should be two screws holding it on.
Mar 05, 2010 | 1991 Oldsmobile Ninety Eight Regency
1991 Olds 98 regency elite not start
iv'e had the same problem. mine was the starter wire had a split in the wire under the plastic. i cut wire and wired it directly to the bolt.
Jun 03, 2009 | 1991 Oldsmobile Ninety Eight Regency
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
